HI ALL
Well i finally got arround to fitting my FLYEN dump pipe, the bellmouth one. I have new gasket on the turbo to dump, but old ones on the cat.
Now for two days it was fine, but now, when you start it, it almost sounds like there is an exhaust leak somwhere, but inside the pipe, does it when warm too.
I have gone through all the bolts, all nice and tight, cheacked for leaks, can't feel anything, anywere. turbo, cat, manifold, all good.
The car still pulls like it did, no loss of power or anything.
You can't seam to hear it directy outside but more inside, like inside the pipe. I am thinking that now that the O2 sensor is more in the flow of the turbo, maybe that is making the sound.
I am going to get new gaskets for the cat, and put them in, just to make sure. But has anyone else had a simmilar problem to this?
ANYONE?
nope no high temp sealer between the dump and the turbo, no need, i got a genuine copper gasket, and was told not to use any, nobody i know has, and it is definatly not leaking from there, tripple checked now.
I got new gaskets for the cat, as they are the ones i have not changed, so i will replace these tommorrow night and see where from there.
It is like a leaking noise, but it is inside the pipe. BUT i do not notice any performance loss at all.
ANy other ideas?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
