What dyno was it?
On a Dyno logic one, I've seen an R34 GTX-T series 2 get 169rwkw running about 12psi, stock ECU and CES 3" Exhaust (split dumps), auto. A series one auto R34 GT-T with nothing but K&N panel filter, stock boost and an Apexi Cat-back 3" exhaust do 147rwkw. Neither car had front mounts.
Mine has more than just exhaust and boost so I won't post mine.
175.1rwkw with 3" turbo back exhaust & Just Jap 600x300 front mount.
Stock boost & computer, manual box.
edit - Mine seems a little high going by the above numbers... suppose it just comes down the dyno I suppose.... I'd like to think I have a heathy motor :)
Edited by Bluprint
Wow these are some high figures! I was only hoping to get about 170-180rwkw with turboback exhaust, fmic, 13psi and pod.
I just fitted a full exhaust on Sat and I must say the difference is huge. I'll see if I can get a dyno run in for you.
Managed to get 176rwkw with my stock turbo, but the timing was being pulled due to overboost retard. Had I realised exactly what was happeneing at the time would have been able to drop the boost and probably make more power.
Manual Box
3" Split dump/front, 3" Blitz cat back
Pod with heat sheild and standard snorkel
Standard ECU
Standard IC
Stock Boost
2 dyno runs with identical results - 168rwkw
Edited by PAV34
From memory;
100% stock = 147 rwkw
Cat back = 168 rwkw (boost went up 1.5 psi)
Split dump and Magic cat = 183 rwkw (boost went up a little bit more, say 1 psi)
Standard R32GTR intercooler and my own design of 63 mm pipework = no dyno
Power FC, tune and boost up to 10 psi = 205 rwkw
GCG Ball bearing High Flow, 1.5 bar boost, tune + injectors = 248 rwkw
Tomei Poncams, 1.4 bar + tune = 265 rwkw
:) Cheers :laugh:
What dyno was it?
Yeah mine was the one with the Apexi cat back and panel filter pulling 147kw atw from a Dyno Logic dyno at our SAU dyno night. Apparently it was reading lower for everyone that had previously dynoed on a Dyno Dynamics...so as SK predicted...with catback...*should* read somewhere closer to 160 for stock with catback only?? :blink:
SK; is your motor stock standard?
Other that the mods above, I also ported it, then volume matched and polished the combustion chambers. I used a standard headgasket with o'rings around the combustion chambers. That's it for when I had it. I sold it 3 years ago, don't know what been done since.
:blink: cheers :)
Shhh n15m0; my car is stock.... :(
Anyways; got off the dyno on Friday with 225.31rwkw @ 10psi of boost... had a boost leak issue (will post up a proper thread about it later today).
Funny thing is that it shoots to 18psi by 4,500rpm - holds till 5,500rpm then slowly drops back to 10psi by 7,200rpm. 1 bar of boost was reached by 3,500rpm. Pulls like a motherF' when the boost kicks in; just not up high :/
New boost controller for me; and maybe some welding!
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
