Abo Bob Posted August 26, 2006 Share Posted August 26, 2006 What kind of power did you get? What transmission? Might as well add what you got once you had a PFC or other engine management in place too if you have it. Thanks. I got 162 with zorst and 12psi. Auto. Link to comment https://www.sau.com.au/forums/topic/131847-did-you-dyno-your-r34-with-zorst-only/ Share on other sites More sharing options...
choyda Posted August 26, 2006 Share Posted August 26, 2006 What dyno was it? On a Dyno logic one, I've seen an R34 GTX-T series 2 get 169rwkw running about 12psi, stock ECU and CES 3" Exhaust (split dumps), auto. A series one auto R34 GT-T with nothing but K&N panel filter, stock boost and an Apexi Cat-back 3" exhaust do 147rwkw. Neither car had front mounts. Mine has more than just exhaust and boost so I won't post mine. Link to comment https://www.sau.com.au/forums/topic/131847-did-you-dyno-your-r34-with-zorst-only/#findComment-2441769 Share on other sites More sharing options...
Bluprint Posted August 26, 2006 Share Posted August 26, 2006 Does just an exhaust & FMIC count in a car with an R34 motor? Link to comment https://www.sau.com.au/forums/topic/131847-did-you-dyno-your-r34-with-zorst-only/#findComment-2441843 Share on other sites More sharing options...
Abo Bob Posted August 27, 2006 Author Share Posted August 27, 2006 sure, what did you get? Link to comment https://www.sau.com.au/forums/topic/131847-did-you-dyno-your-r34-with-zorst-only/#findComment-2441858 Share on other sites More sharing options...
Bluprint Posted August 27, 2006 Share Posted August 27, 2006 (edited) 175.1rwkw with 3" turbo back exhaust & Just Jap 600x300 front mount. Stock boost & computer, manual box. edit - Mine seems a little high going by the above numbers... suppose it just comes down the dyno I suppose.... I'd like to think I have a heathy motor Edited August 27, 2006 by Bluprint Link to comment https://www.sau.com.au/forums/topic/131847-did-you-dyno-your-r34-with-zorst-only/#findComment-2441884 Share on other sites More sharing options...
satanic Posted August 27, 2006 Share Posted August 27, 2006 When I first got my car... Stock Exhaust; Stock Boost; K&N Panel; Auto 154rwkw; those were the boring days! Link to comment https://www.sau.com.au/forums/topic/131847-did-you-dyno-your-r34-with-zorst-only/#findComment-2441894 Share on other sites More sharing options...
Kennedy Posted August 28, 2006 Share Posted August 28, 2006 Mines a 33 but i got 175RWKW with cat back and pod. Standard ECU, boost, IC. Link to comment https://www.sau.com.au/forums/topic/131847-did-you-dyno-your-r34-with-zorst-only/#findComment-2444539 Share on other sites More sharing options...
Andi Posted August 28, 2006 Share Posted August 28, 2006 Wow these are some high figures! I was only hoping to get about 170-180rwkw with turboback exhaust, fmic, 13psi and pod. I just fitted a full exhaust on Sat and I must say the difference is huge. I'll see if I can get a dyno run in for you. Link to comment https://www.sau.com.au/forums/topic/131847-did-you-dyno-your-r34-with-zorst-only/#findComment-2445250 Share on other sites More sharing options...
Kennedy Posted August 28, 2006 Share Posted August 28, 2006 Just put a FMIC and increasing the boost later this week. Hoping to get close to 200 Link to comment https://www.sau.com.au/forums/topic/131847-did-you-dyno-your-r34-with-zorst-only/#findComment-2445301 Share on other sites More sharing options...
666DAN Posted August 31, 2006 Share Posted August 31, 2006 Managed to get 176rwkw with my stock turbo, but the timing was being pulled due to overboost retard. Had I realised exactly what was happeneing at the time would have been able to drop the boost and probably make more power. Link to comment https://www.sau.com.au/forums/topic/131847-did-you-dyno-your-r34-with-zorst-only/#findComment-2452030 Share on other sites More sharing options...
