Hey guys, gotta do a clutch on my GTR soon and i need to know 1, how to do it 2, any nastys to look out for and 3, how to do it!! I got no idea how to get it out, havent even looked at it yet but i imagine its gunna be a pain in the backside, so any info would be helpful
https://www.sau.com.au/forums/topic/131764-removal-of-33-gtr-clutch/
you NEED a trans stand with the threaded tilt things on it. you need to remove the whole gearbox mount.
position the box on the stand with the gaerbox mount point at the front half of the stand. thats aprox the center of gravity. you need to tilt it over about 30 degrees to clear the startermotor hump on the bell housing from the tunnel
also to did engage the clutch fork use a long screwdriver with a small bend in it to wedge indetween the release bearing and diaphapm spring bearing retainer (holding the spring clip thing hard against the clutch cover) and give the fork a jerk and the bearing will pop out.
dont try to pull the pin on the linkage out. its just makes it more akward.
apart from that its pretty easy.
a good quality pair or 12mm open end spanners is a must for the front prop shaft. as they seem to get very tight.
Have fun getting that top started motor bolt out :(
When i did the clutch on the R the 2nd time, i did it whilst the car was on axle stands, used 1 car jack to jack up the engine so it tilted back, and the 2nd to lower the box out. With the top starter motor bolt, you will need all of the extensions you can get (so the ratchet head is almost at the end of the box) and an adjustable socket on the end of the extensions.
Basically just get in there at it and be prepared to swear and curse and probably break things. Well thats just from my experience :(
Its a pain in the ass on the floor but very easy with a hoist.
Its a very heavy box about 95kg so if you do it on the floor you will have to use a jack . If you done boxes before you will see what you have to undo when you are under there . Front pipes have to come off and the front driveshaft .
The easiest way to undo the top box bolts is a long extention ( uni will come handy as well) then undo the subframe bolts about 10mm and it will make esay to get them. When you unplug the attessa pipe block it with something so it doesn't drain the tank no need to block the g/box end but if you do it wont make a mess. Don't forget to take the shifter out before you lower the box. The top starter bolt can be hard to get if you have a C spanner it will make life easier but you may have to hang of it. If you have a late 32 , 33 or 34 she will have a pull clutch so you will have to realease the fork .
Don't forget to bleed the attessa when you put it all back .
If using a hoist no need to take tailshaft completely off or front prop shaft out...we only did this the 1st time when we didn't know what we were doing. 14mm palm spanner is also handy for top starter motor bolt...and yes even we forget the shifter every now and then.
    • Major thread necro but how bad of a job is it to DIY? Looking at it online it looks like if you reuse your ring and pinion as long as those are in good condition it should be fine to just pull the axles/front cover and replace the diff that way? Or should I be replacing everything and doing preload measurements/gear mesh testing like the factory service manual mentions for the rear diff?
    • in my list I had the R33 GTR as the best Skyline. Infact I had all GTR's (33>34=32), the NSX, the GTO, the 300ZX, the 180SX, the S15 better than the FD RX7. I had the MR2 and the A80 as 'just' better. I also think the DC5R Integra looks better but this is an 01 onwards car. I also think the FC>FD. It's almost like aesthetics are individual! The elements @GTSBoy likes about the FD and dislikes about the 180 are inverse in my eyes. I hate the rear end of the FD and it's weird tail lights that are bulbous and remind me of early hyundai excels. They are not striking, nor iconic, nor retro cool. The GTO has supercar proportions. I maintain these look much better in person (like the NSX) especially with nice wheels and suspension which is mandatory for all cars pretty much. Some (or all) of these you have to see in person to appreciate. You can't write a car off until you see one in the flesh IMO. Like most people we probably just like/dislike cars which represent certain eras of design or design styles in general. I also think the 60's Jag E type looks HORRIBLE, literally disgusting, and the 2000GT is nothing to write home about. FWIW I don't think the Dodge Viper Gen1's have aged very well either. You can probably see where I rate bubbly coupes like the FD. I know we're straying now but the C4 and C5 absolutely murder the Viper in the looks department as time goes on, for my eyes. Wouldn't surprise me if people who love the FD, also love the MX5, Dodge Viper, Jag E Type, etc etc.
    • I used to hate R31s, and any of the other Nissans that led up to it, and any of the Toyotas with similar styling, because of the boxiness. They were, and remain, childish, simplistic, and generally awful. I appreciate R31s a lot more now, but only the JDM 2 door. The ADM 4 door (and any other 4 door, even if they are unique compared to our local one) can eat a bowl of dicks. The Aussie R31 is also forever tarnished by their association with stereotypical bong clutching Aussie R31 owners of the 90s and early 2000s. I think the Nissans of the 70s (other than 120Y/180B/200B) are far superior looking to the 80s cars. The 240K era Skylines are boss. The same is broadly true of Toyotas. Hondas don't ever register in my thinking, from any era. Mitsus are all horrid shitboxen in any era, and so also don't register. Subarus are always awful, ditto. Daihatsus and Suzukis also don't generally register. They are all invisible. I think the SW20 MR2 looks fiddly. The 3000GT/GTO is like that but way worse. Too many silly plastic barnacles and fiddly gimmicks ruined what could have been a really nice base shape. Kinda-sorta looks like a big heavy ST165 Celica coupe (and I'm not sure if that's a good thing or a bad thing). I think the 180SX is dreadfully bland. It's not bad looking. But it has no excitement to it at all. It's just a liftback coupe thing with no interest in its lines, and bad graphical elements (ie wide expanses of taillight plastic on the rear garnish). The S13 Silvia is a little better - getting closer to R32 shapes. But still....bland. S14? Nope. Don't love it. S15...a little better. Probably a lot better, actually. Benefits from not being like a shrunk in the wash R34 (where the S13 was a shrunk in the wash R32 and the S14 looked like a Pulsar or something else from the stable on Nissan mid 90s horrors). The Z32 was hot as f**k when it came out but hasn't aged as well as the A80. Keep in mind that I think the R33 is the most disgusting looking thing - and out of all the previous cars mentioned is objectively closest to my precious R32. It's just....real bad, almost everywhere you look. And that is down to the majority of what was designed in the 90s being shit. All Nissans from that era look like shit. Most other brands ditto. In that context, the FD absolutely stands out as being by far the best looking car, for reasons already discussed. Going behind the aesthetics, the suspension alone makes it better than almost any other car.
    • If they just called it the "Mazda Tiffany", it would have been spot on.
    • Yup but for me its the HR ! Cut my teeth on the old holden 6s in the day ! And here's me thinking in the day it was also the 300ZX and the Mitsubishi GT3000 ! All, as well had good lines, but always seemed to need finishing off, style wise.
