  • Replies 84
Interesting article. We got a alcon kit front and rear only 4potters, big 4 pots front and little 4 pots rear. We run full slicks and before our braking was only very average, now not even the little clubmans, super sport 400kg motorbike engine powered things can outbrake us. But being a 1000kgs heavier we just cant accelerate through the corner like they can :kiss:
I believe the only difference between the 6potters is bigger pad, better wear and less fade again, but they cost more. But big brakes with a good suspension setup surely will yield better results then std brakes with a good suspension setup...would it not? Weve found it like that so far.
The tyres are the limiting factor in braking performance, using a full slick means that YOU have a higher limit. Therefore you will benefit from larger brakes until such time as the brakes’ performance once more exceeds the tyres’ grip (CoF). Once you reach that point, going larger in the brakes would have zero effect. To get any improvement in braking performance you would have to improve the grip levels first.
In good condition, the standard Nissan Sumitomo callipers (4 spot front and 2 spot rear) with standard sized rotors and decent pads can easily exceed R type tyres CoF. So sticking BIG brakes on a road Skyline with road tyres is simply a waste of money from an improving performance view point. If all you are chasing is the look, then that's a different question.
:happy: cheers :angry:
Speaking of looks, I'll be pulling the Bremmies off to fit braided lines and give them a recolour in the same crystal Metalcast red I have on the engine covers, similar i guess to SK's.
At the risk of getting off topic (Which seems to about lube oil & adult themes which I don't want to think about) how do I get more performance out of my stock GT-R calipers? The R compounds will grip up to 1.2-1.3 gees, but the brakes will only ever kick out one gee (Above 100km/h), no matter how hard I push. Pads are good Ferodo DS2500's all round.
Well my guess is that the only way for us to increase the tyre grip any further would be to run a softer compound slick rather then the mediums were running now. But i think i could say that at the moment since our skyline isnt a road sort the brakes are well suited, and they still exceed the tyres grip as a lock up is still capable. ive got flat spotted slicks to prove that :(
Ooooh, very nice (rice). My brake callipers are more Snap On red, not candy apple like the cam covers.
:( cheers :O
How about a higher CoF pad compound? Say a Performance Friction or a Hawke.
:( cheers :O
I have read this thread, and also done a search and read quite a few threads. Im after some pads for spirited street driving, good when cold, good when pushed a bit. Its for a mildly modifyed R32 GTR.
I was thinking Ferodo DS2500? Any input?
Thanks
Hey Marcus,
What you putting on the rear??
Nice brakes, bet you can't wait to get it on the track...
Used Pizza trays and some multi-grips with custom braided lines and links. Should lock those rears easy! :laugh:
By performance are you allowing for consistancy? I agree with what you are saying with the std calipers, but the rotors? GTRs are a big heavy car with a good turn of grunt.
And thinking logically there has to be something to the fact that Nissan gave the R32 V-Spec 324mm rotors. The only real difference in caliper is the step up to differential sized pistons, bot the piston area wasnt overly different. The fact that the R33 and R34 uses 324mm rotors, the N1 GTRs use 324mm rotors etc etc
Well i think thats a decent indicator that even Nissan think the original R32 brakes were a little underdone, whilst the 324 rotors with Brembos is good enough for the cars they hoped would be competitive in Production Racing
So dont think the R32 GTR brakes can do a great job even with good pads etc, do the job yes, but shoudl be pretty high up on the list of things to do if you want to enjoy and go quick at the track. Of course if you only need three laps at a time...i will change my tune
dammit. now i wanna upgrade my fronts from f40 to something bigger :laugh:
ive got ap 4pots on the rear with 330x26mm twopiece. veryy impressed with them.
but... one thing i noticed is they came with alloy pistons. wich i thought was stupid.
so from a factory standard of the shelf caliper. i think the brembos are better. stainless pistons annd a big enoughf pad thats very widly used to keep the pad cost down. honestly the "big reds" are a nice caliper.
but some nice monoblock brembos or alcons would be cool*droules*
Hey Marcus,
hoping to run a std GTR33 rear brembo with 350z rotor (322mm) if someone (not naming anyone, Roy) gets off his Dutton fat arse and draws up the brackets...
that is unless i find a set of porsche 911 radial rears in the meantime...
What size rotors you got up front? 365mm??
Thanks
DS2500's are a great 'all round' competition pad. I run them on the street also, but I would probably vote them as being more of a short track/circuit pad than a full time street pad. You CAN run them on the street all the time, they feel ok, but they whine and carry on a bit when cold which some people find annoying.. ie sounds a bit like a train pulling up.. ~squeeelll~
If you are on the street all the time, not doing any circuit work or anything - I would probably recommend Bendix Ultimates or even Performax? Cheaper, less noisy - still work well for one or three hard stops.
Even Ultimates can sometimes have a little squeal though.. seems to be on a car by car basis to some degree.
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
