My 2 cents... Sounds like someone making up another model. Like on carsales once i saw a R32 GTS-T 92 model was a basic standard M spec car.
Advertised as "R32 Turbo SE (special edition)"
I laughed when the guy, he explained it was one of 100 cars ever build when i went to have a look at it.
All R33 GTS25Ts are Type-Ms
However Spec 2s (otherwise known as Series 2) versions kicked in from 1996 production cars onwards. There were some 1995 produced cars with some of the Spec 2 features, which are colloquially known as 'Series 1.5.'
The following thread contains a discussion about the differences.
http://www.skylinesaustralia.com/forums/in...showtopic=17349
We are looking at a couple of cars at auction in Japan , and it does say SPEC 2 on the detail sheet.
LSD's standard in all 96-98 cars ? , what about rear wipers do all R33's have them ?
Thanks for answers so far . Brad
Not all of the 33's are type M's. My friend had a 33 Gts25t that wasnt a type M.
Chris
That's the first I've heard of that.. well there was a GTS25t type G, but that was a sedan. All the model info on the net and on SAU doesn't seem to indicate otherwise for the GTS25t.
LSDs are standard in the Spec 2s. Some have the 'Active-LSD' which is similar to the diff from V-Spec GTRs, you can tell if it's one of them because the dash cluster will also have two lights for 'slip' and 'traction control' (something like that anyway).
Rear wipers are optional on any model Skyline.
yes they are referred to as gts25t.
any manual turbo 33 is type m.
and there were a few limited edition skylines made. they started doing them with the old DR30 skylines. a mate of mine has one. they came out with no stereo, and not much sound proofing. they are basically a race model. i have a HPI mag somewhere that talks about them. it is in a article about buying a skyline and says that they are so rare they aren't worth mentioning, as most were bought and used for race cars. i'm going to try to find the article and scan it.
YeeHaa thanks , we are going to bid on the car tomorrow anyway , the info we have the better . Much appreciated .
Brad
Captain Obvious would like you to know that there is a sticky thread at the top of this section which has a link to details on where you can get all the model specific info you need.
So..... what about the automatic ones? (Which were also sold as Type M?)
Going by the "all turbo manuals are Type M" theory, there would be no such thing as a 33 GTR.
All turbo R33 GTS-t's are type M. It really is as simple as that.
If someone can give me the vin number of the guy's car that supposedly isn't a type-M i will send him a screenshot from FAST indicating that indeed it is. If I am wrong then I apologise but i'm pretty damn sure.
What is he basing the not a type-M call on? Unless it came from the factory with a non-turbo engine and had a turbo engine dropped in....
Preaching to the choir.. :D
Type M came in manual and auto, and as you can see, the post I quoted stated that "any manual turbo 33 is type m"
.. which to an uneducated reader (yes, there are a few around) would assume by that comment that the Type M was only available with a manual transmission, and (engine capacity aside) this would make the GT-R (which is manual & turbo) Type M also.
I suppose I was looking for an explaination of the posters thoughts in regards to the automatic Type M's?
Perhaps the comment was based on the assumption that the "M" in "Type M" means that it has a manual transmission? :)
  • 2 months later...
hi, just wanted to know what the difference between an mspec s2 33 and the normal one.
reason being i went to chek out a 33 today but the guy said mspecs only come with side skirts and rear pods? i remember they had a different front bar?
Just as the guy said... the normal Series II Mspec does not have the side skirts and rear pods, the front bar is the same across the board though. There is an aftermarket Mspec front lip too but it does not come as standard on the Mspec version.
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
