Hi All,
Just purchased my my first Skyline. A Series II R33 GTS-T (1997). It appears to have a factory turbo timer. Is this the case or has an aftermarket one been in fitted??
Also there has been the odd occasion when it has not operated at all...
Cheers
https://www.sau.com.au/forums/topic/132211-r33-turbo-timer/
  lastlineofdefence said:
I would think it is aftermarket. see if you can find one in a hidey-hole somewhere.
I have looked pretty much everywhere you would expect to find one......
No love as of yet....
Thanks though
https://www.sau.com.au/forums/topic/132211-r33-turbo-timer/#findComment-2479366
check under the steering column, theres a big gap there and an easy place to wire one up, then check behind the middle of your dash, behind the head unit, and if then no luck (in some circumstances) you could have an aftermarket ecu in it which could be running this function, happened to my mates rx7 series 4.
cheers :O
https://www.sau.com.au/forums/topic/132211-r33-turbo-timer/#findComment-2492731
  jap33 said:
an easy way to find it is take your handbrake cover off, find the wire connected to it that enables the turbo timer (it will be the only wire there), and trace it. :)
cheers
Thanks mate
Much appreciated
https://www.sau.com.au/forums/topic/132211-r33-turbo-timer/#findComment-2493497
