  • Replies 52
Any in the works for S13's John? :happy:
They fit S13 same as Skyline we have already fitted.
On Sat trial fitted to Beer Baron's car and will need to make totally different for R32 GTR which has alower ball joint right where the air shoorts at middle of the rootor so might make a bigger one to shoot air here as well as above this. Also needs a bracket to secure to one of the radius rod bolts.
How do you reckon standard nissan pads will hold up on a track day?
Car-180kw.. Toyo t1rs on front, advan ad07s on rears(however might use different rubber on that day)
Brand new rda rotors front and rear with new brake pads (standard nissan)
First time on track, so i dont think i will be doing anything crazy!!
Or should i change my pads before i go on the track day?
yep, they need some re-working to work on a GTR. but they look very nice. very light, easy to fit etc. once you have the GTR design down pat they will be a good thing. I'll be running them for sure. I think they will work even better if you have the factory GTR ducts in place.
Hey John thanks for the DS 2500's... really like them as a street pad, they are nice and linear and no squeeling or carrying on... if they hold up well on the track I am going to be very pleased!
I might be in contact soon re the deflectors... just have to wait til the bank balance is in better shape!
Ahhh, good to hear.
How much are these, and are they available?
here is john working hard on the GTR version. this hands on approach is a little worrying, but he does claim to know what he's doing... hehe
Looking forward for the R33 GTR versions. I think i have the same torch! snap-on!
I am getting a 33 GTR this arvo so if I'm nice I'll let john use it to see if the 32 GTR version fits on 33 GTR (i think it will).
and ferni, yep it's a snap on torch. :laugh:
I am confident these will be well worth while. plus they are piss easy to fit and look very neat and can work in conjunction with more elaborate ducting if need be.
I guess I would like to share my experienc from brakes I have used over the last 8 years.
Im a once a month track boy with 30,000km per year street use.
I used many brake pads on my R33 GTR, STD brembo, EBC green stuff (lasted one track day) and SBS carbon ceramic, the SBC were the best by far. STD rotor STD caliper.
My R34 GTR was a different story, I went straight to the SBS carbon ceramic front and rear, they stopped great but screamed like a cut cat on the road for the life of the pad (9-12months). I then moved to the Frodo 2500 with Motol 600V fluid, the combo was maybe just a little better it was hard to tell, but my hair line cracks in my STD front rotors opened up and I cracked a rotor the first time I used the 2500's on the track, Wakefield. I then put a set of DBA4000 rotors on, the Frodo's lasted 20,000km (9 months) and then I replaced them at Christmas. I did another 2 track days and last week at Oran Park south, one of the hair line cracks opened up again and I cracked my DBA rotor, same spot, right front outside. I assume the VSPEC II brake cooling ducts kept the inside cooler, but its hard to cool the outside. I just had a new set of DBA 4000's put on.
I cooled my brakes down every time I went out on the track, and ABO BOB and I have almost the same experience. I might go back to the SBS next set just to check it out, but in reality, the Frodo/DBA combo is so cheap and do stop really really well.
I guess its hard to find a road pad that last for ever and stops like a race car and cost 20% of the Nissan replacement part. The Frodo does everything except comes at a small price if you drive your car hard on the track.
It must be noted that I cant drive very well and have to rely on very late braking to get good track times, my car does weight 1680kg's when its pounding around the track so its by no means a light weight.
Unless you are trying to keep up with John's 300Z and you only want to do the occasional track day I think the best bang for buck is the Frodo 2500. If you want to really push the boundaries then you either have to start spending more money or understand that DBA rotors can become a disposable item.
I hope this helps someone.
Thanks, good info Paul. :D I had a cracked DBA 4000 rotor, running EBC Red Stuff pads that seemed very harsh,
but had plenty of bite. Now using bendix ultimates for street use and Ferodo 2500s for the track with all new ducting. :P
and ferni, yep it's a snap on torch. :P
I have the Nismo deflectors on my car, and Nismo list them as fitting all GTR's...
They are made of plastic and bolt up perfectly, basically bolts up to the castor rod...
    • If you want to do the wiring, the GTT engine ecu has the same pinouts extra that the seperate TCM in the NA car has. You can literally grab the wires/pins that lead into the Seperate TCM and wire them into the corresponding pins in the GTT Engine ECU. You could then in theory Nistune it. I realised this when everyone put it in the too hard basket and I actually looked at the f**kin R34 manual. This is after I had previously had a seperate aftermarket TCM controller in my original N/A chassis car and a very built gearbox from a GTT, running a seperate Haltech engine ECU. I ran into this issue when I re-shelled the car into a GTT shell, so my aftermarket TCM was no longer plug and play, because the loom/modules were not present. I was pretty livid when realizing just how simple the original fix actually was. It sat for 3+ years at various workshops trying to find a solution. In practice none of this is a worthwhile idea for a lot of reasons, generally surrounding the shitness of the NA auto, the autos in general that come with skylines, and the NA engine and lack of gains. The gearbox is specced for the 2.5L N/A and barely at that level. If you have to pay anyone any money to do any of this, that is money spent on manualizing the car and it's not even close in terms of a comparison. Learning to drive manual is simpler than going through the pain of dealing with the N/A gearbox and he'll have fun to boot.
    • Semi-correction to my blanket statement that you can't bend rubber hoses. It seems that you can get most of a result, by doing as this guy does. I wouldn't promise that the bends will stay in the hose forever. I think if I found they wouldn't stay, I'd get a larger hose and cut some 90°s out to go over the bends I wanted to be in the smaller hose, as a reinforcement.
    • Just a heads up. Mine has just failed. When i turn the car on it just reboots everytime then the word "Android" shows up then goes to a black screen. I've aksed the company i got it from for some help but it's passed their 90 day return so they wont help. I have to swap back to my old system this weekend 😭
    • Does the car have to stay auto? If so, you might be looking at a ZF swap in future.
    • Yeah its tuned relatively conservatively being dynoed at 525hp with every bolt on and top end of the motor built wtih HKS vcam and springs etc.
