theres always a bit of noise, when moving the steering wheel it is loud, when at full lock it is louder.
This happens when the car is moving or not. I'm pretty sure its the power steering pump, can ya fix em or do i have to get another one ?
In the Information and technology industry the first thing a tek will as is for you to explain what it is and is not doing in more detail. I see no resin why this shouldn’t be the case here.
Please what kind of noise is it making?
Squealing, squeaking, grinding or another sound I have not covered here or maybe a few of the sounds all together?
  • 3 months later...
Yeah it was just low fluid level. Very embarassing post !!!
Good to see it was just fluid, unusual that the HICAS light never came on???
Was going to say if it was the pump try make a distinguishing mark on the pump so u can tell if it is a new pump or just your one recoed, seen it done before charging for a new pump & the old pump has just had a seal kit put through it.
Give u a idea your looking at around $50 for a seal kit & about 1/2 hr to a hour to pull the pump down & rebuild it, so say $150 - $200 all done, with new pump say around $450 - $500...
Some thing to keep in mind... :P
how about this?
the hose coming from the bottom of the power steering fluid reservoir is always wet. i noticed this on alot of r33's. funny thing is the fluid level has never dropped. what's that about?
how about this?
Had the same thing with my old 33, fluid would leak out the bottom hose and fill up the surrounding rubber sleeve. Ended up just getting new clamps and she was all sweet.
