For camber you need the upper wishbone in adjustable form, the one pictured there i believe comes from the front-centre of the subframe and goes to the hub. You need the adjustable piece that goes from the centre-inside to the hub and around your shockabsorber up top to screw in/out rear camber.
What you need for camber adjustment.
Hope that makes sense :)
Edited by r33_racer
To be honest mate i have no accurate answer for that.
My guestimate would be they are some form of rear castor arms. But what they actually do or help do is beyond me. As far as i know on the rear you only have: camber, toe in/out i dont believe there is a rear castor.
Maybe its a drag racing thing or drift thing....maybe its a wank! Maybe someone with more knowledge then me may answer that one :P
R32/33/34 's have 2 upper rear control arms, both control camber.
One arm is parrallel to the drive shafts, the red R32 arm in the post above
(Note that the R33/34 arm is only one sided, not a complete loop)
The other arm is at a 45 degree angle to the drive shaft, the blue one in the post above.
To properly correct the camber you need both arms.
That's why the Whiteline rear camber kit comes with adjustable bushes for both arms.
In the following picture of R34GTR rear suspension, you can see the 2 upper arms. The inner pivots points (where the Whiteline camber bushes go) are marked with the 4 yellow dots.
:happy: cheers :)
  • 1 month later...
Diggin up an old thread :P but why do people call this (the one on the first post) the 3rd arm, traction arm? that and quote " can be setup for drift or grip"
If you have the camber arm adjustable aftermarket, is there any need to get the other? would have them both adjustable be better?
Cheers
i was visiting a a mate the other day who said i could buy the arm in the first pic realy cheap as he had brought it then decided to get the hole set with both the upper links and the forward facing traction rods.
i now see why just jap sell it all in a pack as i like many others has been miss led that you only need second one pictured.
Diggin up an old thread :( but why do people call this (the one on the first post) the 3rd arm, traction arm? that and quote " can be setup for drift or grip"
Cheers
If you only use the upper control arm to adjust camber you will get severe distortion of the traction rod and lowr control arm bushes and they (all 8 of them) will wear out very fast. Plus your wheel aligner will find it very difficult to get the toe settings correct. Worst of all you will end up with bulk bump steer.
Traction rods make no difference to the rear subframe alignment which is what is required to give the adjustment of squat for traction or drift. A rear subframe alignment kit is what is required for that.
D cheers :D
Edited by Sydneykid
D cheers ;)
Ok - so what dose one use for added traction in a drag scenario?
And whilst i have your attention , who knows the best place to get some et ot Goodyear drag slicks new or used - i cant seem to find any one who has them in stock ?
corect me if im wrong but the skyline multi link rear end is clasified as a "double a arm",virtual upper a arm"
to get the right amound of angle change there pivot points are seperat.(bit hard to have one moumt where the wheel is mean to be lol. but they are one arm in motion.
so you need to do both for corect arm geometry. other wise it will be like one side of the virtually both being twisted as it goes up and down.
hope that makes some sense.
    • Yes, while being... strictly unnecessary. Tuning is a bit like quantum physics. You don't need to understand what Schroedinger's equation actually means. You just need to run the computation and accept the answers. With tuning, you just push page up/down until the exhaust tells you that you've got the fuel right. The VE can stay hidden behind the curtain like the Wizard of Oz and you'll never need to know what he looked like.
    • The second part yes, the first part about easy VE calculation is something I've seen a few people talk about online.
    • You 100% could do that, would save money on a gym membership lol. But yeah, getting a cordless orbital sander will feel priceless coming from doing it manually.  Good luck with it mate
    • I initially was going to do the whole car with a block then realised, it would be a bigger monster of the job 😂 I guess that's all part of the learning process. I appreciate all that advice, I think I got a good idea on how to tackle this whole job.
    • I admire your efforts with the scuff pad.  As a mere mortal, I use this for the baulk of my sanding work- https://sydneytools.com.au/product/milwaukee-m18bos125-0-18v-li-ion-cordless-125mm-5-random-orbital-sander-skin-only Yes you can easily create a low spot while sanding. There are 2 types of filler, 1 part of 2 part. The 2 part filler will get used for large corrections and the 1 part filler will get used for pin holes and areas that only need slight filling.  Depending on how zealous you are with the sander (very easy to do with a power tool) or if you are chasing rust etc, yes those low spots will need to get filled or you will end up with a very obvious defects in the paint.  Using the guide coat and large sanding block, high and low areas will be revealed (watch youtube videos for a good visual on this). Its up to you if you think its worth the effort to make the car completely flat before you spray it (you make it flat by filling the low areas).  At the end of the day, it comes down to time. The end result comes from the level of prep put in to the car. If you want a perfect result, you have to put in the time during the prep stage or else it will be impossible to achieve a perfect result during the spraying process.
