Leave the fronts alone; bit of -ve camber is good.
The rears have some camber adjustment available, but you probably need a camber kit (available from Whiteline).
And 3" drop is probably too much in the first place.
hey
i got a question
i dropped my skyline 3inches
and my back wheels r cambered crazy.........17 inch wheels
my front are only slight cambered
my question is...........what do i need to get them to 0 camber as much as possible....????
thanks for any help
First job is to measure the height, centre of wheel to guard is the suspension industry standard;
This is what is usually needed for each height increment, note that all measurements are centre of wheel to guard;
Standard (new) height is 380 mm front and 370 mm rear
360/350 mm needs only the standard rear camber adjusters
350/340 mm needs 1 front camber kit and 1 rear camber kit
340/330 mm needs I front camber kit and 2 rear camber kits
Refer to the Group Buy thread for prioces and other details
http://www.skylinesaustralia.com/forums/in...showtopic=85467
;) cheers :wave:
Edited by Sydneykid
;) cheers :)
how much Degrees adjustment is available from these bushes?
Bit hard to say exactly, because the standard, old, soft, rubber bushes get distorted when the car is excessively lowered. So just removing the distortion reduces the negative camber. In addition the excessive lowering causes toe changes, which need to be corrected as well. Plus every car is different, of course.
Usually 1 rear kit does a minimum of 0.75 degrees, but I have seen over 1 degree due to the above factors. The 2 rear kits are good for 1.5 degrees to a bit over 2 degrees for the same reasons.
The front is similar with a minimum of 0.75 degrees, but I have seen over 1.2 degrees on ridiculously lowered cars.
As far as bushes compared to adjustable arms, all of the brands of upper control arms that I have measured (Noltec, Nismo, Ikeya, Cusco, Nismo etc) all stop at the same lengths. So choosing one brand over another to get more or less negative camber is pretty much a waste of time. The geometry of the suspension ultimately determines how much adjustment can be made.
:D cheers :D
i agree with sydneykid.
camber is damn important if u want your tyres to last
Actually, Camber is somewhat bad for your tyres and will cause severe uneven wear if applied too liberally.
Negative Camber (which is what you're chasing) will make your tyres wear on the inside more than normal, at a benefit of giving you greater tyre contact patch whilst cornering.
Off the top of my head, i used to run 3 1/4 degree neg camber on the front, and well the rear wasn't adjustable on my GTR XU1 Torana, absolutely perfect for twisty mountain runs and Mount Panorama, wear was reasonable as well.
Dropping one's car 3 inches is almost stupid imho, you throw out all the suspension geometry, ride on bumpstops, and in general the car will handle much worse. For best results, sit down with an Suspension engineer, work out the angles of your geometry, then setup your car up from there.
But of course, thats some $$$ involved AND wont make your car look phat at the macca's drivethru whilst you scrape your body kit over the marginally illegal speed humps.
Alternatively, buy one of SydneyKids pre-configured setups for probably the cheapest better-than-stock setups you're likely to get.
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Right, here's a video of the basic operation at least.  This is what you can expect day to day when you turn the car on and it boots from standby.  The only thing from a media point of view I haven't gotten working is for it to autoplay plexamp when it turns on from standby (it works from cold boot) but that's more of a plexamp problem as it will autoplay other music players.  Also attached is my one stray cable.  It's part of the screen's wiring adapters but there's just nowhere for it to go in my car.  I've just now done a bit of research and found a matching port on a 2010-2014 head unit with BOSE.  Mine has no BOSE so that's that case pretty much closed I think.  Plugging in the Infiniti AC panel basically did nothing for me, so that's a dead end as well.  Next port of call is to mess with this CANBUS module and see what I can find from it.  I found this resource containing the DBC files for a 2010+ G37 : https://github.com/icecube45/Dash_InfinitiG37/blob/master/InfinitiG37.dbc I'll now have something to go from when I try to extract my CANBUS data so I can see if the HVAC Mode, Fan Speed, Temperature, etc. match and also the gear shifter position.  It's a pretty big assumption that it's just mismatched CAN signals but considering all the devices in the CAN network are talking to each other (AC can be fully adjusted just with no info on screen) it might be a safe one.  I will report back WhatsApp Video 2025-02-26 at 12.49.10.mp4
    • Thanks for that Paul.  Do you think if I posted a picture you'd be able to remember where it went?
