Have just done the first test session on semis i felt the car was a little loose in the back end any ideas on how to best make it stick just a little more.
I think that the spring rating maybe just a bit to firm and is picking up the inside rear enough to allow to brake traction.
Any comments will be well recieved. And i will pass the 997 turbo next time i swear.
regards
https://www.sau.com.au/forums/topic/131749-comment-please/
regards
I need to know a few details before I can really make any meaningful suggestions;
1. Spring rates?
2. Shock brand?
3. Stabiliser bar size?
4. Stabiliser bar settings, if adjustable?
5. Wheel alignment settings?
6. HICAS or not?
7. Engine power?
8. LSD type and condition
That'll do for a start.
:) cheers :)
https://www.sau.com.au/forums/topic/131749-comment-please/#findComment-2440746
1. Spring rates?
2. Shock brand?
6. HICAS or not?
7. Engine power?
:) cheers :O
Ok in answer to the replies yes i think the rear is far to hard and the spring rate will need to be lowered but i will follow due course as you guys have years more experience with these cars.
1. Hard, :( thats all i know they were on the car when purchased or rescued from scrap yard is a better term.
2. Ohlins all round non adjustable
3. standard front and back
4. N/A
5. Neutral toe settings front and rear, and 1mm neg camber on front and back and no caster adjust as standard items used.
6. Lock bar in use removed the HICAS
7. about 400 hp at fly guess though but would be close.
8. I dont know to be honest be i would assume factory.
Also i need to mention i am running semi's as mentioned but the car was not handle like this on the track day i ran a few months ago. I have installed a 7 point cage ( as mention in another forum ) could this have stiffened the car?
Edited by tacker
https://www.sau.com.au/forums/topic/131749-comment-please/#findComment-2441108
As well as the spring rates, you might want to experiment with different turn in points (try later compared to other cars) and get an attesa controller and dial in more front drive than standard (they are pretty taily stock, later models addressed this with more front drive to some extent)
https://www.sau.com.au/forums/topic/131749-comment-please/#findComment-2441430
Ok i should have been a bit more imformative with my request.
Car was good coming out of corners as there are only 2 second gear corners the rest are either 3rd or one very quick 4th. The car was turning in well but would become loose in the rear mid corner with a nice consistant throttle and not just pushing it straight to the floor. And this was a constant right through out the 4 x 20 minute sessions no matter what lines i tried. I am sure it is either the swaybar or springs or even both. As it was the car was nice and consistant it just needed a bit more rear traction and it would be a much better car to push around a track.
Regards
https://www.sau.com.au/forums/topic/131749-comment-please/#findComment-2441744
1. Hard, :rolleyes: thats all i know they were on the car when purchased or rescued from scrap yard is a better term.
4. N/A
Suggestions follow;
1. You really need to know the spring rates, this thread shows you how to get the dimensions, then send them to me and I will work out the spring rartes for you.
http://www.skylinesaustralia.com/forums/in...showtopic=79157
2. I have never seen non adjustable Ohlins. Are you sure they are Ohlins? Are you sure that they are non adjustable? No knobs or allen key adjusters on the shock tops?
3 & 4. For regular circuit work you really should look at upgrading to adjustable stabiliser bars, that will enable you to tune the handling balance
5. For regular circuit work you really need around 2.5 to 4.0 degrees negative camber at the front and 1.0 to 2.0 negative camber at the rear. More caster (than standard) is even more essential, do yourself a favour and spend ~$120 and get a caster adjusting kit.
6. Good move
7. That's enough to get some power oversteer
8. OK
On to your observations. For mid corner oversteer, my first guess is the rear spring rate is too high, not unusual for a Japanese kit. Hence why you need to spend a few minutes and get those coil spring dimensions. If you had adjustable stabiliser bars you could have wound on a bit more front bar, that would have overcome the oversteer. Or wound off the rear bar, if it wasn't already at its softest setting.
You could try a little rear toe in, say 2 mm. That will help with the midcorner oversteer, but the downside might be poorer turn in response. It's simply a matter of trying it.
For driving technique, I would try a slightly slower corner entry and then use a little power at mid corner. This gives the front wheels a little torque which tends to pull the car straight. Not large lump of throttle, just a progressive squeeze, which will them give you a higher entry speed to the next straight.
Hope that has been of some help
:thumbsup: cheers :(
Edited by Sydneykid
https://www.sau.com.au/forums/topic/131749-comment-please/#findComment-2441837
Cheers SK,
I am just about to get on a plane for Angola ( Lucky huh ) but i will do as you say as soon as i get back into Dubai.
I have read your thread on the sprind rates and i will post them to you ASAP. The shocks are ohlins but i will have to check the allen key bit.
Angain thanks for the help and i will order the castor adjust kit.
Regards
https://www.sau.com.au/forums/topic/131749-comment-please/#findComment-2442019
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
