What Fuel Do Skylines Love?
brizzi
 Share
  • Replies 69
well guys i have a tock standard 260rs with a dtop in replacement K7N and a full 3" echaust fitted.
i ran with a few 98 rons and founf mobil to be the most powerful , bp smoother and sheel the worse of the lot. ALthough i miced once optimax with extreme once and theres a lot of difference only 10 ltrs to the tank i added with the extreme.
Since Sk said and proved that theres no problem running on extreme then how about running on United? Anubody test it long term @ 10 or 15% ethanol? Cos it sounds very cheap. Ectreme costs about 1.59+ i think. Im very tempted to try the United one.
heres is the link to see where its available in whole Oz
http://www.unitedpetroleum.com.au/distribu...8-locations.asp
Edited by stasis
I just had a fiddle with Uniteds Boost98 E10 pulp.
Not all that happy with it to be honest. knock levels are down and it allows more timing to be dialed in but it just doesn't seem to have the same top end as the usual BP 98.
Maybe its going a tad lean but if that were the case I would expect it to detonate which its not. hrmm
Best not too fiddle as its strange, off for a power run it goes.
Really doesn't bother me to be honest. I don't plan on running the united boost98.
Optimax Extreme I believe will be fine.
I have heard reported in the media issues with ethanol and engine corrosion and its effect on metal parts. What steps are you taking to protect my engine and its components?
The issues you have heard about relate to a situation in 2003 when some retailers were selling fuel products with more than 20% ethanol blend without sufficient disclosure to customers. Shell was not involved in this practice and took active steps at the time to promote that our fuel did not contain ethanol. It has now been shown through extensive testing and research that a maximum 10% ethanol content is suitable for many cars which is why the Federal Government has set a maximum 10% ethanol content in Australian fuel. Shell has determined that a formulation of 5% ethanol optimises Shell Optimax Extreme (the same level that Governments in Europe are encouraging in their specification). All ethanol used in Shell fuel contains a suitable corrosion inhibitor.
I will be ripping out the fuel pump (shows up there first) 3 months after I start using the fuel to ensure there is no corrosion. If not then another 3months and if not then another.
I tried United Boost 98, 3 days ago and although it drives smoother (ie when revving at 4k rpm it feels like 3k rpm), it massively loses power ( on a BNR32), I mean its noticeable!!.
One thing i noticed beacause i overfilled with boost, that it left a yellowish oily trail, which went like glucose overnite, and couldnt be cleaned with water, but with soap.
I too noticed Boost98 was smoother and appeared to have more part throttle acceleration, however top end suffered. Do remember to make use of this fuel the car needs to be tuned to suit as it leans the car out.
I richened up mine by 1 point which should have brought it back to 12:1 and dialed in more ign until I saw det but it still just didn't feel the same in the top end as the origional setup with BP 98.
So for me.. Its bp98 until Optimax Extreme heads my way.
I must also mention my external bosch fuel pump in hot weather usually develops a loud buzzing fuel sucking type noise. It can only be heard on the out side of the car.
Well... Since I dropped this Boost98 stuff in even in cold weather it has constantly had this noise. I used the Boost98 up, dropped in BP 98 and instantly the Bosch pump was quiet and has stayed quiet all the way home.
Interesting.
Interesting.
I have use optimax extreme and its 10 cents more expensive than optimax itself. Long term in terms of affordability its very expensive.
That why i was so interested in the United boost 98 get it tuned to match it and it will save long run. Thats just my theory anyway. But optimax xtreme is damn expensive.
I'm just not sure I can put up with the fuel pump sound that the BOOST98 causes. :)
I've now got BP98 in it and the fuel pump (external Bosch) has gone silent again.
Its a strange finding but most likely due to myself not throwing the car on the dyno, richening up the afr and dialing more ign. in on the usual boost level saw no noticable improvement. However simply dialing up the boost did. There was no knock on Boost98 and the car felt strong. Drop BP98 back in to it and it began detonating.
So Boost98 does appear to have an advantage over the BP98. It simply needs to be tuned to suit, there is no point even trying to fiddle myself on the street without a wideband.
