hes well looked after he got satin sheets and all the works :/:(
And i whipped his ass and he had to do the food shop on his own..so we all know who is in charge in this relationship
Edited by Wildcat
  StageaGirl said:
Hey Wildcat, hyperdrive found that my rear wipers motor for the water spray is the wrong one :/ (it wasn't working, and still isn't :huh:)I have no idea why there is a wrong motor in there.
When my S1 arrived the rear washer did not work. The fronts were fine and the same pump is used for both.
The line to the rear wasblocked. You can get to it by removing the rear cover and the rubber gromets in the body and the tailgate. Disconnect the line and pump through and clean nozzle.
If that doesn't clear it and the pump motor works it would have to be the solenoid that opens the pathway for the water, or the line is blocked closer to the pump I have not got a clue where the solenoid is at the moment, but will search if you need more info.
Cheers 66yo. :):nuke:
I think I have stuffed up.lol
I checked again and it seems like there are two motor sounds when both washers are on together. Check and listen. Ifyou can hear the motor work when it should the it could be a blockage at the rear nozzle.
Its quite easy to get to the line via the cover and grommets in the back .
Cheers 66yo :nuke::/
:huh::)
  StageaGirl said:
Hey Wildcat, hyperdrive found that my rear wipers motor for the water spray is the wrong one :) (it wasn't working, and still isn't :huh:)I have no idea why there is a wrong motor in there.
Well im lucky enough that the water spray still works and comes out like its suppose to...the wiper just doesnt move...will have a closer look tonight or tomorrow when it eventually stops pissin down with rain :nuke:
  Wildcat said:
Well im lucky enough that the water spray still works and comes out like its suppose to...the wiper just doesnt move...will have a closer look tonight or tomorrow when it eventually stops pissin down with rain :mad:
The PDWR got me. Its pissing pickhandles here and we love it. Costs $120 for a load of water. :rant::O
  Wildcat said:
oh mister tangles :D i have faith..i just like to be independent and being a girl and all i would like to be able to do things that men think only they can do :mad: but of course hubby can look at it and fix it and i can watch ;):(
You like to watch....................... eh :huh:
  Wildcat said:
hes well looked after he got satin sheets and all the works :mad::P
OUCH!!!!!!! Damn you ARE WHIPPED Mr GTST!!!!!!!!
While we are talking rear wipers...
Take a look at the length of mine! I have the fuse removed so it can't be turned on, if it is it just tries to smash the squirter nozzle off tailgate, pretty funny but a little scary at the same time. The wiper arm has Toyota stamped into it so it's wrong in more ways than one!
Anyone have a spare rear wiper arm? Or one they would be happy to part with? I will post a WTB in the trade section but will not be holding my breath...
Cheers
Luke
Far out Munch, thats a bit big... although I have to agree with who ever put it on... piddly little wiper on the back :P
66yo I think the problem is with the motor that runs the water, its the wrong one, The back wiper works and the fronts work with the washers.
I'mTOTALLY confused.
Is it correct to say (1) The front wipers and washers work
(2) The rear wiper works but the washer does not
(3) The rear washer works but the wiper does not
(4) Nothin' f**kin' works?
(5) Caus its pissin pick handles and I forgot to change the HW from solar to electric
we have all had to have cold showers and its buggered my night life.
(6) And if thats not enough the boys and I, successfully fitted a new water pump and
timing belt into a 180.
(7) God is good to NISSAN drivers.
Cheers 66yo. :D:D
how can the rear window washer motor be wrong? surely any washer motor will work with the 2 wires connected. i got both washer motors sitting in my garage doing nuthin (cant fit washer bottle with cooler piping), but i might need them later on. how about buy a new one stagea girl from nissan? they wont be much $$$ i'd imagine.
Yes it was a very easy job...(for the hubby) :laugh:
Was just a matter of pulling the cap off the wiper arm and tightening the nut... :laugh:
Little embarrasing after all that worrying to find that it was about a 5minute fix job..but at least now i have a working WINDOW WIPER :laugh:
:laugh::laugh: for everyones help and advice much appreciated
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
