post-30191-1156663134.jpgpost-30191-1156663105.jpgpost-30191-1156663063.jpgpost-30191-1156662469.jpgpost-30191-1156662353.jpgpost-13939-1127450385.jpgpost-30191-1156662123.jpg424]Item: rb25de r32 4 door skyline
Website:
Item Condition: good apart from dent in bonnet and paint run i think on the right quarter pannel damage has been shown in pictures
Reason for Selling: want a change
Price and Payment Conditions: $6800 or possibly trade
Extra Info: the car was bought as a turbo rb20 but was changed because of the new p plate restriction I still have the rb20 engine in perfect running order and will be included in the sale along with the turbo computer and wiring harness. The car still has turbo gearbox and drivetrain and an exedy heavy duty clutch this makes it alot strongr then a normal non turbo.
The car has also been changed to the black interior in the 2 door r32's.
has 16inch s15 silvia wheels with good tread all four with no scratches other 2 are included just not on the car when photos were taken, brand new king springs have just been fitted aswell
the car has also just been re registered so it has 12 months rego on it.
This car would have to be one of the cheapest r32 4 door whether you want it turbo or non turbo these engine with air flow meter wiring harness and ecu still sell for around the $1200 mark so even if the car was to be left non turbo it would make it really cheap to the lucky buyer .
mods for the non turbo rb25 currently in the car are k&n pod filter timing slightly bumped up and 3 inch exhaust with a big cannon but yet the car is relatively quiet the non turbo engine has also got vct.
Pictures: yes
Contact Details: 0408618080
https://www.sau.com.au/forums/topic/131893-r32-4-door-skyline/
  • 4 weeks later...
dude answer your phone mate.
ive rung you many times with no luck. if you want your car to sell then reply to PMs, reply to this thread and/or answer your damn phone!
Edited by whyte
    • So, it's clearly an electrical problem. Either with the gauge itself, or the sender. It appears to be voltage sensitive (ie, alternator output affects the reading.
    • Yes, at this stage of SAU threads, I  automatically assume that anyone here knows that everything depends on each and every setup and its choice of parts and what an individual wants from the setup. I think your misunderstanding what I've said, I'm not saying your curve will move to the right.. I'm stating the opposite; that my setup has a much larger turbo than my last one, my current exhaust manifold runners are 2-3x longer than the last one, the intercooler is longer and thicker (hks 103mm thick), the itbs are now oversized from 45mm up to 49mm, and the plenum is now a larger Nismo plenum that's been port matched. As a result, I'm making more power, torque and boost 1000rpm earlier than my last setup. My curve moved left, in a big way. You guys with 800-1000+hp turbos should be considering hks v-cam or the other Japanese company Sakura who makes RB25 Neo vct adaptor kits for RB26's. they all make more power / boost / torque far earlier and higher peak numbers. Dahtone Racing modifies the Hks v-cam systems to his own specs and he also developed the worlds first and best dbw individual throttle body kits, to complement his V-cam. Every single car is 800-1200+hp and they all produce huge gains in response and peak power.
    • I have a 2008 Skyline 370gt with about 160,000 km on the clock currently. A while ago, I noticed the temp gauge would start climbing but it comes down when I give it some throttle. I took it into the shops. The technicians comments are transcripted below. Reported they couldn't find anything wrong with the vehicle mechanically and they pressure tested the cooling system. Funnily enough, the technician commented that the temperature dropped back down when the car is stationary but this is when I'd notice the temp gauge to be climbing. Just wondering if anyone else experienced anything similar to enlighten me? Cos at the onset, the temps were going up one tick and then comes back down when I step on it. Now, the temps are climbing all the way to the top of the gauge, and it's making me very nervous lol. It also doesn't come down to the neutral position anymore. PS I do have a small exhaust leak near the drivers side caused by when I got f**ked by a really steep driveway at a mall I never visited before. Not sure if this would affect the sensor. Technician comments: Check and verify Fan/Cooling system - ALL OK max 106*C and fans operating at 100% Cools down right away. Checked Fan Operation - 55%@101*C, 85% @ 104*C and 100% @ 105*C Vehicle did not exceed these temperatures with max load. Temperature recovered back to 99*C after fan operation while vehicle Stationary.
    • It really depends on your setup. Mine is 'accidently' more suited to revving higher. bigger cams, turbo etc. Plus my super long first takes donkey years to come onto boost, so if it will move my power band to the right, maybe i'll pass on this. i have a G45-1500 going on there soon which I suspect might make it more of a fat pig.
    • Yeah good call, I will endeavour to tuck that down when I rewrap the looms it’s pushed up by
