  • Replies 141
In
Good to see Jon ;)
we might be going on the cruise
Whoring deleted guys
can my mate in his forrester come he wont do anything stupid its if he cant
As long as he behaves, its not a problem
meet up point is easy, just around `the corner from just jap, infact we should all just park up at the front of just jap :P
how long till the cruise though? i have yet to re register my car, should be ready in maybe 2-3 weeks, if its after then i shall be in
The date is in the titla mate, let me know if you can get it done in time?
Should be in for this one, see how i go, and how come no macca pass runs????!!!!
Makes the night way too long, if you guys are keen for it by all means go after the end of Nasho :O
Think I'll come along for the show.
Cool :P
Im with Beau on this one!! it was well worth the drive..
Im in otherwise :O
Andrew can you navigate for me again?? :D
Andrew should drive himself and get that car dirty :laugh:
for some reason the 22nd is in my head as already doing something - if not - im sure I could turn up - I could bring some LS1's! :P
Cool, just no one looking for a race please Chris :laugh:
i say bring the LS1s as well more cars the better
You're in?
I'm interested
Ill add you to the list, let me know for sure if you're coming? cheers
I hope to make it to this one.
Added to list
Cool im already in with out posting......Nice :P
I might have a rotary coming only cause he needs a ass whopping :laugh:
Yes
Now bring that skyline please
If Andrew is worried about the roads etc, give me the keys, i know the road
Yes
We will see if we bring it out I like going in some one elses car! :P
SIF!!! you get to drive it before me :laugh:
    • I have done smoke test and can’t see any leak on high or low side.   checked pump and fluid can flow through. Removed the high pressure from steering and did smoke test and same on low side, no leak.   puzzled. Thinking why if it was all ok it suddenly went as car was off road for a year. Don’t want to disassemble pump yet as i can see fluid / air( compressor) can flow through with no issues
    • Which manifold mate? Meanwhile......Mark is wondering how bonnet vents would look on the NC 🤣
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
