Hi everyone. My name is victim7. I own a 1995 Series 1.5 R33 GTS-T 5 sp manual. I bought it back in December 2005 in Sydney and then had it shipped over to me in Perth. I then drove it home. (I live in Albany, 400km sth of Perth). It has a 3" exhaust from the turbo back, High flow (racing) cat, twin plate HD clutch, HKS blow off valve, Apexi turbo timer, and it's chipped (or so I've been told, I dont really know for sure but I've hit top speed of 240 Kmh and apparently from the factory they have a 180 Kmh speed limitation). Anyone know how I can tell if its been chipped other than that? I've also fitted a pod filter since I got it. Stock engine and turbo. 1st thing will be a Trust front mounted intercooler and a boost controller. Any advice on this would be much appreciated. Anyway, thats me. Once again, Hi to everyone out there in Skylines Australia.
https://www.sau.com.au/forums/topic/132185-hi-all-chipped/
you can tell if its been chipped if you take the cover off the ECU... if its been chipped, the standard solder-in ROM chip will have been removed, and a socket soldered in, in its place, with the new chip inside that...
or if its a MINES ecu or something like that they usually have the sticker on the outside of it.
but if you've hit 240, there's 2 things i can deduce from that... a) you're an idiot and b) the standard 180kph speed limiter has been removed, which is either done by running a speed cut defender or a modified/aftermarket ECU
https://www.sau.com.au/forums/topic/132185-hi-all-chipped/#findComment-2447532
A little harsh don't you think?? :D For all we know he may have achieved this speed on a track somewhere!!
https://www.sau.com.au/forums/topic/132185-hi-all-chipped/#findComment-2447681
the car has an exhaust and a pod... which means it is going to be not much quicker than standard (i.e. wet wig)... there is not a track in Australia short of Bathurst (conrod straight) that i can think of that a near-standard R33 would be able to wind out to anywhere near 240kph
https://www.sau.com.au/forums/topic/132185-hi-all-chipped/#findComment-2447763
you know...there are actually places in this country where there are no speed limits...and I'm sure WA may just fall into this category...(frowning)
https://www.sau.com.au/forums/topic/132185-hi-all-chipped/#findComment-2447772
eh yeh fair harsh, theres quite a few long roads in AUS that are unlimited speed, people always jumping to conclusions.. Mentioning anything over 100 KPH, mentioning drifting, burnouts or standstills and youll get flamed instantly, its quite sad really. Seems people think theres no places in australia you can enter into these activities legally :O
https://www.sau.com.au/forums/topic/132185-hi-all-chipped/#findComment-2448098
Put it this way - why does the Aussie Joe-Public simply LOVE their hi-po motorbikes??
I'll tell ya - speed, speed, and more speed... thats straightline speed and cornering speed. Thats how bikes are judged here, how quick they are in all-round conditions. Im finaly using my smarts, and walking away from riding tho.
To see if its chipped, open up the kick panel on the pasenger side (under golvebox), check over the front and rear of the ECU for stickes, stamps, tampering etc.
https://www.sau.com.au/forums/topic/132185-hi-all-chipped/#findComment-2448156
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
    • How complicated is PID boost control? To me it really doesn't seem that difficult. I'm not disputing the core assertion (specialization can be better than general purpose solutions), I'm just saying we're 30+ years removed from the days when transistor budgets were in the thousands and we had to hem and haw about whether there's enough ECC DRAM or enough clock cycles or the interrupt handler can respond fast enough to handle another task. I really struggle to see how a Greddy Profec or an HKS EVC7 or whatever else is somehow a far superior solution to what you get in a Haltech Nexus/Elite ECU. I don't see OEMs spending time on dedicated boost control modules in any car I've ever touched. Is there value to separating out a motor controller or engine controller vs an infotainment module? Of course, those are two completely different tasks with highly divergent requirements. The reason why I cite data sheets, service manuals, etc is because as you have clearly suggested I don't know what I'm doing, can't learn how to do anything correctly, and have never actually done anything myself. So when I do offer advice to people I like to use sources that are not just based off of taking my word for it and can be independently verified by others so it's not just my misinterpretation of a primary source.
    • That's awesome, well done! Love all these older Datsun / Nissans so rare now
    • As I said, there's trade offs to jamming EVERYTHING in. Timing, resources etc, being the huge ones. Calling out the factory ECU has nothing to do with it, as it doesn't do any form of fancy boost control. It's all open loop boost control. You mention the Haltech Nexus, that's effectively two separate devices jammed into one box. What you quote about it, is proof for that. So now you've lost flexibility as a product too...   A product designed to do one thing really well, will always beat other products doing multiple things. Also, I wouldn't knock COTS stuff, you'd be surprised how many things are using it, that you're probably totally in love with As for the SpaceX comment that we're working directly with them, it's about the type of stuff we're doing. We're doing design work, and breaking world firsts. If you can't understand that I have real world hands on experience, including in very modern tech, and actually understand this stuff, then to avoid useless debates where you just won't accept fact and experience, from here on, it seems you'd be be happy I (and possibly anyone with knowledge really) not reply to your questions, or input, no matter how much help you could be given to help you, or let you learn. It seems you're happy reading your data sheets, factory service manuals, and only want people to reinforce your thoughts and points of view.
    • I don't really understand because clearly it's possible. The factory ECU is running on like a 4 MHz 16-bit processor. Modern GDI ECUs have like 200 MHz superscalar cores with floating point units too. The Haltech Nexus has two 240 MHz CPU cores. The Elite 2500 is a single 80 MHz core. Surely 20x the compute means adding some PID boost control logic isn't that complicated. I'm not saying clock speed is everything, but the requirements to add boost control to a port injection 6 cylinder ECU are really not that difficult. More I/O, more interrupt handlers, more working memory, etc isn't that crazy to figure out. SpaceX if anything shows just how far you can get arguably doing things the "wrong" way, ie x86 COTS running C++ on Linux. That is about as far away from the "correct" architecture as it gets for a real time system, but it works anyways.
