  • Replies 183
Posted Images
ok all Long wang vids now posted
(this should be everyone in group 2)
http://www.youtube.com/profile?user=emts42
Good effort, well done. :ermm:
Any chance of grabbing the Evo vid if its not too large please?
Who hosted them last couple of times?
http://sau.tharaka.net/
Ask them nicely ;)
If anyone needs hosting, PM me and I'll send you the FTP details when I get home (don't have them here at work)
There wont be any size or bandwidth restrictions
Saff if you can hold out for a couple of days we'll see if can get some ftp spac, as i've got a couple more of you onj the skid pan and a few from the battles
No worries mate, sent you the email addy anyway.
Thanks dude ;)
What a champ, upload them to darK's site......
al you've ditched the wing now yeah?
if so yeah there's one of you from battle 2
Yep.... Didn't have the wing on that day.
Only use it for track days....................... which to date has been NEVER :sick:, or occationally by popular request :(
Well Folks big thanks to darK, got the FTP last night..
spent an evening uploading..
so here you go all the clips in much better clarity
http://sau.tharaka.net/DECA_Aug26/
Awesome, thanks heaps mate, and thanks to darK for providing the space >_<
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
