hey
i have a r33 gts4
i was wondering, if i was to get the rotors redrilled to 4 stud would i be able to put the calipers and rotors onto my gts4?
anyone have answers?
thanks
I don't see why not, as long as they clear your wheels?
i believe all gts4s have abs? if so then you will need gtr brakes.
if not then it should be alright.
rotors and calipers are a very good upgrade if you like the occassional track work or like a well handled car without having the issues and ongoing costs of a turbo car.
i have an r33 gts with r32gtst calipers and rotors front and rear... so far the only issue has been my spokes from my rims not clearing the bigger brakes.
i've got a street set of 17x7 rims which run spacers, and a track 17x8 rims which do not require spacers...
its all about the spoke design - so its best to do the conversion BEFORE you buy rims.
i have aftermarket volk racing rims 17x8, and yeh gts4 have abs, but insted of doing a hub conversion i would rather just put the rotors and calipers.......btw do any gtst have abs?
well i'd like to say that even with volks you'll be ok - but i've found it seems to be on an individual basis - you'll have to look into the thickness and height of the rotor hat, etc, spoke design. i suppose you'll find out when you do it. so keep that in mind - as there's no real way to measure the "X-factor" of the spokes. offset has some part influence but not entirely.
well you are going down the same lines as me as i have custom DBA 4 stud r32 gtst front slotted rotors and redrilled r32 gtst rear rotors - also because i had a set of rims i didnt want to get rid of.
to answer your question: yes some gtst's have abs.
i am not sure what the implications are of using RWD GTST calipers and rotors with an R33 GTS4 setup.
to be safe I'd be more inclined to go with a GTR setup or an R32 GTS4 setup - just so it doesnt mess with your attessa system.
what i'm currently looking into now and one of the reasons for going with an R32 GTST brake setup is that the 180SX/S13 stud pattern is the same i.e. 4x114.3, and the thing is that they also have the same diameter rotor discs. sooooo.... my point is that it MAY be possible to run R32 GTST calipers with 180SX rotors, thus not having to get custom rotors/redrilling rotors all the time and also giving the option of slotted/cross drilled rotors which are not so readily available for the non-turbo skylines.
of course then there's measurements of the rotor hat and that may put measurements out again.
hope this helps and puts things into perspective
    • As I implied in my post, I have NO idea what the were. But in case I didn't make it clear, the way they performed was brilliant; whatever the brand was. I think it was the compound that made the difference. And if they were Bendix, then sign me up, I want another set. I did drive down mount Ousley (just outside of the Gong) a few times, and they showed no untowards performance.   Its not the low dust that I am looking for NOW. At the time I needed low dust, but now I have no issues with dust but want the initial/early bite of the pads that were used. Yeah, the early cold squeal may of been due to a missing shim or such.  And to repeat, its not the low dust I am seeking, its the initial bite of the pads and increase in bite as  the warmed up during each breaking. As soon as I let off, I don't remember the breaks being extra sticky if I used them again soon after. But I also did not test that theory.   Thanks for the recommendation, But I would prefer to choose something specifically with the behaviour I described.   I assume that they didn't use the default compound off the shelf, as we discussed the dust issue at length. And the early squeal when cold, I have seen the sound is more of an issue with some pad compounds. Mostly ceramic, which also are said to produce less dust.
    • Well, in 2007 he must have been charging about $1800 an hour. He only looked at the car for 5 minutes. And another 4 to write the report wrong, and another minute to correct it. Mind you, this was for a car that was: Stock engine, fmic (hole in drivers guard), all alloy intake and custom air box, 3 inch turbo back exhaust, lowered, and a set of 17" Advans (255/40/17 rear and 235/45/17 front). It was nothing crazy. The blue slipper wanted the "hole in the guard" engineered. But that was because he got the shits that I wouldn't "relocate the battery from the boot, back to the factory position in the engine bay"... In an R33 GTST...     Also for emissions, E85, and don't go wild on timing. It's amazing how the closer you get ignition timing towards max torque, the last couple of degrees really throw NOx counts right up. And for the huge increase in emissions, it's only a small increase in torque.
    • He'll be looking down and swearing about "the damn apprentice" for trying to convince Duncan to use percussive maintenance... 😛
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