But yer.. Not sure I could put up with the fuel pump noise from Boost98. :laugh:
Other than your fuel pump noise no other problems? Does anybody used boost 98 before on a long term? Can we set 2 different settings with the power Fc using the hand controller than? Switching to different mao when using different fuels.
^ OK well if you're gonna be that specific about fuels, I'd call that semi-PULP fuel if i was being pedantic.
But either way, the original statement made by Rosie_1008 is still wrong according to SydneyKid's knowledge - throughout the thread he has informed us of the different fuel companies who share their 98RON fuels, and which fuel comes from where and whos refinery.
the only problem is that apparantly ethanol can bond to H20 - thats why there was a stink about it when it was first being used coz obviously water and pistons dont mix.
however i think its unlikely to actually get enough water into your engine to do instant damage but i think the whole point is that it "can" do damage over time... who knows if it actually does... i mean most of us use high flow air filters that prolly let in just as much crap and water vapour anyway.
dude why do people put water injection systems in there car to help with inlet temperetures.... an awfull lot of supercharged cars an now quite a few turbo'ed run a water injection system on the pressure side cant see its gonna hurt the pistons when you have a exploding fireball next to it... gonna dissapate preety quick
 Share
    • Little more work!  Did some body work on the rear wheel arches and since the paint was a cheap spray job before figured I’d do something to tide me over until I wrap the car.    Colour might not be everyone’s choice but I like it and it’s only temporary, just hate having primer from the wheel arches standing out.    Keeping an eye out for a decent set of wheels to throw on now. Wheels and tires on the car are junk
    • Its likely to be 70% road 30% track usage, track usage will increase if anything. Decided not to fit it as I cant be arsed changing the bushes on my LCAs again 🤣 I did get the below back from GKTech though so they should work together     The anti-squat kit and roll center adjusters work independently since they change the rear lower control arm's angle in different ways. The anti-squat kit adjusts the angle from front to back, which impacts anti-squat values. Roll center adjusters change the angle side to side, mainly to correct geometry on cars that are significantly lowered. They might affect each other a tiny bit, but overall, you can think of them as separate.
    • What are you doing with the car? street car or race car? People get hung up on the squat of the s/r chassis rears. There is positives to the squat if a car is setup and driven correctly for it (correct ride height, spring rate, alignment, damper valving). Generally just lengthen the rear traction arm by 5-10mm and that will help the squat and bump steer too. You are also correct with the roll centre too. This too also needs to be adjustable if you start messing with suspension geometry.   Having done quiet a bit of testing on race cars this year in regards to rear squat, I've seen some big positives from it in regards to drive off corners and traction.
    • I find I am using the MX5 for everything except long overnight cruises with Jackie, or, if picking up the kids to go somewhere, the SS has so much more room inside, and is much more comfortable if your going to be doing Hwy driving for 6-8 hours And the MX5 isn't bad in stop go traffic for a manual transmission car, whilst the clutch kit has been upgraded from stock, it is still light, and also not having a stupidly light flywheel in it helps as well, I've spent alot of time sitting on the M5, M4 and M7 stuck in traffic when plodding around the Greater Sydney Region in it Another benefit is MX5's are not really a car that gets stolen, you can pretty much park it anywhere, and it will still be there when you return
    • I can totally get why you like it for that sort of commute. I was thinking BoganDore because it's such a lazy drive, for things like stop start traffic.   I used to do over an hour in stop start shit from one side of Bris to the next, twice a day. My choice of car was larger displacement, with an auto. Basically for torque in low rpm/very low speed, and no clutch pedal. But loved a fun manual for the weekends, which the partner has (plus had the LandCruiser too for other fun drives). I now have an EV as a work car, and I tell ya what, ultimate daily driver, especially if youre out of energy, like I often am after work. I don't even need to touch the brake pedal   That said, I'm presently rebuilding the Liberty GTB to get it setup for weekend drives and track abuse! So small high revving turbo engine with 6 speed cog swapper!   But for your style of commute, I'd probably take the MX5 too!   For those choices, I'm ignoring fuel economy. Because I know how atrocious V8 daily life is for fuel from when I used to daily a manual SS, ha ha. Hence why I know I love the daily rumble of a V8
