i blame that on every 1 else not keeping up when i gunned it so i went slow after that and early on in the cruise we had a spot of rain :(
yer those stagea drivers.. :P heheh
Ahh wasn't too bad.. Was fairly brisk at times then at other times it felt as if we were not moving. :/
  • Replies 51
yer those stagea drivers.. :( heheh
Ahh wasn't too bad.. Was fairly brisk at times then at other times it felt as if we were not moving. :P
hey!! :D
i thought we did a pretty good job of keeping up...except for getting stuck behind a terribly slow 4wd going up mt lofty - double lines all the way. After that things picked up a bit... :D
Very nice drive, and i was very impressed to experience how well the stagea handles. Its just sooo much more than just a family wagon!! :O
I've came across a few posts where 'Tuna' (Who I believe is Martin Donnan) tested BOOST98 and found it provided more power over other PULP fuels.
I've just dropped $30 in an empty tank, I will check out if it affects ign. timing tomorrow.
Apparently cleans your fuel system right up so its recommended to change your fuel filter after a tank of the stuff.
Also I've found that Boost98 hasn't had any effect on how much my engine pings. Damn. However its good stuff its a lot cheaper than BP Ultimate and the rest and the station is only 100m from where I live. But I have a strange feeling that its only me that ever buys Boost98 there so I begin to wonder how old the stuff is.
my dad works for mobil and says it would be very rare that it would just sit there Busk2k
i sits in the storage tanks @ the terminals for ages b4 getting to the servo's 1 would suggest it doesnt have a shelf life
Im pretty sure the boost98 runs a little leaner so you probably need to richen it up slightly, but it can handle a fair bit more timing.
Let us know how you go joel. Dyno before and after???
A quote from Mr. Chops this time last year. :)
Ok, I have done a little bit more research on this fuel.
Speaking to Martin Donnon today, it turns out this fuel CAN be a good thing. If tuned for this "boost 98" every car he's seen has picked up power in comparison to regular 98 octane fuel.
There is a catch however. He showed me some dyno graphs, and just by changing to this from another 98RON fuel, the car LEANED OUT BY A FULL AFR POINT (ie 12.5-13.5).
This would explain the increase in performance experienced by owners of cars with factory style rich tunes, but if your car is tuned on regular 98, and is "on the edge" I would steer clear, it could give you problems.
A full point is a hell of a lot. :P
I dont understand. If its tuned to the edge then the Boost98 should do better. Isn't that the whole point? Ie winding in more timing/leaning it out. Although I bet if you leaned out most cars by a full AFR point you'll end up pulling timing, not adding it in.
Well thats just it...
If it has leaned the car out and still running the usual ign. timing and not pinging then there is definitely room for improvement by dropping the afr back down to 12-12.5 and dialing in more ign. timing.
All though mr. Chops is a reliable source I almost find it hard to believe that it will lean it out by a full point. I've richened it up by half a point (without wideband guestimating) and will see what ign. it will take.
All though last night I gave it a little squirt after dropping boost98 in and felt a little lean spot after 5000-5500rpm.
No det just had that lean feel if you know what I mean.
I guess to know the lean feel takes many years of being a fiddler. lmao.
Some interesting comments on this stuff.
I would have thought that the idea when using a higher grade fuel was to maintain the same AFR while producing more power. To do this you then have to advance the timing due to the longer burn time. The effectiveness of it then comes down to the fact that you need less of it to maintain the AFR, you can fit more air in the cylinder for a bigger bang & therefore create more power.
I have done a fair bit of reading & research as well as having a bit of experience on this subject, & this is my understanding on how it works. Leaning out sounds like a bit of a worry, like the fuel is actually a lower octane rather than higher. Confusing
Edited by JazzaR33
I ended up using the Boost98 up as quickly as possible as it made my external bosch pump noisy. :)
Some who have a bosch pump may know of the sound I speak of. It usually only makes the louder buzzing, airating type noises on hotter days after a long drive.
This fuel for what ever reason made the pump do it all the time. :laugh:
I didn't have any luck from a seat of the pants point of view richening up the mixture, dialing in more ign (managed to get another 3degree's in) and feeling more go, it still felt not as rev happy.
However.... Leaving ign and fuel as it is and dialing in more boost saw another 2psi being pushed in before I began to see signs of det and it definitely did feel better.
Dropping BP 98 straight in after saw increased levels of det with the increased boost level. The fuel pump also instantly shut up and has stayed quiet since.
Without a wideband I can't do anything.. Boost98 really does need to see the dyno.
If it wasn't for the fuel pump noise when running Boost98 I would stick with it. :laugh:
I used to buy it from there too busky :)
Just make sure you check your AF Busky. Martin tested and tuned a lot of cars on boost98 when the fuel first came out. He found that the car runs fairly lean with the extra oxygen in the fuel. Your knock might be ok but the cylinders and exh temp might be dangerously high.
I've been using Boost98 on the my R32 almost since I got the car. Great power gain after Martin tuned it for this fuel. I use Shell Extreme when ever I go to the track up here. The car seems to like the extra RON. You guys will love it when it's on the pump.
