How does one know that the gearbox is nearing or at the end of its service life? What are tell take signs?
i) The car will give a slight jolt when changing gear?
ii) Sometimes a gear is "hold" for a good few seconds before engaging a higher gear (noticed RPM is also higher when this happens)?
These are the symptoms that I experience with my A31 currently. Your thoughts and experience will be greatly appreciated.
Almost missed out the most important information. I'm driving a 1991 A31 Auto transmission, with a RB20DET swap.
Thanks.
CT.
https://www.sau.com.au/forums/topic/131903-gearbox-problem/
Thanks Simon. Your input is much appreciated.
To add on to the symptoms that I had, here's the latest... this morning when I arrived at the office, and while trying to park the car, I put the transmission at "R"... press the accelerator.. and the car didn't move!
I suspect I need to replace the torque converter. Any thoughts?? Is there a doctor (mechanic) in the house??
CT.
https://www.sau.com.au/forums/topic/131903-gearbox-problem/#findComment-2455983
CT.
Dont want to sound cruel but have you checked your fluid levels. Auto gearboxes play up heaps when they are down on fluid... Most importantly though get a service done, they will change fluid etc. Most problems you explain would be fixed by service..
https://www.sau.com.au/forums/topic/131903-gearbox-problem/#findComment-2478716
