OK,
Got my new rims from Leo ,(JDM CONCEPT) XD9 Gunmetal 18" by 10" DEEEEEEP-DISSSSHHH.
They look fantastic. :):):ninja:
The tyres are the hardest choice to make.
I drive the car daily and want a good quality tyre without it setting me back $4000 plus.
Yes I am as shocked as you are....these apparently go on Ferraris, Porsche etc.
All tyres above 255mm wide have a price penalty attached to them.
They come with the OH factor. :)
OH you need them that wide.....OH you also need the same size for the fronts.
OH OH OH OH OH :laugh::P:)
And these are the tyre dealers...and suppliers.
It is as if I have a larger nose than every-body and all they seem to say is OH. :O
Volume is the key to manufacturing costs of these items, sure I understand but the difference from
255 to 295 is almost double, that i cant understand.
Ok I am happy with 285/35 for these Rims. The height for the ride and the width for the handling.
I fear if I go wider I will have a hard time steering and if I go lower I will have a harder ride than I have now
sitting on Ohlins.
I can go as high as 315/30 but am concerned not only on the two above points ,but also on my pockets.
So my choices are 275/40 ,275/35,275/30,280/35.285/30.285/35,290/30,290/35,295/30,300/30,305/30,310/30,315/30
Which tyre?What size? Now you know what i am going through.HELP!
I have bought many tyres in my life, none have been this complicated to choose from.
Any input......besides OH :O
Would be great,
https://www.sau.com.au/forums/topic/132063-new-rims-gtr33/
I'd be going with the 275/40's the problem with going anything below 40's is the handling starts to go because there is so little flex in the sidewall of the tyre. And even the smallest of bumps in the roads is magnified 40billion times, the width of the wheel has little to do with how rough it will be it is more the height of the sidewall.
A friend of mine used to do contract work at bridgestone on their industrial networking stuff, apparentley say a 275/40 tyres costs no more to make than a 195/60, it's the fact that the market for them is so small and they sell so few of them they cost the earth.....
https://www.sau.com.au/forums/topic/132063-new-rims-gtr33/#findComment-2445591
What tyres and Rim size are you running Kyle?
https://www.sau.com.au/forums/topic/132063-new-rims-gtr33/#findComment-2445779
even a 255/45 or a 265/45 would be fine.
Thanks Beer Baron,
I am thinking of going 275/35/18 in the Hangkook K104,
or 285/30/18 in Hangkook K107 which is just new on the market so asking anybody
about these are really a waste of time.
I will buy them next week so hopefully have some more time to research a little more.
Might see if anybody does a 275/40/18 this would be ideal I think.
:D
https://www.sau.com.au/forums/topic/132063-new-rims-gtr33/#findComment-2446048
I had 255 hankooks and they actually measured about 20mm less width than my 265mm yokos... i think the k104 a bit undersized.... i think 275 is a good size for your rim, if your going the hankook maybe go for the 285....
ps. i wanna see photos when you have the wheels on your car.
https://www.sau.com.au/forums/topic/132063-new-rims-gtr33/#findComment-2446062
yokohama does 275/40/18
I love Yoko's...I will look into them tommorow.
I have had a price on second hand Pirelli 70% tread and Bridgestone 75% tread.
Does any-one use seconds because they save 1000's or is it just because they are a better tyre.
Why are the K104's at 310 ,Re55 at 470, Bridgestone at 750 and Pirelli at 900
The more I look the worse it gets. :D
https://www.sau.com.au/forums/topic/132063-new-rims-gtr33/#findComment-2446661
No problems you will see the beast, all in her glory :D
https://www.sau.com.au/forums/topic/132063-new-rims-gtr33/#findComment-2447477
I would rather get good 255/40's (which will fit easily on 10J) than crappy Korean 275s...
There is huge variation in between the width of tyre models of the same specification anyway.
I have put lots of different 215/45R17s on my 9J wheels and the difference in actual width is striking.
But regardless of how wide they look, the "good" tyres always handle better, when I stick some
el cheapo Korean tyres on my car I always think something is broken in the suspension (even when
it isn't). The difference in construction of the tyres is very obvious when you are mounting the tyre
and amazingly obvious when you are driving it.
Anyway, if I had some 10 inch wide wheels I would be putting 235/40s on them because I am one of "them" now. :stupid:
But until I get a new diff from tonight's efforts I won't be changing any tyres very soon :D
But the question you need to ask is how was the car on the current tyre/wheel package you are running?
I am guessing either 245/45R17 or 255/40R17... If the car was not a deathtrap running those "narrow"
tyres it will be fine with the same width tyre in a lower profile and if the tyres cost twice as much for wider
ones just buy softer tyres that grip better and last half as long.
Edited by Laurence
https://www.sau.com.au/forums/topic/132063-new-rims-gtr33/#findComment-2447565
I wouldn't mix brands/models of tyres on your GTR, you need exactly the same tyre size all the way around or it will mess with your ATTESA
https://www.sau.com.au/forums/topic/132063-new-rims-gtr33/#findComment-2447653
Hello...Thanks for your replies guys...
Some tyre pricing for you
Yoko's (unsure of pattern )275/40/18 $500 each
Ventus K104 275/35/18 $310 each
Ventus K107 295/30/18 $410 each
Not thinking of buying different sizes because of the Attessa.
Although might give that the flick later.
The widths do vary........why do tyre manufacturers do this...is thw width measured internally and not at the treads?
Cheers
https://www.sau.com.au/forums/topic/132063-new-rims-gtr33/#findComment-2448069
275x35x18 would be about the same diameter as the stock 245x45x17and your speedo will be same as well.
