SOLD
FOR SALE IS THIS IMMACULATE TWIN HIGH MOUNT BOLT ON KIT FOR A SKYLINE R32 OR R33, COMES COMPLETE WITH
*TWO KKK K26 TURBOS IN IMMACULATE CONDITION WITH NO SHAFT PLAY AT ALL,
*TWO BIG EXTERNAL WASTEGATES WITH SCREAMER PIPES,
*BLITZ MANIFOLD IN TOP CONDITION (PERFECT WELDS NO CRACKS),
*ALL GASKETS REQUIRED FOR INSTALL ARE INCLUDED,
*ALSO INCLUDED IS TWO K&N POD FILTERS WITH PIPES ALREADY PROFESSIONALLY ATTACHED TO TURBO HOUSINGS,
*2 PIECE DUMP PIPE FROM TURBOS TO CAT INCLUDED ALSO
HAS MADE OVER 400KW AT ALL FOUR WHEELS ON ONLY 22PSI WITH MINIMAL MODIFICATIONS IN AN R32
DONE ABOUT 5000KMS SINCE NEW. IN IMMACULATE CONDITION
REASON FOR SALE IS I AM STRIPPING DOWN CAR AND GOING FOR A FULL DRAG SETUP
ITEM IS LOCATED IN SYDNEY AND PICKUP IS PREFERRED HOWEVER, IF REQUIRED. WILL POST AT BUYERS EXPENSE
PM ME OR EMAIL AT [email protected]
https://www.sau.com.au/forums/topic/131860-sold/
  • Replies 46
Posted Images
what turbos are they
when was she on ful boost
and dyno graph please
THEY ARE KKR TURBOS K6 SERIES(THEY HAVE A PLAQUE ON THE FRONT OF THE HOUSING I WILL CHECK TO SEE WHAT SERIES FOR SURE)
NO DYNO SHEET AVAILABLE BUT BY MEMORY FULL BOOST BY 4250RPM.
https://www.sau.com.au/forums/topic/131860-sold/#findComment-2441887
    • Only reason I started replacing hoses was I went for a short drive to the shop the other day and finished shopping and started the car and started to drive off and could see a big trail of fuel in the rear view mirror. Parked up and found the bottom hose to the fuel filter had busted. Lucky I was near a car part store and was able to get a replacement hose and back on the road. But got me thinking I had owned that car for around 20 years and was all original fuel hoses so probably time to replace all of the fuel hoses. Was pretty lucky it went where it did.
    • A few kg falling from a few feet is enough to move parts of your skull inwards into your brain Also, there's always news about people getting crushed, and occasionally killed, working under cars Be safe is your endeavours
    • I was just going to replace the fuel line and keep the stock one, but they do look pretty nice lol.
    • Are you going to delete the stock damper or are you just replacing the fuel lines and keeping the stock damper?  There are also options for sexy ones if the stock one is too ugly for you lol -  https://www.radiumauto.com/Fuel-Pulse-Damper-Inline-Kits-P751.aspx or https://www.radiumauto.com/Fuel-Pulse-Damper-Direct-Mount-Kits-P759.aspx So sexy.
    • I think you guys are right. The only reason I thought it was a restrictor was I had seen the same yellow band on the r32 boost restrictor. Will just replace with a standard fuel hose. Thank you for your speedy replies. I'm sure I'll have many other silly questions.
