RBFIRE I wasn't really sure what you meant originally....but like dangerous_daveo said the quickest way to brake is when the tyres are just about to lock up, not after they just have.
You need to practice the feeling of how much braking the car can take on each surface so you know how hard you can brake, and if the tyres lock you need to back off the braking a little until they regain grip.
And if you want more info try googling "cadence braking".
Or if you don't want to learn the technique buy a car with ABS....but learning a new driving skill is a better idea
Seems to me you're not feeling the pedal correctly - maybe invest in a set of front braided brake lines to take the spongyness out of the pedal feel, definately get your shock absorbers (all 4) checked and possible replaced, check all the brake pads and discs for abnormal wear, and possibly invest in new suspn mount bushes etc, oh............and listen to the advice below, : :yes:
ok so try a new braking technique. just slamming the brakes on will lock up your wheels. if you can train yourself to ease the brakes on a bit slow, brush the brakes a lil bit so the nose of your car dips down, THEN push the brake in. That way you are giving the car time to shift weight to the front before you apply full pressure.
Im talking like a split second brush before you bury the pedal. Shifting the weight to the front will allow you to put more pressure on the brakes, as your tyres will be biting down into the tarmac more. If you just slam the brakes on while cruising or jump straight from the accellerator to the brake, there isnt enough weight on the front to stop the tyres from breaking traction, cos its all either centered, or at the rear. Move the vehicles weight onto the front, then bury that pedal.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
    • Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank.