I have used 265x35x18 and 275x35x18 on stock R34 GTR rims and they are both OK. I had Falken ST115's on 18x10 rims in a R33GTR and they were fine.
I have Toyo T1Rs 275x35x18, they are a very good all around tyre and if you shop around you should be able to get them at a reasonable price.
https://www.sau.com.au/forums/topic/132063-new-rims-gtr33/#findComment-2448096
I recently bought 18x10s aswell and went with some Yokohamas. They were a fair bit cheaper than your other quote (depending on which model they quoted you on of course)
I got the Yokohama AVS 102 in 265/35/18. They're about $325 per corner fitted when i had mine done.
Awesome grip in a straight line and excellent steering response aswell. The only negative is that when they are new they have to be worn in, so dont go flying into a turn when you first have them fitted because they may not hold on! Should be right after the first 100kms or so.
Otherwise its an excellent tyre, suited to street and mild track work.
My 2c......
Cheers
https://www.sau.com.au/forums/topic/132063-new-rims-gtr33/#findComment-2449835
I've got 17x10rims with 255/40's on it but they are an el-cheapo brand nexen or something similar (there what came with the car) and there like skating on ice but the actual ride quality with coil-overs isn't toooooo rough. The two cars i have been in though one with 35's and one with 30's can't remember width were like running on the rim, the car was bumpy as...
If you can I would highly recomend RE55's, one of my friends had 235/45/R17's on the front of his n/a supra (something else on the back) and we had a hard time breaking traction.....awesome tyres very much worth the money.
https://www.sau.com.au/forums/topic/132063-new-rims-gtr33/#findComment-2449879
My 2c......
Cheers
Hello again.
I will check again tommorow why my pricing on the yoko's were so high.
I can not see the difference in price except for the fact I like the 275/40/18 combination.
I will also check to seeif toyo's and Falkans also come in this size.
RE55 sound like a good idea, but last i looked 10000KM's before they get dodgy,sucks.
Kyle , change your rubbers before you snow-plough into something.
High Performance cars need high performance...stopping power(Brakes and tyres)
Still not decided, I could write a list of things I need to do for the next 10 weeks and be
pretty spot on.But can't for the life of me make a decision...need a holiday :dry::)
Thanks again for your inputs.
Tekin
https://www.sau.com.au/forums/topic/132063-new-rims-gtr33/#findComment-2450140
Yeh I know thats the only gay thing about them, soft compound so they wear out quick, unlike the tyres on my commodore, I've had them puppies for over 100,000K's now and they still have heaps of tread :/ good old Falken ZE-326's
Yeh I know there baaaad, I still take it pretty easy driving the car as i ain't had it long, it is on my immediate list of things to do. Though I am used to driving cars that have so little traction they make my skyline feel like it is on tracks in comparison even with the crappy tyres :)
:dry: hmmm reading that it makes me sound like I don't care about my cars, I am really quite anal when it comes to quality with them though, dam working in the aviation industruy and having the mindset of quality required for aircraft it gets expensive :P
Also out of intrest where bouts you been getting quotes from for your prices, just so I have some direction when my time comes :)
https://www.sau.com.au/forums/topic/132063-new-rims-gtr33/#findComment-2450310
Yeh I know thats the only gay thing about them, soft compound so they wear out quick, unlike the tyres on my commodore, I've had them puppies for over 100,000K's now and they still have heaps of tread :D good old Falken ZE-326's
Yeh I know there baaaad, I still take it pretty easy driving the car as i ain't had it long, it is on my immediate list of things to do. Though I am used to driving cars that have so little traction they make my skyline feel like it is on tracks in comparison even with the crappy tyres :P
:/ hmmm reading that it makes me sound like I don't care about my cars, I am really quite anal when it comes to quality with them though, dam working in the aviation industruy and having the mindset of quality required for aircraft it gets expensive :P
Hello again,
Made my choice today...finally.
Ventus 104 same as i am running now 245/45/17
Could not bare to part with another $800 more for the others :(
275/35/18......$310 Each fitted and balanced.TOTAL $1240
Kyle my first set of tyres..were crap(fronts) I skidded and nearly hit a BMW and the next day I hit a pole.
Not much damage,$300 to repair(Repair bumper and repaint ) Just pride
When it is wet and you loose rear traction on take off the fronts don't respond very-well when you hit then as
soon as you have taken off . Just letting you know....I am sure you know any-way.
Also I think tyres have gone up in price lately...due to oil prices.
The yoko's i had a quote on were the ADVAN AV02 pattern they have a AV03 but $530Each
Thank you all for your input...I will have them on Monday fitted and balanced.Photo to follow.
At Northern Car Care in Campbellfield/Melbourne.
Cheers
Tekin
https://www.sau.com.au/forums/topic/132063-new-rims-gtr33/#findComment-2453434
Oh damn, i was just going to advise against the K104's!!
I have a brand new set of them on my GTR, and i sorry to say but i was a bit shocked by the braking and turn in!!! Understeer city when asked to change the 1500kg whales direction in a hurry! And braking, they kept losing traction causing the ABS to keep coming in so much that the car kept going!! Ok my braking example is when asking a lot of them, but the understeering example i noticed even on just spiritly driving.
Another fact to bear is that im used to RE55's on my gtst. But dude at the end of the day if you have anywhere near 700HP, i would forget about all but the very top street tyres such as conti's michelin and pirelli.
Any keen for a review of your own, let us know what you think, as we all drive differently and expect different things from our cars!!
cheers.
https://www.sau.com.au/forums/topic/132063-new-rims-gtr33/#findComment-2456868
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
