there are 3 things you have to take into consideration.
1. do you want to end up with 2 dents in the boot from the wing pushing down when driving at speed for a while (like on the highway). it depends on what angle you have the wing on too.
2. will it protrude past the side of the car.
3. do you want to add something to the car which is going to get you pulled over more, especially if it protrudes past the side of the car. also if the legs and end caps are too skinny you will get booked for that too.
https://www.sau.com.au/forums/topic/131968-rear-wing/#findComment-2443815
my opinion is yes it is a good buy but do take into consideration what mad082 said unless ur askin to be defected and pulled over every corner u turn. :) apart from that its a fat wing :happy:
https://www.sau.com.au/forums/topic/131968-rear-wing/#findComment-2443868
OK, that Ok, I just needed to know if I could dock say 70mm off each side of this wing and then mould the inner end cap back in place so I can screw/bolt the end plate on to it. From what you said [once I shag around and find the supplys I'll need] its no big deal. All my amateur efforts will be inside the wing and covered by the end plate, so should be OK. And if all elso fails I can take it to a cf shop and let them do it..........lol
https://www.sau.com.au/forums/topic/131968-rear-wing/#findComment-2444159
