I've heard a fair bit of talk about hollowing out/punching out the CAT in the hope of gaining some power. Now to me this sounds highly illegal given emission laws but I'd think it'd be hard to tell if done right? Has anyone done this themselves, if so what process, did you open the cat or remove the insides through the holes, did you gain any power? What are the risks etc etc.
Cheers
https://www.sau.com.au/forums/topic/131904-hollowpunched-out-cat/
  • Replies 74
if you tap it with a spanner or something solid it will ting if its empty
so its pretty easy to tell if its been gutted
also youll have black crap on the rear bar where the muffler comes out
obvious signs of a gutted cut or "hi flow" special cat
Woah, that's steep... How would they know though? I was under the impression that it would look stock from the outside and if you get told to go do an emissions check you'd just replace it with a stock one?
i was thinking of the same thing for a while. then common sense hit in and i bought a hi flow. $360 vs $9k. i think it speaks for itself. from what ive been told u just crack it open at the welt joints gut it and weld it back up. if you can get a straight through pipe and then weld a 3" cat cover over it you will get more out of it.
yeh gutted standard one would flow better, but a hi flow one couldnt be much worse, considering larger size in and exit pipes (not adapted from 2 " to 3", and far better flow design.
Although you could always say youve never had it off and i cant see hoe they could prove it wasnt the last owner
someones a hippy.
Perhaps spend a few hundred bux and just buy a 4" cat and put that in instead, the extra size surely wouldnt restrict a 3" system. But i admit having cool flames from the sil80 when it was minus a cat was cool fun when doing mountain runs haha.
I believe they measure the temp before the cat and than after the cat, there should be a drop as it passes through.. also - it'll flame on backfire..
It's not worth it, there is other things you can do to get power that doesn't cost you $10k in fines..
You don't have too be a hippy at all too have a little respect.
Seriously, its generally accepted that not having a cat/gutting your gut with net you about 3-4rwkw - Really worth it.
Now......Time too pour my excess race fuel into Waragamba Dam.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
