  • Replies 40
yeah its been a three week labour funkymonkey haha.
yes ant she is now mine!! i am so going to either lose my license or kill myself she is actually faster than the skyline.
Great stuff Niz......I know how capable they are....I was up against one at a deca day in Vic...only power mods were intake and exhaust but it had a crap load of suspension work.....even my 200rwkw gtst was humbled by it (not by much but even so).
Enjoy it and I hope to see you at a track or skidpan soon :huh:
  • 3 weeks later...
Nice car niz, I have been sorely missing a turbo car and have been thinking about what to get as my next ride. A mate bought one of these a yellow limited ed one and I went for a drive in it the other day (basic modes, exhauast, pod filter, better suspension) and I was amazed at the low down torque and overall acceleration... i might have to look at one of these :)
nah jezz decided it wasnt for her .....its gone to a new home in rockingham so maybe some of the RICE crew might see it around .... but i doubt it. Its this guys first import - had VK statesmens and stuff like that before. In the end it sold for $14.5K
I had a cry! then i sat in my new project :rolleyes:
yeah but when importers are selling them for about $8K and other people with the same configuration are selling them for $15K .... not much of a choice. Unfortunately a vehicle is only worth what someone is willing to pay for it ...... plus it gets paulie off my back about selling it.
Admittingly my R33 wasn't exactly in perfect - there was a little bit of race tape on there where the corner of the front spoiler had been ripped and a trolley ding in the side etc.
Dan Im not going to argue with that its becoming scary in fact!!
Maybe i should even get a job as a carsalesperson :)
I've started even going off in threads (not these forums) "Should I by this car" it's like why the hell do you need a thread to ask every john, dick and harry should you buy a car or not - we aint going to be driving it, we aint going to be paying for it ..... if you like it and can afford it then the only person left ot give it the okay is an mechanic. Geez .... hahaha maybe that should go in the "what really grinds my gears thread" people that have to bring a committee or consult a committee of people before making a decision that at the end of the day will only effect them.
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
