Changed My 33 Climate Control Lights To Blue(pics)
they're really not that much more expensive than the ones you buy at autobarn...$14 for 2...so $7 each or $10 for 1... not much difference :D
yeah ur right...just bought 5 x white and 5 x blue for both cars...should be fine. My issue is the directional light from the LEDS...this should help even it out..
  • Replies 75
installed some of these 2nite. They fix up the unevan problem pretty well, the cluster is heaps brighter now :)
these r the ones i bought, c how they have 4 LED's facing all direction's?
http://www.superbrightleds.com/specs/bulb_specs.htm
installed some of these 2nite. They fix up the unevan problem pretty well, the cluster is heaps brighter now ;)
nice...I'm still waiting for mine to be delivered. looks like it will be good.
and a picture of mine using normal style led's...note the brighter spots...the bits that look dull are pretty much as bright as a normal cluster, they just look duller because of the brighter spots...
i need some1 to help me with this ;)
Its VERY easy to do mate.
take out the cluster, flip it round, take out the 5 stock lights and plug in some parker style LED's
put it back in and you're done :)
wowo good results with the new style leds. The other pics resemble efforts I have done before and I just went back to globes cos it pissed me off too much. Should get mine this week and I will take a pic. I got white and blue...blue for the line and white for the FTO as I have blue/red dials...will look awsome.
Changed mine from regular LED's to the ones from America today...no bright/dull spots. completely even across the cluster.
Only downside to them is they are a Slightly lighter blue to the ones I had in there, which matched my gauges/headunit perfectly...but the new ones aren't far off :D
Photos: These are the American LED's
Nice even spread. :)
compared to the old normal LED's in the same dash...
and here's the new ones showing the slight color difference to my gauges
Not very noticeable :D
nice1 dezz...yeah I took a pic and mine look they same as yours but in real life I rekcon they looks better.
At least ur guages are blue...mine matched the stock lighting color...so i have to change them now :D
pretty sure its not the LED's kon. mine were like $14 for 2 (so hardly cheaper than yours)...
its the layout of the light spreading plastic on the back of the cluster
so it was the low quality LED's u had in before?
i wouldnt call them low quality. just a different layout.
justin had everyday single Narva brand LED's and i had a different brand with a triple LED layout on the top.
both showed exactly the same light spread...the ones from america have a better design
    • Hi everyone, just looking to see what's available in the GTR seat options, testing the waters on what's available. Wanting a driver's seat to replace my old school OG jap race seat, going to re-register the car so need a factory seat. Prices currently seem to go from $300 to $2k for a driver's seat. What's options are there, that's good condition and actually a realistic price? Located Brisbane. Thanks
    • Are these a plug and play setup, and do they need a tune, like a haltech ecu etc? Thanks
    • Nice work on the paint. Those 3 studs are long as.
    • Hi everyone, still chasing a bunch of this stuff. Thanks
    • Been over 2 months since I have done anything on the S15 and had a day off today so got stuck into mounting the radiator and intercooler. I ended up using factory bottom mounts as bolted in and I did order some gktech top brackets but didn't work with the PWR radiator so made up some with aluminium flat bar. Spent way to long on them but pretty happy how they are. Next job was the intercooler. Used some more aluminium flat bar and did the bottom mounts first. Top was easy as just one long piece and 2 90 degree coming off rad support and welded them on. The bumper support required some notching to let the outlets sit where I want so will add some reinforcement later to strengthen it. I have also bought ecu and waiting for it to arrive. Went with a Link g4x Xtreme but will be adding a ptmotorsport expander to add a few extra inputs over CAN. Went through a few different configurations on pclink to get what I want to allow future expansion for sensors and gearbox upgrades. Ordered gktech rear arms but looking at the hardrace lower control arms to have some extra adjustment too will see how the alignment looks after first setup. Got 2 more weeks of work before shut down and will have almost 4 weeks to work on this so planning on hopefully firing up mid January.   Also bought a 2015 brz with a heap of good gear, did noosa hill climb a month back. Owned it for 3 days changed alignment and sent it. Finished the weekend 2nd in class and only .3 off the 180sx best time last year. MCA Red coilovers, gktech rear lca, bolt on lock kit and tie rods, whiteline toe arms, cusco 1.5way diff and 4.5 ratio, endless brake pads, headers, exhaust, perrin intake and e85 tune. Electronic steering adjustment, nankang crs with koya wheels 17x9 +35. Have bought rear traction arm and relocation kit, extended studs and v3 tie rod kit. Planning on also getting flex tune as lucky to get 300km a tank with e85 and short ratio. Car is a heap of fun to drive and super easy to work on. AC in the line up at Noosa was mint in 35degree weather.
