hi all,
looking to get 200 awkw current mods are full 3inch exhast, k&n pod, and big FMIC. i have been told that upgrading my turbo to a VQ turbo off an R34, bleed valve and winding boost up to 12psi and i will have around this figure. to me this sounds too good to be true.
has any one used a vg30 turbo or VQ R34 turbo on their stags or is it better to get an after market brand new turbo.
https://www.sau.com.au/forums/topic/132124-200-awkw/
you can get the sort of power your are after with a hiflow of the stock turbo i believe best to do a search for the words turbo and hiflow in the stagea section there have been way too many articles on here to list and I am sure everyone doesnt want to repeat what has been discussed numerous times before
goodluck
https://www.sau.com.au/forums/topic/132124-200-awkw/#findComment-2446801
I dont know what the heck a 'VQ R34' turbo is. But an r34 turbo wouldnt be a worthwhile upgrade and a vg30 turbo definately isnt.
A better course of action would be a fuel computer, boost controller maybe a replacement turbo of some description and a good tune.
https://www.sau.com.au/forums/topic/132124-200-awkw/#findComment-2449912
IMO only
a VG30 or a R34 Neo turbo will get you to say around 180awkw with a good tune, but it wont go to 200awkw unless you're pushing it to destruction - however if you had one of these turbos with an exhaust steel wheel then yes, it could take more boost and get 200awkw
But youd need; large fmic, great airflow to airfilter, large fuel pump, adjustable fpr, full hiflowing 3inch+ exhaust system, larger-reading afm, and an ecu of sorts (piggyback like safc/sitc combo, or emanage, or full computer - hell, its your gearbox!)
highflow a standard R33 turbo tho, and do the above, and you'll be maxxing out the injectors before you reach maximum power from the turbo. how does 215awkw sound? :dry:
https://www.sau.com.au/forums/topic/132124-200-awkw/#findComment-2450367
215 sounds good. the bloke has told me that using the turbo he has got 240 rwkw out of a R34 but said that is the absolute maximum. the price is 600 change over and he will use the exhaust housing of my turbo so it will all bolt straight on. are there after market computers for autos without getting say a microtec system wired in. like a power fc
https://www.sau.com.au/forums/topic/132124-200-awkw/#findComment-2457161
doesnt sound like a good deal at all, steer clear until you have more info. the R34 has the good exhaust housing - what current turbo do you have?? if yours is the r33 turbo then uhuh dont do it. you want a turbo woth the r34/vg30 OP6 rear exhaust housing for a bolton upgrade, and youd need to highflow it to get that 215 awkw........ tune with safc, or emanage (look into the coil pack reports tho)
maybe look into this:
http://www.skylinesaustralia.com/forums/in...howtopic=131723
Im happy to let ppl know this is the direction Im taking,... I have all the supporting mods done and tuned, so I personally expect a 200awkw tune at ~1bar tune with a safc and sitc as the piggybacks. Maybe it might just be a 190awkw at 1bar and 200 above that, but meh I got a dual stage ebc LOL :laugh:
Cant wait to tell you all the truth. Budgets damn tight but Im making it happen (wife and kids love peanut butter sandwhiches for a month) LOL :laugh:
https://www.sau.com.au/forums/topic/132124-200-awkw/#findComment-2458302
spoke to mechanic last week. the vq turbo is off a new 3L V6 engine which i think is in a 350z or car like that. he has put one on a r33 before and got 225rwkw on 12pound boost and all he had to do was run 12v back to fuel pump. getting it done next week and putting it on a dyno be able to tell you what power the stag will make. i hope it will be around 200kw
https://www.sau.com.au/forums/topic/132124-200-awkw/#findComment-2476755
Sounds like the turbo off the VQ25DET. The only car I know of that has this engine is the Series 3 (m35) Stagea.
Thats a turbo 2.5L V6, so the turbo should work well on a 2.5L RB I guess...
The 350Z is non-turb and has a 3.5L V6 (VQ) engine.
Anyone know if the VQ25DET turbo has steel wheels?
Would be interesting to hear your results - might be another alternative turbo upgrade for skyline/stagea owners :(
Not many of these are likely to make it to australia though...
https://www.sau.com.au/forums/topic/132124-200-awkw/#findComment-2477901
got my car back on saturday. ran out of time for dyno so it will be getting done tuesday night i hope. some issues with car. feels like it is not getting the correct amount of pull down low. disconnected factory boost controller so i have less boost down low at the moment. as wasn't put on dyno kept boost stock to be safe until it is on the dyno. pull up top is amazing and boost gauge is only reading 0.5 bar so when we wind it up to 1 bar it should be sweet. having problems with getting cool air in the air pod. have fitted factory scoop above the radiator and crappy cool air induction system to help it for now but i need to make a cool air box.
just want to wind boost up and see what power it is making.
had a drag with my BRO AND BEET HIM IN A R31 WITH RB20 so was happy about that. (he was devestated)
put power figures up later in the week.
https://www.sau.com.au/forums/topic/132124-200-awkw/#findComment-2524358
got my stag on dyno today. 157.8 rwkw on 0.5 bar of boost. mods are FMIC, pod filter, 3 inch exhaust and bleed valve and vQ turbo. didn't get to wind boost up as a funny smell started coming into car. mechanic thought it was coming from trans so we stopped for today. all looks good for 200 kw on 1 bar but have to sort out a few problems first. still dont know why only feeling the pull of the turbo at about 4000 rpm has any one else found this problem. has it got anything to do with the car being auto???
https://www.sau.com.au/forums/topic/132124-200-awkw/#findComment-2531279
are you putting your car on the dyno just to wind up the boost and see how many rwkw's you'll get?
