The CAS is keyed to the exhaust cam so it only goes on one way, when you try and move the CAS it's attached to the exhaust cam which is in turn connected to the intake cam via the cam belt and the crank also from the cam belt, not exactly easy to move it.
And even if you can it wont do shit because all the gears will move along a like they would if the engine was running.
Pretty sure the only way to advance the timing is electronically.
Best way to understand would be rip the CAS off for 10 seconds and you'll understand, cause i suck at explanation.
Edited by Rudager
Hi, my dad and i are attempting to adjust the engine timing for more advance, however we are unable to move the CAS, we have loosened three mounting bolts and it still doesnt move..I've got a R33 with an RB25DE for your info. Any help would be appreciated.
It definitely should move . Undo the 3 x locating bolts at least one full turn . It could be stuck to the gasket , and they do cause a slight indentation in the gasket which may prevent it from turning if bolts are only slightly loosened .
I would only andvance it 4- 6 degrees . I advance mine 4 degrees and use ethanol 10 petrol which has an octane rating of equivilent to 103 .
Also was advised by My local wreckers at moorebank that the rubber between the CAS sometimes will slightly melt and make it hell difficult to move.
On inspection so far it seems that is true..We'rve managed to move it and just testing now for an optimal setting.
Thanks for you guys and sau's help as usual.
Would be nice to talk to more R33 GTS-4 members
Edited by Ryan D
Just a follow up on this, When adjusting the engine timing on the RB25DE make sure you put the car under load in 5th gear and check for signs of pinging, I've found all the local fuel pretty substandard (compared to what the fuel companies claim) and wasn't able to advance as much as we thought.
Definately has made a slight difference though.
I used to just keep advancing it. take it for a drive each time, absolutely cain it all the way to the limiter and when it starts to ping back it off a little, dont worry if you've never heard pinging before... you will know what it is if it happens.
    • Slow when hot could also be because its getting more dynamic compression, OR things are getting a bit tighter once it is all expanded. If it were an earthing issue, typically I'd expect you to have it have issues all the time. Unless it's really a combination of both things. Where the higher compression, and things being a bit tighter, is giving that bit of extra load and you do need a slight clean up on the cables/connections.
    • Yeah, this is one of the most annoying things about nissan part numbers... I've got an unrelated example... Image is of the AT output shaft ~ they have the same part#, but clearly the shaft on the left is beefier design to that on the right ...the difference (essentially) is the 'lighter' shaft on the right, is for engines up to RB25DE (this includes RB20 variants) : the shaft on the left is for RB25/26DET(T)....are they interchangeable? Yes...but obviously one shaft is going to be stronger than the other...and, the lighter shaft is around USD115, but the heavier shaft closer to USD150...same part#... ...epc-data usually tells a tale ~ the amayama listing for 39100-23U60 has a note "Longest side is between 60 and 105 cm" ; no such info is there for 39100-23U70 ...and given the great disparity in price between the 2 parts, it makes me at least curious (to the point of caution) where the 'extra money' went? ...ie; these 2 parts have a cost difference that (to myself at least) isn't explained by 'plastic boot'...ie; with amayama there's AUD700 price difference ...plastic versus rubber?...I'm not seeing it like that...and 60cm ~ 105cm...??...that's a huge disparity....something hinky going on here... I'd try searching by VIN, not model... /2cents
    • I don't know for sure, but I'd expect them all to be interchangeable given the diff end and hub end don't move/change between any C34 series. Often Nissan will change part numbers and the aftermarket follows those year ranges; but the original part number change doesn't mean other parts won't fit. The change could be a change in material, internal parts or even just supplier. For example, all the RB gearbox to engine bolts are no longer available and there is a new part number instead. The only change is they went from cadmium plated bolts to zinc plated due to the issues manufacturing with Cadmium. They look different but work the same.
    • One year is a bit concerning. Did you try contacting GSP? It says 5 year warranty on the box if I remember correctly. I'm also running their driveshafts on my S2 Stagea.   You could check the part numbers on Amayama for your year. Here's the link for my 1998 which gives the 39100-23U60 part number. Well, that and 39100-23U70. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/trans/391 What does it say for yours?
    • I ordered a GSP Front R/H Axle from here - https://justjap.com/products/gsp-premium-front-driveshaft-r-h-nissan-r32-r33-r34-skyline-gtr-stagea-4wd#description It lasted around a year before one of the boots blew out. I'm lowered, but I have GKTech roll center adjusters. One year seems a little premature. I think I'm going to spend the extra money on an OEM cv axle this time. This website - https://tfaspeed.com/collections/nissan-stagea-wgnc34-x-four-parts/products/nissan-stagea-awc34-260rs-rb26-right-front-axle-drive-assembly Makes it sound like the readily available OEM CV axle will only fit 11.1999 Stagea and up (mine is a 2.1997 S1). The JustJap listing didn't mention any years or anything for the GSP axle. Amayama shows '11.1999' and up as well for that part number. As well as 'plastic boot type'. See attached picture. So I guess my question is, does that axle (39100-23U60) really only fit S2 Stagea? It's the front driver side. If it does, I'd love to buy that instead of rolling the dice on another GSP. I've found that OEM one cheaper here: https://www.partsfornissans.com/oem-parts/nismo-jdm-r32-r33-r34-skyline-gtr-r32-gts4-right-front-axle-3910023u60 and here https://www.nissanparts.cc/oem-parts/nismo-shaft-ft-drive-3910023u60 Just a little confused because the JapSpeed listing for the GSP front driver axle doesn't mention any specific years or anything and it fit my S1 Stagea fine. So will 39100-23U60 fit my S1 Stagea even though technically it says '11.1999' and up? What would have changed? Thanks.
