hehehe don't worry I'm about to hit 120,000 kays..
still trying to decide whether to sell and get a newer model/lower kays....or spend a bit of money (since I've basicly spent nothing so far, except for servicing etc)....yes, emotional attachment sucks :P
https://www.sau.com.au/forums/topic/1320-kays/#findComment-26391
These cars seem pretty reliable as the kays climb. I've seen plenty of turbo Skylines over 120,000 km. Some things wear out like suspension, fuel pumps etc but they are not major things like engines! I think if they are kept serviced with regular oil changes then they should last years.
My old R32 GTS-t was a bit crook towards the end (126,000) only because I fed it 91 octane all the time. My current R33 is going strong and about to hit 85,000...got it at 35,000 (I learned and now only feed it >95 fuel)
Over here in NZ, Brenhan has a GTS-t that is still doing hard service at 200,000 km+, and Kai's GT-R (which has had more drag meets than I've had beers) finally got a new engine at approx 160,000 km.
My sister's Ciefiro (RB20E) still runs sweet as a nut at 180,000km.
Counter this with my last v8, needed a rebuild at 130,000km...and the one before that was rebuilt 3 times over it's 260,000 life (I hear it's still registered)
https://www.sau.com.au/forums/topic/1320-kays/#findComment-26414
    • Does that price include the rack time to straighten the frame and body and replacement of parts and paint, as well as the noise and emmisions testing  The last engineering certificate I had done, albeit about 15 years ago, was around $1000 for a few inspections and the certificate
    • 😂 thanks guys. The diagram i had did not have the breather on it at all. Much appreciated.
    • Geez, engineers fees have definitely gone up. Mine back 2007 cost me all of $300. Mind you, I had to go back to him a few times to get him to write the correct things on the report after he'd inspected it. Things like wrong exhaust size, wrong wheel sizes, etc etc.
    • Can we see a scan of the original quote? The problem with engineers (and by this, I mean, all engineers across all engineering industries) is that there are "engineers" and there are "engineers" (you'll have to imagine the two different vocal emphases on those two versions of the same word. Engineering is a mindset - your farm kid who spent his life rebuilding the tractor will likely make a good engineer. The farm kid who spent his life taking photos of butterflies.. perhaps not. But on top of that mindset, the modern engineer has to learn how to write so that there is absolutely no way of being misunderstood. Proposals/budget estimates/quotations are one place where this is absolutely vital. You have to delineate your scope of supply with extremely hard boundaries, and anywhere where there is any possibility of not being able to have such a hard boundary, you need to write language that will cover you from scope creep, cost overruns, the inevitable interference of the client or their "engineer", etc etc. Now, if your clients are the BHPs and the Rio Tintos of the world, and similar, then you get good at this. If you are an automotive engineer, pitching work to the great unwashed masses, your skills in this area might not be well developed, because you're only dealing with knuckle draggers trying to get a big block legal in a Torana. And when I say "might not"....I'd suggest there's a better than even chance that any such skills might be completely absent. So, we might be able to look at your quote and see what the opportunities are for rebuttal.
