Before i bought the car i asked the guy what fuel it was tuned too, and he said Shell Optimax 98. So i try to fill up with shell all the time. I noticed when i fill up with 98ron fuel sometimes the pfc indicates it knocks. Last time i seen it knock was 195, i have seen it up to 200. So i decided to fill up with Shell Optimax Extreme 100. Since i filled up it hasnt knocked at all (About 12-15 knocks). Since Optimax Etreme is ethonol based for higher octane, for long term use would it be safe?
Cheers Anggi.
https://www.sau.com.au/forums/topic/132152-shell-100-ocatne/
  • Replies 51
whilst using higher octane fuel will take out knocking you should just have your tune fixed to suit 98 ron fuel. the powerfc faq (in my sig) will help you identify the knocking show you how to report it to your tuner
Guest Mashrock
Cheers Anggi.
i beleive the question your asking about ethonol fuel, is yes its safe. but also its only been around for a short time i figure in these applications correct??
but from what i've been told its ok to run as long as its tuned to it.
  emsta2003 said:
still makes no sense dude........:D
Results 1 - 10 of about 6,030,000 for engine knock. (0.33 seconds)
If that makes no sense, it means it would have taken you just over a quarter of a second to get an answer if you'd gone and looked.
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