What Bosch pump are you using?
I'm running a 4.5yr old Bosch 910 thats done somewhere around 140,000-150,000km's.
Its a little long in the tooth. I'm going to have shaun fit an 044 intank as he is able to get them in there and keep them quiet. Bl4ck32's 044 is silent compared to my 910.
Well I was going to drop the Boost98 idea and wait for the extreme 100 gear but after driving today it appears at the higher the boost level requires .... 3degree's retard to stop det from the previous boost98.
I think i'll give this boost98 gear a go. I'll have a chat to shaun see when I can sort out a bit of dyno time to do the back to back.
I ended up using the Boost98 up as quickly as possible as it made my external bosch pump noisy. :P
This fuel for what ever reason made the pump do it all the time. :(
If it wasn't for the fuel pump noise when running Boost98 I would stick with it. :)
You may find the main reason the pump was noisy is either 1 of 2 things: Either the Boost98 fuel is more prone to cavitation with the ethanol in it, or the ethanol fuel itself is less lubracative, meaning the brushes & bearings are wearing faster & therefore making more noise. Either way it doesn't sound like a good thing.
4 & a half years isn't that long for a fuel pump though should have a bit of life in it yet.
The other thing with the ignition timing, I read somewhere that ethanol actually burns faster than petrol due to it not being in great long chains like high octane petrol, so in theory this would mean you actually have to retard the timing a bit anyway for the same amount of fuel would it not?
Edited by JazzaR33
    • This might be true if you live in NZ but I can't see how this could be true for us locals here.  I've found the customer support for Haltech to be absolutely amazing. I've turned up to Haltech and spent entire days with their tech support guys, they've even helped me with wiring dramas that had nothing to do with their products.  They have the best customer support of any company I've dealt with, I can't imagine how my experiences with them could possibly be any better.
    • If you want to do a single throttle body conversion easily, you won't need to pull anything apart. Take the linkage from your throttle off the linkage controlling the ITBs. Now open the ITBs wide open, and lock the linkages in said position. Now add a single throttle body onto the front of your inlet plenum. No it's not ideal for the last nth of a kw, but it'll be a lot better than what you're already trying to do...   PS, ITBs can be so damn hard to tune from, because roughly 20% movement in a throttle body equates to a change in roughly 80% of its flow (Hence power). When you add up the flow limitations of those small throttle bodys, it is a LOT higher than that of a single large throttle. Hence, TPS is very very sensitive with them, and you do a LOT of work with sensor fusion, and some Maths behind the scenes to make those blends nice, and be smooth.
    • Yep, when Haltech purchased Adaptronic, and all of the Adaptronic staff, including Andy went with it, it took Haltech to the next level. Haltech wanted Adaptronic as they wanted things like Andy's fuel models, and some other IP, AND they wanted Andy too as he is brilliant! Andy has spoken about the incompatibilities between the old 1500 stuff vs Nexxus, and it totally makes sense. It's not JUST software that is different, there is huge changes in the underlying hardware too. It's why Haltech has had soooo many changes in the last couple of years, in terms of Hardware, and Software, and why it has become so damn Amazing. Why do you think guys like Rob Dahm with his quad rotor, went from running Adaptronic's to running Haltechs? Andy. Pretty much, Haltech these days, is Adaptronic, but with more funds behind it, and more staff, and hence Andy's visions, and visions of other people that he helps shape their great visions, into amazing new products. All the new Nexxus gear, whole new software for it, new and better dashboards, the apps that will run on headunits and NOT be slow to respond! I understand people being burnt in the past, but if you're ragging on a company, about products and issues from many years ago, it's more a reflection on yourself, not looking or keeping up with new stuff. In which case, those people should be going back to PowerFC and Nistunes as the ECU's to rave on about...
    • Right, but I thought the problem has been for a while now that even if you know manifold pressure + throttle position you still have non-linearity and aliasing issues vs actual engine load? One way I can see things simplifying is going DBW, then all air going into the engine is represented by the throttle position. As opposed to a random bimetallic strip vaguely linked to engine temperature opening and closing a shutter or some random power steering air valve suddenly allowing a bunch of bypass air. But the same throttle position/RPM at ~atmospheric MAP in different gears is not guaranteed to be same engine load? Honestly, ITBs are of such dubious value IMO. I don't know why these things are hyped up so much. The main benefit as far as I can tell is you reduce the likelihood of cross-cylinder EGR scavenging with significant cam overlap at idle. I would absolutely run speed density and be done with it if not for this fairly esoteric control problem.
    • Hah dont worry, my adult brain has this conversation every single day. Dont waste your money, invest more of it into shares, pay down the mortgage. Then the bedtime insta doom scrolling begins and after being bombarded with gtr's my mind is set: im definitely getting one! I have the current model mx5 as the weekender, but i just miss my boost and literally like your username, the sututu's that come with it. I remember with my 2nd supra, as it had twins and vvti, they used to spool real early, like 1,500rpm so you could just be a spooly boy all day long. Some people say they get over it after a while, not me tho.
