Hey gents and lady.
Getting my handbrake shoes changed tomoz and just wondering what they interchange with ?
I have a rear disk for normal brakes and drum for handbrake. Also car was NA from factory so I thought perhaps NA S13 ?
Any input would be greeeeat! Thanks :P
https://www.sau.com.au/forums/topic/132015-handbrake-shoes/
s13's dont have drum handbrakes so that rule's that out. I'd be looking at s14's or r32's or something... but pull yours out and find something that matches them.
have you done urs? i remember something about you wanting to tighten the handbrake so thought you might have done them.
Im thinking R32 atm :S
https://www.sau.com.au/forums/topic/132015-handbrake-shoes/#findComment-2445253
here is a pic of them installed (obviously without the disc on)
Turns out the shoes were ok but they were out of alignment and weren't grabbing the drum properly.
Had to get the rear pads replaced after been told by another place on saturday that they were fine.
Grrr
Also, do you notice a difference with the uras ones ?
https://www.sau.com.au/forums/topic/132015-handbrake-shoes/#findComment-2447646
well... i bought the URAS brake shoes... they're the same as 32 and most other drum applications...
I have to ask is there anything you can do with the uras ones you can't do with stockies or is the marketable factors of uras ones that they last longer or something?
https://www.sau.com.au/forums/topic/132015-handbrake-shoes/#findComment-2451161
s14 is disc handbrake... just like sils
r32/r33 are the same
uras ones would be good for supposed performance enhancement
so is this true for the s14 disc brake ? Do they bolt on to the rear of the ceffy? direct replacement?...and are they twin piston likie the 32s and 33s?
thanks ...sorry for going off topic a bit
https://www.sau.com.au/forums/topic/132015-handbrake-shoes/#findComment-2453098
direct replacement
modify handbrake cables and thats it...
single piston s14/s15... not twin like 32/33
https://www.sau.com.au/forums/topic/132015-handbrake-shoes/#findComment-2453553
to me it looks the same... put it this way - it wont be a downgrade... youll have 5 stud and larger rotors
the other thing you can do
use the s14 stub axles and hubs... then get 32/33 rear rotors... and use something that runs disc handbrake that isnt single pot caliper...
OR just use your standard stub axles - use 32 hubs... you get to keep your drum handbrake setup... and use 32/33 rotors n calipers (what ive done)
direct bolt on! less muckin
https://www.sau.com.au/forums/topic/132015-handbrake-shoes/#findComment-2457034
yea well at the moment i am staying 4 stud .........i already have wheels(which are awesomeand 4 stud)...yeas i could sell and go through all that agin but i really cant be bothered ....its cheaper to stay 4 stud at this point in time ...thats why i was just talking about callipers not hubs ...........in the end i may go 5 stud but ............but its just going to be a pain in the arse now ....
https://www.sau.com.au/forums/topic/132015-handbrake-shoes/#findComment-2457890
    • Jump into the wasteland. Plenty of random posting/chatting going on in there.
    • I did not go to GTR Festival. It's quite a long drive and the car wasn't dialed in yet. I also wanted to see how the racing portion went before going. From what I can tell the classes were not heads up, index, or bracket - just whoever has the quickest ET wins. Never heard of that sort of thing before and maybe some people like it but it's not my cup of tea. I don't suspect I'll go if that is how the racing is done. I did get the car out three times and had issues each time. Some were my error - haven't raced the car in over two years - and others were parts. Had trouble getting the clutch to slip correctly and remembering how it was set up in the Haltech. Broke some drivetrain parts as well that couldn't be fixed in a couple days to get back out. Season definitely didn't end the way I wanted but at least the bearings are still fine! Not a fleck of material in the filter. Really hoping next year is the year I can actually test this car properly.
    • find it funny everyone claims different fuel chains, do different things with their fuel blah blah blah. We don't have that many fuel terminals in Australia. The fuel tanker trucks drive into the terminal, fill up, and drive directly to the service station and dump out. The majority of fuel you get, is coming out of the same terminals. The variation is actually at the individual service stations and how good their tanks are, as well as how much turn over they actually have. Older fuel stations, that haven't had their tanks replaced are going to end up with the worst fuel. Also a lot of older stations have shit design, and shit maintenance, and end up with more water absorption into the tank. This is when you then get a bad batch of fuel. Other shit things happen, like tanker drivers have a f**k up, and starting to unload the wrong compartment on their truck into the wrong tank.
    • Yeah go with that one
    • This one?? In other news: I cannot tell the difference between my red MX5 with the silver grey hard top......... and the Ferrari 599XX EVO, they might as well be twins, well.......apart from the big wang hanging off the back of the Ferrari...🤔🤣, without the wing they are identical
