I have a set of standard R32 GTS-t rims that i am using for my track tyres (so will see some high speeds).
I found out the other day that one of them has a slight 'hop' or buckle in it from some time in the past... not much, its out of round at one point by a couple of mm.
now, the tyre shop that mounted the tyres to the rims (yesterday) and did a balance, claim that they were able to balance the wheel with the buckle/hop to within 4 grams, and the other 3 wheels to within 1 or 0 grams. They say that their usual tolerance is 7 grams, and that with the balance being that good, that i wouldn't even notice the hop/buckle...
what are your thoughts on this?
https://www.sau.com.au/forums/topic/132330-wheel-balancing/
if the buckle is only tiny, i mean as you said a couple of mm. then yes when it is balanced the hop will almost disapear, but i mean if you are getting up around 160 - 200 km/h then you may still feel something, your bes bet would be put the rim with the most hop in it on the rear of the car then that way you will feel it even less.
https://www.sau.com.au/forums/topic/132330-wheel-balancing/#findComment-2451010
Within 5 grams for road use would be acceptable as you not hitting really high speeds but being a perfectionist I like to get mine to within 1 gram.
BUT there are other tings to consider = How much wieght did it take to balance out the rim? General rule of thumb = 60 grams is about the maximum allowable but again I'd reduce that for high speed work and also you must consider your tyres. If it is only a small buckle, it shouldn't be a problem but if it is larger than the tyre will form to the buckle which will give you a vibe at best and start wearing struts, bushes, ball joints etc at very worst.
IMO if it is only a couple of mm out and it didn't take much wieght to balance out - put it on the back and it should be sweet!
What tyres did you get track whore? I was thinking of doing the same but couldn't decide wether to put semis on my stockies, Enkei's or trade my practically new sets off both sets of wheels for one semi set on the Enkei's
because for road use you'll get up to about 25-30,000 kms out of a set if W/A and pressures etc. are right and I don't drive mine that often.
Edited by ellie
https://www.sau.com.au/forums/topic/132330-wheel-balancing/#findComment-2451173
well, i just looked at the weights on the tyres then...
they read like this:
Wheel 1: 2 x 15g
Wheel 2: 1 x 30g, 1 x 15g
Wheel 3: 2 x 10g
Wheel 4 (that we identified as having the hop in it): 1 x 10g, 1 x 20g
I'm not driving the car with these rims/tyres every day... they're being used solely for track work (i.e. not very often at all)... so hopefully it won't come to the point of wearing shocks etc.... realistically, i should feel the car shaking before it comes to that anyway, shouldn't I? I guess if it is shaking more than just a little bit i'll probably just put my street tyres back on in place or something
I got myself 4 x second hand (good condition) Bridgestone RE55s in SR compound (according to this diagram, the 'hardest')
https://www.sau.com.au/forums/topic/132330-wheel-balancing/#findComment-2451446
Suspension damage at the very worst for very bad buckles! sorry, I should of said it clearer!
BUT if the wieghts are that low I'd be surprised if they couldn't have been balanced better.
BUT that amount of weight on each rim is pretty good!
https://www.sau.com.au/forums/topic/132330-wheel-balancing/#findComment-2453629
i'm happy to bring them down to you to balance :(
https://www.sau.com.au/forums/topic/132330-wheel-balancing/#findComment-2453656
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
