on the dyno we were checking fuel ratios and up to was getting towards the lean side. 12.5 i think the reading was. i dont fully understand how it all works but i have told the bloke i dont want to boost it up and have a fast car that lasts a couple of months. my car dosn't feel frinnished at the moment. only feeling the pull of the turbo from 4000rpm onwards. mechanic wants to get it back on the dyno and check fuel rail pressure, timing etc to make sure car is running safe. he was talking about fuel cut defender and other stuff that is going to go on the stag. what is a SAFC and what does it do and how much does it cost because it sounds like i need one?!!??!!
Edited by stagon
https://www.sau.com.au/forums/topic/132124-200-awkw/page/2/#findComment-2544104
I've got a GT30 turbo on my series 2 stag and have only recently got a 3" full turbo-back exhaust fitted and now the turbo hits full boost around 3000rpm or maybe even less. Really pulls nice and hard with almost no lag. Before I had the exhaust fitted the lag was very noticeable but now its only ever so slight. One reason is that the turbine now spins more free and another reason is that the engine breathes better and therefore builds revs quicker.
I'm getting a safc2 fitted this week. Basically they just sit between your air flow meter and your ecu and modify the voltage that the ecu sees - enabling you to accurately tune your Air/Fuel ratios. Instead of running rich or lean, the SAFC can correct the AFR graph so that you're running much safer and more economical. You will also see improved performance as a result of your car being more efficient.
Hope that helps. It does have limitations but provided your AFR's aren't too way out then you should have great results with it.
Personally I'd get one of these before a fuel cut defender. Probably depends how much boost you're planning to run.
https://www.sau.com.au/forums/topic/132124-200-awkw/page/2/#findComment-2545098
this might sound real stupid at this stage...but what is a GT30 turbo? is this a stock turbo...if so..which car? is there an advantage of using the GT30 turbo over hi-flowing the stockie ...in terms of turbu efficiency and $$$
https://www.sau.com.au/forums/topic/132124-200-awkw/page/2/#findComment-2574355
Have a read through this topic should shed some light as to the possible advantages, disadvantages and what a GT30 is.
Cheers
Luke
https://www.sau.com.au/forums/topic/132124-200-awkw/page/2/#findComment-2574398
  • 2 months later...
    • You’re all still going on about track cars, he has said multiple times doesn’t intend to take it to the track,  just stick to what was said at the beginning and do the pump and ecu, it’ll get you enough for 230kw at the wheels and has enough poke to be fun for what you want it for
    • All of that is absolutely true. At any time in the history of these turbos the lottery has always been that it could die at stock boost treated exactly as the factory intended, or it could die when pushed to 10, or 12, or 14, or 16 psi, after a short time, or a longer time, or it could last seemingly forever. You have the combination of all the possible statistical (probably) normal distributions of manufacturing tolerances and quality outcomes, on top of the statistical distributions of failure modes (which might be normal, but are probably biased, like Poisson distributions). You get the lucky turbo and you can beat on it for years. You get the really unlucky turbo and it will crap itself as it rolls out of the factory gate. And every possibility in between. But you can definitely still kill the lucky turbo. It's just that most people didn't try, once they knew they really shouldn't try.
    • Maybe I have Stockholm syndrome but working on an M2 isn't that hard. Getting parts cheaply and quickly is hard, but getting parts same day isn't necessarily hard if you're willing to pay way too much for it at local dealers. There's a lot going on, you need to have a build of ISTA on a laptop and the right cable, if you don't have the mindset of "do it exactly right or not at all" you will probably start seeing cascading failures. Skylines are a little more tolerant in that regard. The car doesn't potentially trash itself if you bought the wrong oil filter like a BMW would. Or trash the entire cylinder head and potentially spin a bearing because someone took the anti-drainback valve out of the plastic oil filter cap. An M2 will also do just fine on track, zero oil starvation concerns, factory brakes are great if you change the pads for a high temp compound + flush with track-ready fluid.
    • The "ideal/formula" that used to be touted was death of the turbo is going to be caused by a combination of 3 things. Heat Speed of turbo (boost level you're pushing) Time   Basically, you can get away with high heat and high boost for short periods. But start doing long hard pulls, or circuit driving etc, and now you've increased time as well which will shred things. From memory when Adrian was drag racing he was running 17psi, on a stock turbo, and running insane speeds. But he also had other additives helping in the setup too. Some people have success at 14psi for a while, while others due to pushing the cars hard for long periods opt down to lower temps. But also, generate a lot of heat (let's say bad tune), for a long time, and you'll be okay, until you try to spin that little guy up slightly. It's the one advantage of dumping a lot of fuel in, you'll be reducing EGT a bit and helping with the heat portion of the above 3 areas.   And these days, stock turbos are that old that there's the possibility of just outright failures due to material age. I'm not shocked that even when used in factory spec that a stock turbo fails when 30 years old. It's a worn out "precision" "balanced" performance item, that's likely no longer precise, or well balanced
    • this... hence I said what I said previously, SMSP nights you see mainly Hondas, Evos, A90s, F80x and the odd VW. The 5 or 6 times I went, I only saw 1x R32 GT-R, and other than that I was the only one in a shit box Skyline.
