hey guys
I recently installed a set of 6" MTX 6001 (90RMS) speakers in the rear parcel shelf. They are being run off a kicker amp so i believe they have enough power, but if i start to turn up the volume it sounds like there is interferance with the signal as if i was listening to a radio station that wasnt correctly tuned in? I tried playing with the treb, bass and gain on the headunit and amp but with no luck. Any one had this drama or have any suggestions?
cheers luke
https://www.sau.com.au/forums/topic/131909-distortioninterference-prob-r33/
Sounds like you are having the famous "alternator whine" problem which is experienced by many a Skyline owner. Does this "interference" increase in loudness with the revs of your engine?
Not really its only when i trun up the volume that i start to hear the interference. I did however here the engine idle come over the speakers when i was sitting at the lights. But its not the sort of distortion that you would associate with crappy speakers that are being put to the limit but like i stated, more like when the radio station isnt tuned in properly.
Ah yeah. I have both. The hazy static noise went away when I turned my gains down on the amp though.
The whine is still there, and there's just about nothing I can do to get rid of it.
I found a blown ground wire for the RCA's in my head unit, repaired that, tested with a multimeter, reinstalled, but it's still there. If I unplug the front set of RCA's, it goes away. Changed cables, swapped front and rear, changed amp. It won't go. Pretty sure it's my headunit that's at fault.
So. Turn down your gain. ALL THE WAY down. Then crank your headunit and see if the static is there.
Yeah, from what i've read, if everything else has been done correctly, then the only other thing that causes the static and whine is a bad RCA earth.
Either you've killed the earth in the amp, or in the HU. It's hard to find out without borrowing someone else's stuff.
I'm quite sure my HU is the problem. It had a burt track in the HU, and the amp has changed to a different new unit.
yeh im going to borrow a amp this weekend and see if it fixes the prob, and ill write up my results
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to moth things around tbh, but they are all from the same log and the line crosses at the same point for all of them
    • It's about time I start work on my sun tan. So I knocked up a few parts that will all combine together to become my new power steering reservoir. Now just to produce an abundance of UV and IR rays while melting a heap of bits of alu to become one... Well, that's after I put one more hole in it for the return line to plumb to. It likely won't be this weekend, as Sunday I'm meant to be in doing some last minute stuff to the AMG race car, and the weekend after will be filled with non my Skyline stuff, followed by Bathurst 6 hour. So I don't expect to get to melt metal for at least 3 weeks.   I also managed to stuff up and start cutting the hole for the res to pump pipe on the wrong side of the line... It means instead of the lines being nice and tight against the inner guard, they'll be out off the guard.    The size of it means I should end up with about 1.8L of power steering fluid, and still have space for another half a litre before it reaches the overflow/breather. This is wayyyyyyy more capacity than factory, which should help keep Powersteer oil temps lower, and the design hopefully allows it to prevent any aerated oil being able to makes its way down to the bottom as it'll have a couple of baffles and some hopeful trickery to force air bubbles away from the bottom.
    • The log you did with ECU voltage, can you log the other things too like rpm and oil pressure? Need all that info together to compare easily
    • Editting as I hit post to soon, and this will lock out otherwise.
    • Think ill be going hunting for bad earths and might just replace the alternator for shits n gigs as its an LS alternator but only about 5 years old with very minimal use in that 5 years.
