I have recently purchased a 99 R34 GTR. Now I want to make it the best all around performance car I can. I want it's HP numbers between 500 to 600 (373 to 448 Kw) to the wheels. I plan on dumping a ton of money into it and I figured since they are actually legal in Australia that you guys would have a ton of experience on them.
Thank you in advanced
https://www.sau.com.au/forums/topic/132343-american-needs-help-with-r34-gtr/
n1....why not go for a nismo gt block? Are they not supposed to be the ducks nuts of the rb26 blocks?
80g...damnit, why spend that on a road car....build a track car 80g ontop of what you have would be awesome so long as you do the work yourself cause thats alot of parts you can get.
Also 600hp at all 4 wheels is alot of power, probably too much for a street. I dont know what the loss is for 4wheel drive but i would say at least 100hp minimum so thats like 700ponies(523 4wkw) at the fly, maybe more!
Edited by r33_racer
I wasn't sure if I could find a Nismo GT block.
As for the money that would cover every aspect of the car...Suspension, new interior and body styling new paint...But mostly will go to engine.
As for the 6oo HP to the wheel that is my max, but maybe 560 to 580hp would be fun
And from people I have asked with a manual AWD you lose 80hp
Harley,
You really need to take into account what you want from your car. Most GTR's (here anyway) are used as daily drivers. I like to use mine more for track work rather than drags or dyno. I have it set up so I get reasonably early power, but not MONSTER power which would see me with more lag down low. The highger your horsepower requirements (generally) the higher your lag. I have mine built firstly for reliability and secondly for performance. Forged internals would be mandatory for reliability and power. Also if you are going near the track, get a race sump - not a street sump which most of the performance houses sell.
I still use a single plate clutch which is a delight to drive with and has held up extremely well on the track.
I can't stress enough to work out what it is you really want to do with the car before you start your build.
Good luck.
dude ,
start looking at some MOTEC ECUs since you have the $$$ then consider stroking the engine to a bigger displacement.
Bigger turbo (run single maybe? -for bigger top end output)
Edited by hicas_posse
Harley,
Good luck.
I agree completly and reliablity is my 1st concern and then worry about making perform well for time attack or track use. I still plan on driving it daily during the summer so no huge horrible laggy turbo, from what I have read the 2530's sound good or is there a better set to go with....I would like between the range of 500-600 hp tp the wheels and thats it
As for being built the GT block or N1 block and then the HKS stroker kit sounds good and then getting it blueprinted and honed. Any advice to make a nice built motor will be appreciated
If I were building something with that power at the wheels with that budget I would probably do something as follows:
N1 block
JUN 2.7L stroker kit (crank, rods, pistons)
JUN oil pump
9 litre enlarged and baffled sump (CRD in Australia could help you out with that and send one over)
JUN 272 degree 11.35mm lift camshafts
JUN titanium bits for head (buy this and the cams as a package)
JUN cam gears
Tomei gasket kit and head oil feed restrictor
HKS T04Z turbine kit (turbo, manifold, wastegate)
HKS Type R intercooler
HKS Type S oil cooler
HKS duel entry fuel rail
Sard 800cc injectors
Sard type RJ fuel pressure regulator
Bosch 044 pump in tank going to surge tank, with twin 044's pumping from surge tank
ECU of your choise
Youre then going to need some form of gearbox/clutch combination. I am a big fan of the OS Giken OS88 6 speed sequential box, but this might push your budget a bit (the box itself is $16,000 AUD or so) but then again if youre doing alot of the work yourself you will save greatly on labour costs.
Id also drill and tap an extra oil drain from the back of the head to the sump, as reccomended many times on this forum.
But that above combination would be an awesome street package in my opinion and run some impress 1/4 mile times too. It would easily put out over 400kw at the treads.
Edited by Amaru
what he said would be da bom^^...
Also the HKS 2.8 stroker kit with a set of HKS-GTRS turbos would be awesome!! Check out some of the well setup shop cars from japan such as the Mines R34 (my fav & track weapon), OS 3ltr (awesome) and the MCR R34(hks 2.8 + GTRS)...
I would suggest that 370awkw is acheivable with a set of 2530's or trust 517z's but the engine setup, tune & boost levels will be critical...
With a single such as a T04z you can pull 400+awkw easy but miss the midrange of the lowmounts...but great top end trade off.
my 2c, goodluck
^^^ All awesome suggestions
However, no advice is free, we expect pics when this monster is done.
And I reserve the right to act ina manner that is insanely jealous and cry like a baby if you crash it.
my 2c, goodluck
The 2.7L will rev to 10,000+rpm on pump fuel which is why the T04Z goes so well on it. I guess you could say it effectively moves your midrange up a few thousand rpm, as changing at 10,000rpm wont make you fall as far back down in the rev range as changing at 8 will :/
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
