Gearbox Specifications And Interchangeability
In a bid to archive this info myself or to have it as a sticky, it would be nice to have as much info as possible on gearboxs. Which ones are interchangeable? Ie apparently rb20de = rb20det. Things like which ones pull and push type. Gearbox gear widths, bearing diameters, etc. HP rating through experience (torque rating??).
Add please.
RB20DE
RB20DET
Same as RB25DE box ( i think)
Same as SR boxes too i think
RB25DE
RB25DET
RB26DETT
RB30E
RB30ET
GTST4 box
umm. ok.
FS5W71B L SERIES,CA (PRE TWINCAM)FJ20,
FS5W71C single syncro. RB20e,rb20de,rb30e,REDTOP RB20,LATE FJ20ETrb25de,ca18de,sr20de
FS5W71C twin syncro RB20DET,SR20DET,LATE CA18DET
FS5R30A SINGLE SYNCHRO.vg20det,vg30e vg30et,rb30et
FS5R30A TWIN SYNCHRO, VG30DET,RB25DET,RB26DETT.
fs5r30a pull clutch. 33gtr late 32gtr,rb25 neo
upgrades..
FJ20ET TO RB BOX. elongate top bellhousing bolts :P inward about 6mm each.
fj20 tight ass secondhand box replacement. anny l series box or ca box (aka bluebird box)will fit. you just need to swap the bellhousing. as the angle is oposite.
early fj use a small bearing on the countershaft front. will need to be swapped onto the doner gearset.
rb 20 upgrade. a 25 box will bolt up. the tailshaft yoke is differant and the gearbox x member needs to be moved backward 50mm aprox.
vg upgrade. swap internals from rb25det
rb30 upgrade, as above.
fj20e,lseries,ca18,sr20de rb20e,rb20de use a 225mm push clutch
vg30e,et usus a 240mm push clutch
vg30de uses a 240mm push clutch
sr20det 240mm push clutch
fj20et 240mm push clutch
rb20det all use a 240mm push clutch.
rb25det all uses a 240mm push clutchup to r34 skyline.
rb25det neo uses a 250mm pull clutch
rb26. pre 94 uses a 240mm push clutch
rb26 post 94 usus a 250mm pull clutch
vg30dett uses a 250mm push clutch
not listed is s15 duel mass flywheel clutch. the norm is fitting a s14 clutch and bearing carier.
all 250mm clutches can mix n match,
ie rb25det upgrade is a r33gtr,rb25 neo flywheel with a vg30dett clutch disc atd plate. small mods needed. to rear main seal plate/engine flange plate to clear flywheel.
r34gtr uses the same clutch as the 33 but on a diferant flywheel.
non turbo variants with the small 225mm clutch can swap for the bigger turbo clutch/flywheel asembly of the same engine family.
all 71b,c boxes have the SAME gear sizes. later ones have improved bearings and selectors.
all 30a boxes have the same gear sizes, later ones have bigger bearings and improved synchros,selectors.
thats about all i can come up with atm my head hurts.
Being new to this type of car I have a question for you T04GTR
You being a mechanic and all I'm getting a R33GTR but being a Auto type guy I want to convert it to.
I have been told that a Auto form a Stagea will bolt right up with min probs. Is this the case?
Thanks in Advance
  • 1 month later...
question
im aware that the RB20det and RB20de boxes in terms of strength are the same.
difference being the ammount of synchros
if i was to bolt both of these up to my fj20et engine
in terms of drivability what would the difference be..
thanx
Thanks in Advance
yep. or 33 gts4 all bolt in :laugh:
question
thanx
twin synchro.
i poped 11 single synchro boxes in my dr30. (i just loved ripping seconds and 3rds) basicly the twin synchro will cop more before it crunches :laugh:
twin synchro.
i poped 11 single synchro boxes in my dr30. (i just loved ripping seconds and 3rds) basicly the twin synchro will cop more before it crunches :)
thanx for the input mate
but i was actually wanted to kno the difference between the N/A RB20 box and the turbo RB20 box in terms of drivability..
not the comparison between the fj20 box and rb20box
cheers
so a 5 speed manual can be converted into a 6 speed for the rb26 98"?
Yes. but you need new clutch/flywheel, new clutch slave/new clutch line. tail shaft modified to suit. and the gearbox too. there are also a few other fiddly things to do to have it all working
  • 8 years later...
 Share
    • And by the way, I've also checked the ECU diagnostic numerous times and got a bad O2 sensor code and initially an Ignition Primary code, which is why I replaced the O2 sensor and all the ignition components (coil packa, plug and loom). No codes have been coming up lately despite the ongoing issue.
    • Hey pber13, unfortunately still no luck. At this point the following has been done with little or no success: - Spark plugs replaced, gapped to 0.8mm - Splitfire coilpacks installed to replace originals - Replaced Ignition Coil/Coilpack harness with a new genuine nissan one - New fuel filter - Replaced AFM/MAF sensor - Injectors have been thoroughly cleaned with an online flush (without removing) - Upper engine and inlet decarbed - blew tons of black smoke out, cleared the carbon deposits from the top of the engine and exhaust.  - IACV removed and thoroughly cleaned with carburettor cleaner - O2 sensor replaced with new and genuine one -  Smoke test revealed no vacuum leaks - Healthy compression test of 160psi across all 6 cylinders Overall the car does run a lot smoother now, no backfires between gear shifts like it did originally... but the rough idle when warmed up is still there. It may not even be a misfire but simply a rough idle. Seems crazy to me that so many people have had this issue and seemingly no one has gotten to the bottom of it, or at least never bothered to post if they did! Hope you have more luck than I did pber13, I'm at a point now where I'm just going to try to ignore it unless it gets worse. Would love to fix it but I've genuinely run out of ideas of what it could be.
    • I got the full frenchys kit too. Really awesome kit. Easy to install my only complaint was the hardlines I think could be routed differently (I modified mine) but I realise the kit needs to suit multiple applications. This was the hard lines before I modified them. They were touching the wastegate pipe. I ended up reducing the distance between firewall and first bend. The made it so they tucked along the frame rail.
    • Deeve, I don't suppose that you've made any progress on this? My Stagea has the exact same problem, and just like you, I've read through as much as I can online, with no real progress. My car isn't throwing any codes at all, which is a little frustrating. I've changed plugs, checked the wiring and harness. A new MAF gets here next week, but I'm not hopeful it will solve the issue.
    • I installed it all myself,  It was really easy to install.  I got a professional to do the degas/gas.
