Hey guys, gotta do a clutch on my GTR soon and i need to know 1, how to do it 2, any nastys to look out for and 3, how to do it!! I got no idea how to get it out, havent even looked at it yet but i imagine its gunna be a pain in the backside, so any info would be helpful
https://www.sau.com.au/forums/topic/131764-removal-of-33-gtr-clutch/
you NEED a trans stand with the threaded tilt things on it. you need to remove the whole gearbox mount.
position the box on the stand with the gaerbox mount point at the front half of the stand. thats aprox the center of gravity. you need to tilt it over about 30 degrees to clear the startermotor hump on the bell housing from the tunnel
also to did engage the clutch fork use a long screwdriver with a small bend in it to wedge indetween the release bearing and diaphapm spring bearing retainer (holding the spring clip thing hard against the clutch cover) and give the fork a jerk and the bearing will pop out.
dont try to pull the pin on the linkage out. its just makes it more akward.
apart from that its pretty easy.
a good quality pair or 12mm open end spanners is a must for the front prop shaft. as they seem to get very tight.
Have fun getting that top started motor bolt out :(
When i did the clutch on the R the 2nd time, i did it whilst the car was on axle stands, used 1 car jack to jack up the engine so it tilted back, and the 2nd to lower the box out. With the top starter motor bolt, you will need all of the extensions you can get (so the ratchet head is almost at the end of the box) and an adjustable socket on the end of the extensions.
Basically just get in there at it and be prepared to swear and curse and probably break things. Well thats just from my experience :(
Its a pain in the ass on the floor but very easy with a hoist.
Its a very heavy box about 95kg so if you do it on the floor you will have to use a jack . If you done boxes before you will see what you have to undo when you are under there . Front pipes have to come off and the front driveshaft .
The easiest way to undo the top box bolts is a long extention ( uni will come handy as well) then undo the subframe bolts about 10mm and it will make esay to get them. When you unplug the attessa pipe block it with something so it doesn't drain the tank no need to block the g/box end but if you do it wont make a mess. Don't forget to take the shifter out before you lower the box. The top starter bolt can be hard to get if you have a C spanner it will make life easier but you may have to hang of it. If you have a late 32 , 33 or 34 she will have a pull clutch so you will have to realease the fork .
Don't forget to bleed the attessa when you put it all back .
If using a hoist no need to take tailshaft completely off or front prop shaft out...we only did this the 1st time when we didn't know what we were doing. 14mm palm spanner is also handy for top starter motor bolt...and yes even we forget the shifter every now and then.
    • This has been covered a bazillion times but google wet boiling point vs dry. Motul is only good when it's fresh, once it absorbs moisture it gets pretty average very quickly. So as above, make sure you change it if you're going racing. I run the Endless brake fluid in mind, but only because a mate is a distributor and it's cheap. It's not quite as good as SRF but I'm running 380mm rotors on a Skyline so it's not like they get hot.
    • That's the thing, they still add it and it makes fuel cheaper, implying adding 10% of it drops the cost of 91 by what, 5c a liter? I remember when it was barely half the price of 98. Because you know, 85% of what is in the fuel is way cheaper than 91 fuel is by volume.
    • Auto electricians that do repairs on automotive AC systems can source service kits. I don't know where they actually source them. I do know that there is one available for the R34 comp that I would need it for. If you have to pay someone to dismantle, clean and do needed repairs and fit kit contents, then you'd probably end up spending a good fraction of the cost of a new one. I would not be paying for that, because I would be doing it myself. My mechanic (bro-in-law) will happily source what is needed. Back in the day (like in the 80s and 90s), rebuilding an AC compressor was the standard approach, same as for starter motors, alternators, etc, because new replacements were v. expensive. After the China manufacturing boom and the rise of the disposable approach to everything, people just started throwing broken/worn stuff away and not rebuilding things.
    • Is rebuilding it even a thing? Where would the shop find parts for it? I looked at some off these local online stores for my r34 and suprisingly they had brand new aftetmarket ones for $600-800 I think. I guess r32 might be a bit tougher.
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
