Which Wheels
Jaker34
 Share
hey guys tryin to choose between 2 sets of wheels
the first is Gmax M190 which the pic doesnt show but they have major dish on them and i like the multi spoke, i have seen a set of them at my local tyre place
and the second are more of a drift style wheel but with mega dish so let me know what u think, i leanin towards the M190 coz they are a little more classy thent he drift style
anyway let me know what u think its for my new R34 coupe
jake
Ok I see your car is white....well I reckon you should dice those 2 you selected and go stealth.
Try the apache wheels from TRYDIS' suggested website...www.stgeorgetyres.com.au
I did a kwik 2 minute cut and paste for ya...wheel angles aren't right but it gives you a good indication anyway.
The gold version aint bad either!!
like i said give us a yell and i'll try hook sau members up. its all good in TRYDIS's Hood
Drifters use so many different types of wheels on their cars, how can you classify a single style of wheel as being 'drift style'? Just like the 'drift wing'? Whatever....
For what it's worth, although the mesh would be harder to clean as has already been mentioned, they do look classier. Just promise that the offsets are suitable for RWD cars... :happy:
I dig those.
just out of general interest, what colour rims do you guys think would suit a gunmetal grey R33?
I was leaning towards some charcoal or black rims with polished lip?
like mine?? i should be getting them fitted today 18" 265/35 on the rear and 245/35 on the front
yeah im gunna go with the m190s
they have a big dish on em 2 so i think it will look hot as, i was thinkin of goin gold but the only ones i like are the speedy one with the gold centre and crhome lip, but because of the way they are made the rear brakes wont fit in 18s so id have to get 19s and they are 550 just for a wheels each.
so fark that, but with gmax 190s, he has an over stock, so he'll do em heap as and he also sponsered me in last years auto salon with my astra SRI turbs, so i know him pritty well,
anyway thnks for your help guys
i just got a new set of wheels and tyres last week and need some advice.
235/40/R18 front
265/35/R18 rear
does it matter if the overall diameter of the front and rear tyres are different, i'm still on stock standard suspension. i'm worried that the difference in diameter will affect the drive and the height of the car.
cheers
235/40/R18 front
265/35/R18 rear
cheers
and your speedomoter readout, and your takeoff speed, and general efficiency
From the tyre calculator: 235/40 goes best with 265/35 as there is minimal diameter difference. Not sure in other states but in QLD overall diameter difference must not be more than 15mm.
Speedo does go out but very minimally for the below combos.
Stock Tire - 225/45R17 >Search Tires Tire 1 - 235/40R18 >Search Tires Tire 2 - 265/35R18 >Search Tires
Rim Diameter: 17 in 431.8 mm
Rim Diameter: 18 in 457.2 mm
Overall Diameter: 24.97 in 634.23 mm
Overall Diameter: 25.40 in 645.16 mm
Overall Diameter: 25.30 in 642.62 mm
Actual Speed: 60 mph 100 km/h
Speedometer1: 58.9 mph 98.3 km/h
Speedometer1: 59.2 mph 98.7 km/h
Speedometer Difference: - Speedometer Difference: 1.722% too slow Speedometer Difference: 1.313% too slow
Diameter Difference: - Diameter Difference: 1.7% Diameter Difference: 1.31%
235/40/R18 front
265/35/R18 rear
cheers
It dosen't really matter on a rear wheel only drive car but it does depend moreso on the series of tyre you are using on the rear in comparison to what you had on the car before you got the 18s.
I first had 255/45/17 on the rears of the car then I went to 245/35/19 and it was the worst mistake I ever made plus the speedo was about 4-6 km/h out.
Now I've gone back to 17s and the ride is much better once again.
 Share
    • So next year I am looking at upgrading from my VE SS bomadore ute to something more refined.  I wanted to stick with a V8 but not anything German or Australian, either a coupe or a sedan. So if I wanted anything newish that limited my options to either the Lexus RCF which I quite like. But with the price they demand and a kid on the way a 2 door coupe is probably not going to be the best idea. The next best thing would be the ISF but the newest models are 2014 and commanding over 60k and even the older 2008 models in ok condition starting around 35k is kind of bullshit. So I figured if I could not have the noise I could perhaps make do with easy power. Enter the infinity Q50 or Skyline equivalent. The price difference between the 300 and 400hp models seems a bit crazy. Right now there is 300hp Q50 one on carsales from a dealer with 61km for 27k drive away. If I wanted to get a 400hp Red or 400R car the prices seem to start at 43k From my limited research it seems that the only differences are that the 400r/Red Red runs more boost and a more aggressive tune. There are are turbine speed sensors on the turbos. Has 2 pumps for the water to air intercooler. Runs an engine oil cooler. I'm guessing that the exterior trims might look a little more sporty as well. I had a lazy look for upgrades to bridge the gap on z1motorsports They have kits that upgrade the water to air heat exchanger as well as the coolant pump which should give a non Red/400r better intercooling temps than the stock Red/400r. I added an engine oil cooler with a thermostat as well to try and make things as close as possible. Obviously the ECU is going to need a tickle. Having not done much in the way of research they also sell a ECU flashing tool with pre loaded tunes that are supposed to boost the non Red/400R by 100hp which adds 1k USD to the cost. The total cost of the parts @ the current time including shipping and taxes worked out to be $4350 AUD. Personally I would rather get the car tuned on a dyno which would probably add more cost Assuming the worst that you got a workshop to install the new parts I would guess no more than 5 hours would be required in the worst case @ 5 x $150 per hour = $750 So the total cost could be around $5100 So for easy number 5k + 27K = 32k I guess that would leave some change left over to swap out the open diff and fit a LSD Any thoughts?
    • Right, not sure why I thought it to be a lean spike. It might be fixable with modern card-style hot film MAFs which have some design features to avoid counting reversion flow but I've never tried it myself.
    • I did not realise this, I'll contribute more and earn my stripes and retry later.
    • I'm only going to hassle you for posting links to images. It's against my policy to click links that could be some nasty payload. Sadly, you need to make 9 more posts before you can just stick the images directly in a post, unless @PranK sees this and bends the rule for you.
    • Hello,new to the group, I bought a R32 from auction recently, wondering if anyone knows the cars history, seems to have the usual go fast bits on it, plan is to do an engine swap- add 2 extra cylinders and 1 extra turbo. https://www.dropbox.com/scl/fi/i4rjmlzubjbwjtguh6f4s/IMG20241011140744.jpg?rlkey=q0lumm251377vknbqktfwrycq&st=7scvwx4e&dl=0 https://www.dropbox.com/scl/fi/ro24qmwzlczzlfsr4y05x/Screenshot_2024-10-10-10-49-23-90_9a2f5bb2149dae94cd1e190effc09b33.jpg?rlkey=oyguh26ttshlf04ccp48odf4v&st=xloae97b&dl=0   New to forums and posting pics, if links don't work, take it easy on me, 42yrs old and I tune carburettors!!
