My 2 cents... Sounds like someone making up another model. Like on carsales once i saw a R32 GTS-T 92 model was a basic standard M spec car.
Advertised as "R32 Turbo SE (special edition)"
I laughed when the guy, he explained it was one of 100 cars ever build when i went to have a look at it.
All R33 GTS25Ts are Type-Ms
However Spec 2s (otherwise known as Series 2) versions kicked in from 1996 production cars onwards. There were some 1995 produced cars with some of the Spec 2 features, which are colloquially known as 'Series 1.5.'
The following thread contains a discussion about the differences.
http://www.skylinesaustralia.com/forums/in...showtopic=17349
We are looking at a couple of cars at auction in Japan , and it does say SPEC 2 on the detail sheet.
LSD's standard in all 96-98 cars ? , what about rear wipers do all R33's have them ?
Thanks for answers so far . Brad
Not all of the 33's are type M's. My friend had a 33 Gts25t that wasnt a type M.
Chris
That's the first I've heard of that.. well there was a GTS25t type G, but that was a sedan. All the model info on the net and on SAU doesn't seem to indicate otherwise for the GTS25t.
LSDs are standard in the Spec 2s. Some have the 'Active-LSD' which is similar to the diff from V-Spec GTRs, you can tell if it's one of them because the dash cluster will also have two lights for 'slip' and 'traction control' (something like that anyway).
Rear wipers are optional on any model Skyline.
yes they are referred to as gts25t.
any manual turbo 33 is type m.
and there were a few limited edition skylines made. they started doing them with the old DR30 skylines. a mate of mine has one. they came out with no stereo, and not much sound proofing. they are basically a race model. i have a HPI mag somewhere that talks about them. it is in a article about buying a skyline and says that they are so rare they aren't worth mentioning, as most were bought and used for race cars. i'm going to try to find the article and scan it.
YeeHaa thanks , we are going to bid on the car tomorrow anyway , the info we have the better . Much appreciated .
Brad
Captain Obvious would like you to know that there is a sticky thread at the top of this section which has a link to details on where you can get all the model specific info you need.
So..... what about the automatic ones? (Which were also sold as Type M?)
Going by the "all turbo manuals are Type M" theory, there would be no such thing as a 33 GTR.
All turbo R33 GTS-t's are type M. It really is as simple as that.
If someone can give me the vin number of the guy's car that supposedly isn't a type-M i will send him a screenshot from FAST indicating that indeed it is. If I am wrong then I apologise but i'm pretty damn sure.
What is he basing the not a type-M call on? Unless it came from the factory with a non-turbo engine and had a turbo engine dropped in....
Preaching to the choir.. :D
Type M came in manual and auto, and as you can see, the post I quoted stated that "any manual turbo 33 is type m"
.. which to an uneducated reader (yes, there are a few around) would assume by that comment that the Type M was only available with a manual transmission, and (engine capacity aside) this would make the GT-R (which is manual & turbo) Type M also.
I suppose I was looking for an explaination of the posters thoughts in regards to the automatic Type M's?
Perhaps the comment was based on the assumption that the "M" in "Type M" means that it has a manual transmission? :)
  • 2 months later...
hi, just wanted to know what the difference between an mspec s2 33 and the normal one.
reason being i went to chek out a 33 today but the guy said mspecs only come with side skirts and rear pods? i remember they had a different front bar?
Just as the guy said... the normal Series II Mspec does not have the side skirts and rear pods, the front bar is the same across the board though. There is an aftermarket Mspec front lip too but it does not come as standard on the Mspec version.
    • That's the thing....the basics of fuel and ignition are deceptively simple.....getting it to behave like factory in all conditions after airflow mods is way more complex. Newer cars like the V37 are all about modifying the standard ECU which is about a billion times more complex than they were 20 years ago, with a bunch of parameters affecting others
    • The larger TB I had on the SS was a pain to get to idle right, but, that was cable In the end they just raised the idle up a couple of hundred RPM so it was happy idling away either in gear or in park (slush box life) I'm curious on how my NC will idle with the new intake, larger TB, and cams that are currently going in/on, but I have faith that MX5 Mania will sort this "electronical" "black magic" out the best they can in the tune with a electronic TB Sometimes I wish I knew more about the intricacies of tuning, but most of the time I don't because I know it would hurt my brain 🤣
    • That's the thing. Cam is smaller than before.. though the old cam was +6 degrees advanced. We're talking huge changes here, the narrowbands want to trim out 20% of fuel and pull the (wideband) idle to like 16.0 AFR or such. One side is a little more trimmy than the other. Think along the lines of ~20% to ~15-18%. Unfortunately my scouring of the internet hasn't really found anyone with this issue. People either just disable NB's or have them wildly different, where one is -20% and the other is +20 or 0 (i.e a sensor is just dead/wiring is just busted). Turning them off and relying on the base map only results in the wideband reporting at about 14.0 with the Varex closed. It'd be a little leaner (closer to 14.7ish) with the Varex open. I know I can just change the switch points so that the narrowbands agree with the wideband, but it's still odd. Both of them are reading voltage, it's just that they're reading quite high mv, in the ~800 region. It's just odd. This was with the IAT fudged to report it was about ~22 degrees which is my guesstimation of the temperature in the room. I have an OEM sensor ready to try tonight, which is slow and crap - but .. worked last time I used it. Sadly I am aware that idle tuning with the big TB is going to be a PITA and I look 'forward' to many hours spent stalling or stumbling idle or delving into drivability things.
    • The GTR strut brace clears the new manifold.. by about 0.5mm. So this means I need to buy an OEM GTT Strut brace (again), which will clear the new manifold, but not the bonnet vents. I guess I can sell the GTR Strut brace with the bonnet with the vents as a package deal as someone will need this one day. So my choices are vented bonnet but no strut brace, or GTR Bonnet with OEM brace (which I have to buy) but is bright red instead of the same colour as the rest of the car, which means the entire front end of the car will just be red until it goes back to paint jail. In other news the engine starts and doesn't leak. Why both O2 narrowband sensors think the tune is rich AF I do not know. The idle is also pretty shitty and my expensive IAT sensor from the USA is dead. The car sounds awful. But I assume or at least hope this is due to the many exhaust leaks, and the concrete garage it is in, sitting there with 0 intake bolted to it, and no bonnet or panels or anything to stop the induction/intake sound which is about 200db.
