Duncan Posted August 30, 2006 Share Posted August 30, 2006 not relevant to dohc turbo cars...we don't have to open the motor to make big improvements... only means something to dinosaur drivers Link to comment https://www.sau.com.au/forums/topic/131841-can-you-still-call-an-engine-unopened-if-you-have-aftermarket-cams/page/2/#findComment-2449933 Share on other sites More sharing options...
Dale FZ1 Posted August 30, 2006 Share Posted August 30, 2006 Cam change alters volumetric efficiency. I'd call it "opened" for cam, compression, or turbo change. They all change the way the engine breathes. Modified is modified. Link to comment https://www.sau.com.au/forums/topic/131841-can-you-still-call-an-engine-unopened-if-you-have-aftermarket-cams/page/2/#findComment-2450091 Share on other sites More sharing options...
GTRgeoff Posted August 30, 2006 Share Posted August 30, 2006 Cams take me at most 1 hour to swap so I consider them as "unopened". Head off for improvement, slugs/rods and all that is opened. Whatcha floggin' mate Link to comment https://www.sau.com.au/forums/topic/131841-can-you-still-call-an-engine-unopened-if-you-have-aftermarket-cams/page/2/#findComment-2450696 Share on other sites More sharing options...
Abo Bob Posted August 31, 2006 Author Share Posted August 31, 2006 Nuthin. Just getting consensus. Link to comment https://www.sau.com.au/forums/topic/131841-can-you-still-call-an-engine-unopened-if-you-have-aftermarket-cams/page/2/#findComment-2451907 Share on other sites More sharing options...
AdamsR33 Posted August 31, 2006 Share Posted August 31, 2006 To me the head is the lid, so if you don't take the head off mate then it isn't opened. opened as i think , to get into the motor is to open it, removing/replacing cams are really on the outside of the motor. Unopened IMO. Link to comment https://www.sau.com.au/forums/topic/131841-can-you-still-call-an-engine-unopened-if-you-have-aftermarket-cams/page/2/#findComment-2452768 Share on other sites More sharing options...
Rexx Posted August 31, 2006 Share Posted August 31, 2006 Replacing cams ...unopened bottom end ........opened Yup thats what I've heard as well Link to comment https://www.sau.com.au/forums/topic/131841-can-you-still-call-an-engine-unopened-if-you-have-aftermarket-cams/page/2/#findComment-2453221 Share on other sites More sharing options...
Cubes Posted September 1, 2006 Share Posted September 1, 2006 Unopened to myself means standard mechanicals that have not been touched. Bolt ons only. An LS1 or old GM 5ltr. Is that unopened when changing cams? No. I believe it must be an equal playing field, whats unopened for one motor can't be opened for another just because its easier to due to its design. But from a literal sense.. A motor is only opened when the head is cracked off/removed. Link to comment https://www.sau.com.au/forums/topic/131841-can-you-still-call-an-engine-unopened-if-you-have-aftermarket-cams/page/2/#findComment-2455259 Share on other sites More sharing options...
Duncan Posted September 3, 2006 Share Posted September 3, 2006 How on earth do you change the bottom end by taking the head off? I think you would be better off trying to remove the sump. Taking the head off gives you access to absolutely nothing Link to comment https://www.sau.com.au/forums/topic/131841-can-you-still-call-an-engine-unopened-if-you-have-aftermarket-cams/page/2/#findComment-2459312 Share on other sites More sharing options...
Abo Bob Posted September 3, 2006 Author Share Posted September 3, 2006 Yeah but you can at least look at the pistons. Link to comment https://www.sau.com.au/forums/topic/131841-can-you-still-call-an-engine-unopened-if-you-have-aftermarket-cams/page/2/#findComment-2460015 Share on other sites More sharing options...