PAV34 Posted August 31, 2006 Share Posted August 31, 2006 (edited) Manual Box 3" Split dump/front, 3" Blitz cat back Pod with heat sheild and standard snorkel Standard ECU Standard IC Stock Boost 2 dyno runs with identical results - 168rwkw Edited August 31, 2006 by PAV34 Link to comment https://www.sau.com.au/forums/topic/131847-did-you-dyno-your-r34-with-zorst-only/#findComment-2452048 Share on other sites More sharing options...
nuffsaid Posted August 31, 2006 Share Posted August 31, 2006 (edited) Manual, 3" split dump and front, 3" cat back, 3" flanged Catco steel cat with 5" body. Stock ECu Stock IC Stock boost Stock everything else haha 163.5rwkw Edited August 31, 2006 by nuffsaid Link to comment https://www.sau.com.au/forums/topic/131847-did-you-dyno-your-r34-with-zorst-only/#findComment-2452718 Share on other sites More sharing options...
satanic Posted August 31, 2006 Share Posted August 31, 2006 My car's going on a dyno tomorrow.... it's pretty much stock; I'll post some results after! Link to comment https://www.sau.com.au/forums/topic/131847-did-you-dyno-your-r34-with-zorst-only/#findComment-2452780 Share on other sites More sharing options...
Sydneykid Posted August 31, 2006 Share Posted August 31, 2006 From memory; 100% stock = 147 rwkw Cat back = 168 rwkw (boost went up 1.5 psi) Split dump and Magic cat = 183 rwkw (boost went up a little bit more, say 1 psi) Standard R32GTR intercooler and my own design of 63 mm pipework = no dyno Power FC, tune and boost up to 10 psi = 205 rwkw GCG Ball bearing High Flow, 1.5 bar boost, tune + injectors = 248 rwkw Tomei Poncams, 1.4 bar + tune = 265 rwkw Cheers Link to comment https://www.sau.com.au/forums/topic/131847-did-you-dyno-your-r34-with-zorst-only/#findComment-2452838 Share on other sites More sharing options...
satanic Posted August 31, 2006 Share Posted August 31, 2006 SK; is your motor stock standard? Link to comment https://www.sau.com.au/forums/topic/131847-did-you-dyno-your-r34-with-zorst-only/#findComment-2452854 Share on other sites More sharing options...
n15m0 Posted August 31, 2006 Share Posted August 31, 2006 What dyno was it? On a Dyno logic one, I've seen an R34 GTX-T series 2 get 169rwkw running about 12psi, stock ECU and CES 3" Exhaust (split dumps), auto. A series one auto R34 GT-T with nothing but K&N panel filter, stock boost and an Apexi Cat-back 3" exhaust do 147rwkw. Neither car had front mounts. Mine has more than just exhaust and boost so I won't post mine. Yeah mine was the one with the Apexi cat back and panel filter pulling 147kw atw from a Dyno Logic dyno at our SAU dyno night. Apparently it was reading lower for everyone that had previously dynoed on a Dyno Dynamics...so as SK predicted...with catback...*should* read somewhere closer to 160 for stock with catback only?? Link to comment https://www.sau.com.au/forums/topic/131847-did-you-dyno-your-r34-with-zorst-only/#findComment-2453110 Share on other sites More sharing options...
n15m0 Posted August 31, 2006 Share Posted August 31, 2006 My car's going on a dyno tomorrow.... it's pretty much stock; I'll post some results after! Your car is far from stock!!! http://satan.p5.org.uk/home.html Link to comment https://www.sau.com.au/forums/topic/131847-did-you-dyno-your-r34-with-zorst-only/#findComment-2453118 Share on other sites More sharing options...
Sydneykid Posted August 31, 2006 Share Posted August 31, 2006 SK; is your motor stock standard? Other that the mods above, I also ported it, then volume matched and polished the combustion chambers. I used a standard headgasket with o'rings around the combustion chambers. That's it for when I had it. I sold it 3 years ago, don't know what been done since. cheers Link to comment https://www.sau.com.au/forums/topic/131847-did-you-dyno-your-r34-with-zorst-only/#findComment-2453128 Share on other sites More sharing options...
satanic Posted September 4, 2006 Share Posted September 4, 2006 Shhh n15m0; my car is stock.... Anyways; got off the dyno on Friday with 225.31rwkw @ 10psi of boost... had a boost leak issue (will post up a proper thread about it later today). Funny thing is that it shoots to 18psi by 4,500rpm - holds till 5,500rpm then slowly drops back to 10psi by 7,200rpm. 1 bar of boost was reached by 3,500rpm. Pulls like a motherF' when the boost kicks in; just not up high New boost controller for me; and maybe some welding! Link to comment https://www.sau.com.au/forums/topic/131847-did-you-dyno-your-r34-with-zorst-only/#findComment-2460361 Share on other sites More sharing options...
R34GT-t_07 Posted September 5, 2006 Share Posted September 5, 2006 R34 GT-t Manuel 3" catback and pod 171.5Kwatw my clutch is slipping tho i asume that mybe it would be a bit higher if cluctch was good. Link to comment https://www.sau.com.au/forums/topic/131847-did-you-dyno-your-r34-with-zorst-only/#findComment-2463525 Share on other sites More sharing options...
