My Hazard Lights Aren't Working...........
Soooo... the hazard button is on, so that your indicators even work while you drive?
And do your indicators go off when the button is OFF, but the door is open?
Sounds like some incorrect wiring man. Should never need to have the hazard button on for your indicators to work!
Guest IH8VEE8S
well, all blinkers blink when a door is open, it's quite annoying.
when i unpush the hazard lights button, i can't signal :laugh:
so yeah it's always on (otherwise i can't signal) and yet it doesn't turn on the hazards.
also, i know my car has an imobalizer and an alarm but i don't think my alarm works :ninja: coz it never makes any noise.......
how do i do a check on these kinda things?
cheers
Edited by IH8VEE8S
cheers
How to check.
1 - Get yellow pages.
2 - look up professional alarm technician
3 - Book in car
4 - Take car to alarm technician
5 - pay money for a professional to fix it.
Why?
Well, your car is not even close to being raod worthy with that set up. But with that aside, An alarm when installed and working correctly could be your last line of defense against some scum bag theif who wants your car as much as you do..
possibly some super dodgy wiring has been done there.
sounds like the hazards have been hooked up to the door switch or interior light. try just switching on the interior lights and see if the hazards go on.
and if you have an imobilizer, that doesn't mean you have an alarm. if you look in the engine bay you should have a speaker looking thing.
it may just be that the hazards switch is dead. if you have the hazards switch disconnected then the indicators won't work (well thats how is in my SSS pulsar).
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
