If you follow these steps, you should have no problems....
Step 1: Take car to mechanic
Step 2: Pick up car from mechanic with injectors changed
Step 3: Pay mechanic.
Or you can do it yourself, it's more fun when you learn the hard way
Looking at a how-to with pics, but here are the main points assuming a stock engine:
drain radiator
remove cross-over pipe into throttle body
remove throttle body
disconnect fuel lines
disconnect AAC lines
disconnect loom connectors onto AAC
remove plenum mounting bolts and split manifold
access entire fuel rail and remove mounting bolts
use some lube like silicon spray or brake assembly lube around injector mounts
loosen and remove injectors from rail
installation is basically reverse procedure.
You will need a reasonable amount of time, patience and a few tools to make it happen. If not, take it to a mechanic.
You dont have to take plenum off just intake pipe & throttle body take fuel return line off and hoses & then loosen fuel rail bolts then take radaitor breather hoses off take plugs off injector then pull hole rail out
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
