Have just done the first test session on semis i felt the car was a little loose in the back end any ideas on how to best make it stick just a little more.
I think that the spring rating maybe just a bit to firm and is picking up the inside rear enough to allow to brake traction.
Any comments will be well recieved. And i will pass the 997 turbo next time i swear.
regards
https://www.sau.com.au/forums/topic/131749-comment-please/
regards
I need to know a few details before I can really make any meaningful suggestions;
1. Spring rates?
2. Shock brand?
3. Stabiliser bar size?
4. Stabiliser bar settings, if adjustable?
5. Wheel alignment settings?
6. HICAS or not?
7. Engine power?
8. LSD type and condition
That'll do for a start.
:) cheers :)
https://www.sau.com.au/forums/topic/131749-comment-please/#findComment-2440746
1. Spring rates?
2. Shock brand?
6. HICAS or not?
7. Engine power?
:) cheers :O
Ok in answer to the replies yes i think the rear is far to hard and the spring rate will need to be lowered but i will follow due course as you guys have years more experience with these cars.
1. Hard, :( thats all i know they were on the car when purchased or rescued from scrap yard is a better term.
2. Ohlins all round non adjustable
3. standard front and back
4. N/A
5. Neutral toe settings front and rear, and 1mm neg camber on front and back and no caster adjust as standard items used.
6. Lock bar in use removed the HICAS
7. about 400 hp at fly guess though but would be close.
8. I dont know to be honest be i would assume factory.
Also i need to mention i am running semi's as mentioned but the car was not handle like this on the track day i ran a few months ago. I have installed a 7 point cage ( as mention in another forum ) could this have stiffened the car?
Edited by tacker
https://www.sau.com.au/forums/topic/131749-comment-please/#findComment-2441108
As well as the spring rates, you might want to experiment with different turn in points (try later compared to other cars) and get an attesa controller and dial in more front drive than standard (they are pretty taily stock, later models addressed this with more front drive to some extent)
https://www.sau.com.au/forums/topic/131749-comment-please/#findComment-2441430
Ok i should have been a bit more imformative with my request.
Car was good coming out of corners as there are only 2 second gear corners the rest are either 3rd or one very quick 4th. The car was turning in well but would become loose in the rear mid corner with a nice consistant throttle and not just pushing it straight to the floor. And this was a constant right through out the 4 x 20 minute sessions no matter what lines i tried. I am sure it is either the swaybar or springs or even both. As it was the car was nice and consistant it just needed a bit more rear traction and it would be a much better car to push around a track.
Regards
https://www.sau.com.au/forums/topic/131749-comment-please/#findComment-2441744
1. Hard, :rolleyes: thats all i know they were on the car when purchased or rescued from scrap yard is a better term.
4. N/A
Suggestions follow;
1. You really need to know the spring rates, this thread shows you how to get the dimensions, then send them to me and I will work out the spring rartes for you.
http://www.skylinesaustralia.com/forums/in...showtopic=79157
2. I have never seen non adjustable Ohlins. Are you sure they are Ohlins? Are you sure that they are non adjustable? No knobs or allen key adjusters on the shock tops?
3 & 4. For regular circuit work you really should look at upgrading to adjustable stabiliser bars, that will enable you to tune the handling balance
5. For regular circuit work you really need around 2.5 to 4.0 degrees negative camber at the front and 1.0 to 2.0 negative camber at the rear. More caster (than standard) is even more essential, do yourself a favour and spend ~$120 and get a caster adjusting kit.
6. Good move
7. That's enough to get some power oversteer
8. OK
On to your observations. For mid corner oversteer, my first guess is the rear spring rate is too high, not unusual for a Japanese kit. Hence why you need to spend a few minutes and get those coil spring dimensions. If you had adjustable stabiliser bars you could have wound on a bit more front bar, that would have overcome the oversteer. Or wound off the rear bar, if it wasn't already at its softest setting.
You could try a little rear toe in, say 2 mm. That will help with the midcorner oversteer, but the downside might be poorer turn in response. It's simply a matter of trying it.
For driving technique, I would try a slightly slower corner entry and then use a little power at mid corner. This gives the front wheels a little torque which tends to pull the car straight. Not large lump of throttle, just a progressive squeeze, which will them give you a higher entry speed to the next straight.
Hope that has been of some help
:thumbsup: cheers :(
Edited by Sydneykid
https://www.sau.com.au/forums/topic/131749-comment-please/#findComment-2441837
Cheers SK,
I am just about to get on a plane for Angola ( Lucky huh ) but i will do as you say as soon as i get back into Dubai.
I have read your thread on the sprind rates and i will post them to you ASAP. The shocks are ohlins but i will have to check the allen key bit.
Angain thanks for the help and i will order the castor adjust kit.
Regards
https://www.sau.com.au/forums/topic/131749-comment-please/#findComment-2442019
    • Sounds good. Provided the panel is flat/level I'd be happy to start the painting process.  While you are learning, for sure you could do this. Its only paint, you can always sand it all back and start again. Its only your time and money on materials, but while you're learning, really its time and money spent on your education.  Once you know how to do this bodywork and painting, you won't want to waste your time and money on frivolous activities lol.
    • Yep I will use a guide coat after putting filler, I will do it on the whole panel as I'm a beginner so chances I've made quite a few errors. In that photo, I think that was a low spot, I just for example said to pretend it's flat but I will put filler + guide coat after to assess where I'm at. Yep with that picture, the panel is wet as it rained when I took the photo. But all those scratches are completely smooth, I went over it with 240 grit and can't feel it, even with my nail digging into it. I was legit thinking to buy a 2k can and spray primer to see how it turns out but then thought to myself it's going to be a mess doing it haha. Good mention there. Thanks for all that info I think I know what to do next.
    • Prior to laying down the primer, you need to make sure the surface is completely level. For example, based on this picture, I strongly suspect that the areas marked in blue are higher then the area marked in green.  If you spray primer over this entire area, then paint and clear it, the finished result will 100% show the low area. It will stick out like dogs balls. Unfortunately the paint won't magically level out the low areas as you lay it down.  Without seeing it in person, I expect that the green area will need to be filled, then use a guide coat and check that the entire repair area is level with a large sanding block.  With this picture, are you saying that even though you can see the scratches, the panel is in fact completely smooth and flat? If this is the case sure you could prep and paint it as it is.     The picture with the paint you described as blistering, it's hard for me to comment on from the photo alone. It looks like the panel is wet? Dunno, looks strange. Does the panel feel as smooth as glass when you run your hand over it? **** Going back to your question again, generally you would only sand the primer if you made a mistake while laying down the primer.  If the panel is prepped properly and you lay the primer down properly, you should not need to sand the primer.  This wouldn't work - Don't prep the panel. Spray primer and see how it turns out. Sand the areas where the issues appear. Spray more primer and see how it turns out. Sand the areas....... Yeah you'd go round and round in circles getting no where.
    • That's sick, thanks for that, mine has much the same mods on a 400R. I just don't have the heat exchanger yet.   Might be worth a trip down the M1 to Syndey for a tune.
    • Mate , this is the current mods list Current Mods list (Installed) RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Cat Back  RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Front Pipe AMS  - INFINITI Q50/Q60 RED ALPHA COLD AIR INTAKE KIT AMS  - Performance Heat Exchanger Intercooler AMS Alpha Performance Full Race Down Pipes ECUTEK tune form TuneHouse in Sydney .(Just over 2k) The car came with HKS - Power Editor but I had it removed for the full tune. I would say if you are using the car for street diving a proper tune would be better.
