FFS I will ban the next person that refers to their "Type M" as an "M Spec"... consider this... an "M Spec" is an R34 GTR variant, usually a whole $80,000 more expensive than an R33 GTS25t Type M.
https://www.sau.com.au/forums/topic/131714-type-m-r33/#findComment-2024871
hahaha.. ahh funky..
actually I think there were also R33 Type MR GTS25t as well.. just to throw a curve ball..
http://rps13kuma.hp.infoseek.co.jp/Friends...33/kuri_r33.htm
It was done by the Kangawara prince nissan - 280MR (i think it's called..)
goto babelfish and stick this in the translate..
http://club-gts.sakura.ne.jp/skyline/conte...tory/index.html
Edited by Links
https://www.sau.com.au/forums/topic/131714-type-m-r33/#findComment-2025172
m spec is surposed to mean sunroof in r33
that is the only difference that i know of and as an owner of one , when i was selling it , i got sick and tyred of people saying that theirs was a m spec when it had no sunroof! :)
yeah not all mspec are meant to have sunroofs, difference are within the brakes, the rims and the bodykit, mpsecs have 16 inches rims and normal sky's have 15s,
https://www.sau.com.au/forums/topic/131714-type-m-r33/#findComment-2025203
So by looking at a s2, how can i tell if it is a type m or not?
Do only series II skylines come type m??
My mate has a 93-95 skyline and i think his one is a Type M... It's got red coloured brakes ( do they all come red?? ), sunroof, and also i think only the Type M comes with the skyline writing on the back boot which lights up???
Anyone can correct me or confirm this?
https://www.sau.com.au/forums/topic/131714-type-m-r33/#findComment-2031936
  • 4 weeks later...
"Type M' Is an options list available to all r32 and r33s.
It includes such things as body kits, 4 pot front brakes, adjustable front spoiler, and a bunch of other much less useful things; windscreen antenna, air purifier, illumous skyline garnish etc.
'Type S' were similar options available to the non turbo skylines
A list of these options is somewhere on the website.
Also, thanks for calling it typem, and not M spec.
Edited by Mulkers
https://www.sau.com.au/forums/topic/131714-type-m-r33/#findComment-2086493
jrocket,
yes, type m is an upper spec model that had some optional extras
BUT.. what you must realise is that >95% of skylines are in fact type M. And, even the non-type M cars have most of the options that the type M had anyway!
almost anything could be optioned in when bought new in japan, thus 5 different type M cars will all probably have different options, but will all be type M
at the end of the day, if a car is not advertised as type M, assume it is a type M unless stated otherwise. If you want to post pics up of the car, we can point out whether its one to steer clear of or not.
happy car hunting :P
Waz
https://www.sau.com.au/forums/topic/131714-type-m-r33/#findComment-2087244
  • 1 month later...
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
    • Uniclutch install vid, RB Track edition.   Highlight reel is very drive able, not noisy but still heavy with the clutch master he has.