No offense mate, but it sounds like a very dangerous approach....might be a better idea to get an safc installed then running the car on the dyno...that way you get to tune the car to get betterAFR's and won't run the risk of blowing ur engine.
https://www.sau.com.au/forums/topic/132124-200-awkw/#findComment-2537513
Wouldn't the stock ecu start cutting fuel or switch to R&R to stop the engine running lean?
I figured you'd get these warning signs before the engine has any risk of blowing up...yes?
https://www.sau.com.au/forums/topic/132124-200-awkw/#findComment-2537963
ECU is based on airflow not boost, you can over boost, start detonation and blow up your engine easily, try it, see what happens...
https://www.sau.com.au/forums/topic/132124-200-awkw/#findComment-2538384
But what about with only 0.5bar or 1bar - like he mentioned??
I know the stock turbo wont cope with 1bar for long, but what about the engine??
Have heard of plenty of people with similar mods to stagon running 10-12psi without problems.
Sorry my knowledge is a bit limited on all this.
Is detonation only caused by the mixtures running lean? ie. too much air for the amount of fuel? thats the way I understood it.
Still it is definitely a good idea to try this on a dyno first and get an safc or similar to tune it properly.
https://www.sau.com.au/forums/topic/132124-200-awkw/#findComment-2538763
1 bar = 14.5 psi @ 0 ft above sea level....don't think the stock ecu was made to handle that kinda boost without some sort of afc or rom tuning done.
https://www.sau.com.au/forums/topic/132124-200-awkw/#findComment-2539131
work on the safe side and get a piggy back system installed at the same time your increasing boost, the $500 you might spend now might save you the $3000 on replacing your engine...
i've never heard of anyone getting good results by just winding up the boost on a larger turbo while still running stock management...
a mate of mine runs a hi flowed steel wheeled Vg30 turbo on his rb20 and it won't hit full boost till just over 5000rpm, he's only running 6psi till he can instill an SAFC...
Edited by rsx84
https://www.sau.com.au/forums/topic/132124-200-awkw/#findComment-2540711
    • You’re all still going on about track cars, he has said multiple times doesn’t intend to take it to the track,  just stick to what was said at the beginning and do the pump and ecu, it’ll get you enough for 230kw at the wheels and has enough poke to be fun for what you want it for
    • All of that is absolutely true. At any time in the history of these turbos the lottery has always been that it could die at stock boost treated exactly as the factory intended, or it could die when pushed to 10, or 12, or 14, or 16 psi, after a short time, or a longer time, or it could last seemingly forever. You have the combination of all the possible statistical (probably) normal distributions of manufacturing tolerances and quality outcomes, on top of the statistical distributions of failure modes (which might be normal, but are probably biased, like Poisson distributions). You get the lucky turbo and you can beat on it for years. You get the really unlucky turbo and it will crap itself as it rolls out of the factory gate. And every possibility in between. But you can definitely still kill the lucky turbo. It's just that most people didn't try, once they knew they really shouldn't try.
    • Maybe I have Stockholm syndrome but working on an M2 isn't that hard. Getting parts cheaply and quickly is hard, but getting parts same day isn't necessarily hard if you're willing to pay way too much for it at local dealers. There's a lot going on, you need to have a build of ISTA on a laptop and the right cable, if you don't have the mindset of "do it exactly right or not at all" you will probably start seeing cascading failures. Skylines are a little more tolerant in that regard. The car doesn't potentially trash itself if you bought the wrong oil filter like a BMW would. Or trash the entire cylinder head and potentially spin a bearing because someone took the anti-drainback valve out of the plastic oil filter cap. An M2 will also do just fine on track, zero oil starvation concerns, factory brakes are great if you change the pads for a high temp compound + flush with track-ready fluid.
    • The "ideal/formula" that used to be touted was death of the turbo is going to be caused by a combination of 3 things. Heat Speed of turbo (boost level you're pushing) Time   Basically, you can get away with high heat and high boost for short periods. But start doing long hard pulls, or circuit driving etc, and now you've increased time as well which will shred things. From memory when Adrian was drag racing he was running 17psi, on a stock turbo, and running insane speeds. But he also had other additives helping in the setup too. Some people have success at 14psi for a while, while others due to pushing the cars hard for long periods opt down to lower temps. But also, generate a lot of heat (let's say bad tune), for a long time, and you'll be okay, until you try to spin that little guy up slightly. It's the one advantage of dumping a lot of fuel in, you'll be reducing EGT a bit and helping with the heat portion of the above 3 areas.   And these days, stock turbos are that old that there's the possibility of just outright failures due to material age. I'm not shocked that even when used in factory spec that a stock turbo fails when 30 years old. It's a worn out "precision" "balanced" performance item, that's likely no longer precise, or well balanced
    • this... hence I said what I said previously, SMSP nights you see mainly Hondas, Evos, A90s, F80x and the odd VW. The 5 or 6 times I went, I only saw 1x R32 GT-R, and other than that I was the only one in a shit box Skyline.
