Hey ladz,
Today i was mucking around in the engine bay and i was taking a good look at my Apexi BOV... and noticed that it has a red metal band around it that has 3 different size holes in it... i was like why..?
so i touched it and it span around...
Why would my BOV have this feature and what does it do? change the sound of it or what?
i have attatched a couple of pics so you can see what i mean...
Beef
https://www.sau.com.au/forums/topic/131867-apexi-bov-any-ideas/
Ok here is what i think it is after a bit of research.
you can change the diameter of the pressure outlet.... which means you can make it not realease as much boost pressure between gears.. so if you have it on the biggest hole it will relese all the boost pressure when you change gears.. but if you change it to the smallest one it wont be able to get rid of it all thus it will hold boost between gears...
sounds right?
Edited by Beef
I have the exact same BOV as you mate and ive moved the band around thinking it would change the sound but I cant notice any difference at all no matter what setting its on
yeah i really dont think its a sound thing at all... if you think about it... how would it change teh sound anyway?
it is a way of boost holding... it just doesnt release it all between gear changes so that the turbo doesnt have to spool all the way up again....
thast all it is
hello guys... i really searching for my BOV? i can't locate it from the engine...and my twin turbo is really very tight inside....where is the exact location of the BOV? is it the one that sounds when i rev and change gear????? because i wonder why i can't hear anymore the other sound that pssst.....sound....even when the car is not running and just reving it high/????help
it would change the sound in the same way that changing the shape of your mouth can make you whistle.
you'd probably find that on high boost applications it could make a difference.
The adjuster on the Apexi bov is for the PITCH of sound it makes..
The size of the hole will ALTER the PITCH of the sound it makes.
It doesn’t hold boost in or have anything to do with boost.
Just the sound it makes on release..
Small hole means slightly less sound and it a little more high pitched.
Larger holes make more sound and not as high pitched.
Stock GTR bovs are on the drivers side of the car.
Follow piping from intercooler up to engine bay on drivers side.
thast all it is
The red collar is for sound adjustment, and the screw on the top of the BOV is for spring tension adjustment.
when to know if i have a BOV installed??? what will happen if i don't have BOV installed in my car??? do you have a yahoo messenger mad??? can u add me [email protected] thanx
If you dont have a BOV installed you will get the 'flutter' noise from compressor surge.
UM NO... i have tried it on all different settings on full and half boost and there is NO change in sound.. however.. there is a difference in LENGTH of the release sound... but NOT PITCH of sound.. the below is an exerpt from the Apexi USA SITE:
"The blow off valve is also adjustable to allow desired amounts of boost response between shifts"
So there it is... it is adjustable to control the level of boost released between shifts.. NOT SOUND
IT IS BOOST CONTROLLING....
:dry:
