Hi guys someone here told me this oil which is used for diesel engines is good to clean out the engine. any comments? also how long do I use it for?? is it safe? was told to do it as it would be cheaper than my other alternative running redline motor oil. Just want to get rid of a annoying ticking sound which i believe is the lifter.
https://www.sau.com.au/forums/topic/131934-mobile-delvac-1-5w40/
the only problem with cleaning the motor out is that you can end up with oil leaks. if you engine has a thin layer of crap through it, it may be covering slight cracks or places it can leak out. if you then clean all that crap out the oil can get to those areas. also you run the risk of some of the crap moving from where it was, and ending up somewhere it can do damage.
    • There was a thread on here when it was set up for the Bathurst 12/24 hour race a while ago then went to giant then to Jason’s who I bought it off   has some cool shit and is old school cool
    • I would call it the "manifold coolant outlet" or something like that.  If you know the dimensions you can just get a bit of mild steel (or stainless) pipe that is the correct size, bead roll a hose retaining lip into the end of it and bash it in! Or, get fancy-  https://boostdoc.com.au/products/rb25-neo-billet-top-hose-outlets?srsltid=AfmBOopjNetVaMphRC0x44Er2jwO2k5vPp-4AGG5Bd285Ah0SsXXGk3e
    • True....I've not done a bearing in a borrowed car yet, but I've sure as hell killed a clutch in one   What's the car's history? Looks like a fair bit done to it already
    • For $2m you could grab Brockys sons daily driver AND a R34 GTR VSpec
    • Help! Can anyone tell me what this part is called? Mines a rusted mess as you can see in attached photo and I'm struggling to find a replacement for it anywhere because I simply don't know what to search up. It's on my intake manifold and I believe the top radiator hose attaches to it. If anyone also knows where to buy one from that information would be greatly appreciated aswell 😊
