Definition of unopened.
102 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
unopened is a way of saying stock internals, mate. Cams are in your engine, therefore by my reckoning they are internals.
if anything has been changed that doesnt just bolt onto the outside, the engine has been opened to do so.
I want to know. Just for general discussion. I think the LS1 boys think cams don't stop it from being 'unopened'.
The LS1 boys definitely consider a cam change to be 'opened'. Some of them have valve springs done but that is it, even then it is unopened aside form valve springs. Cams put you in a different class altogether.
Unopened to me - Nothing changed that isnt BOLT ON.
This means that the dynamics of the engine have not been changed, aka, no REAL (to me) mods have been done to the car.
To me, bolt on is anything before the inlet side of the engine and after the exhaust outlet (side of block). So the head is part of the "engine" in my view and if it is touched it has been opened.
Most cam work on LS1's, least when I had one was a case of getting new valve springs, pushrods, new gaskets and a better timing chain, which any way you look at it is major surgery. While its cracked open most people will opt for port, polish and nicely tuned extractors as well so calling it 'stock' would be generous at best and bullshit at worst.
i look at it this way - if you take the lid off a jam jar, then that bad boy has been opened.
Take the lid off your engine...? opened.
otherwise a cam change in a OHC engine could be considered unopened, but a cam change in an OHV engine is opened.
to me, "opened" is getting access to the internals.. which is literalyl opening the inside by taking the head off...
if cams = opened
then cam gears must also = opened
which are both wrong in my opinion...
Maybe if you get into the oily section it's opened. :)
