Hi guys,
I have a mildly tuned skyline that seems to have everything done to it, bar injectors and AFM. Thanks to someone's "tuning" guide on the forums (can't remember the name) it mentions that before you bolt a new turbo on, AFM upgrade is a good idea.
The guide mentions that in higher output situations the Q45 has a higher throughput, and i'm wondering if there is any reason why you wouldn't just grab a Q45 as opposed to a Z32 (less response maybe?)?
Currently have a stock Turbo, but like i said, its AFM then injectors then turbo (with a full tune in there somewhere too) to push to 250ish rwkw (from 194 noe).
Any advice would be appreciated, as i come from a Carby Background, bolting on a 780cfm Rochester doesn't look like it would do the job :D.
Cheers,
Geoff
Edited by nsanity
https://www.sau.com.au/forums/topic/132503-z32-vs-q45/
the z32 is fine, its good for beyond 350rwkw and wont pose a restriction.
people would likely use a q45 for larger intake turbo piping and more resolution. but with the q45 comes the issue of changing pipework and likely pod filter or airbox connect as its 90mm instead of 80mm so standard airbox, pods etc won't fit.
https://www.sau.com.au/forums/topic/132503-z32-vs-q45/#findComment-2455065
So i'd still be left with a nice fair of quality all-round turbo's with the Z32 and standard piping installed? If there is a killer all round turbo that suits the q45, i'd probably look at that.
I want something that is as responsive as it can be, but still packs a bunch when you put the hammer down.
https://www.sau.com.au/forums/topic/132503-z32-vs-q45/#findComment-2455079
any of the reasonable sized inlets will suit the z32.
theres no need to choose a turbo based around the afm size and pipework.
with the z32 you can use the standard afm duct piping or you can even go the apexi power intake or a custom one to suit the stock afm, as the z32 is identical in size and same shape/bolt pattern
whereas q45 is completetly different
https://www.sau.com.au/forums/topic/132503-z32-vs-q45/#findComment-2455085
I would only use the Q45 AFM when I needed the extra resolution for the extra power output. They don't meter as well as the Z32 at low airflows. So if you don't need the big airflow, use the Z32. The car will run nicer and get better fuel economy, plus it will be a damn side easier to tune.
:D cheers ;)
Edited by Sydneykid
https://www.sau.com.au/forums/topic/132503-z32-vs-q45/#findComment-2455353
:D cheers ;)
exactly my concerns :P
cheers for that
https://www.sau.com.au/forums/topic/132503-z32-vs-q45/#findComment-2455381
I recently installed a VG30 AFM which diretcly bolts on to the rb25 intake. I was told its good for 350rwkw
I was of the impressed the VG30 is the same or similar to the Z32 AFM. Can some1 confirm. THe VG30 I assume means it came off a 300ZX type engine and the Z32 is the AFM type.
I followed the following process after reading stuff here.
Get a new ECU - at the time I had an Emanage installed which was ok to a point
Zorst inc. 730CFM cat
Dump/front pipe
AFM + fuel pump + manual boost control
Turbo upgarde - custom high flow in my case
FMIC
AVCR for better boost control
Injectors
CAI setup - although I did this more for the looks.
PFC - is comming in 1 week.
This gets you a good results on the road, not so good for your bank balance :)
https://www.sau.com.au/forums/topic/132503-z32-vs-q45/#findComment-2457420
So i visited Zebbie and Vader today.
Zebbie thinks that my car "lacks punch" 4.5k rpm onwards.
According to the powerfc, duty cycles aren't going past 70.9% (several hills and very very aggressive accelerations to test).
The car feels like its just plateauing.
Thommo (the guy i bought the car from) mentioned it was tuned by ICE down in Melbourne (who i'm told have a good rep), would the car benefit from a Z32 or similar (peak readings were roughly 6.8k rpm, 0.992 bar boost (capped at 0.8 apparently), 70.9% duty cycle) at this stage? I have the option to purchase one, and i'm getting the car once overed by the guys up here in Canberra.
Or do i really need to look at a better turbo?
SydneyKid was mentioning you get boost cut from the stock AFM around the 9 - 10 psi mark, which could explain the flatness around the 4.5k - 7k mark under full throttle maybe.
If its not going to be a substantial upgrade (10 - 15rwkw), i will wait till i do the turbo as well, but if its worth doing now, i'll get it done.
Also, on a sidenote - my injectors are upgraded ones it would seem?
Edited by nsanity
https://www.sau.com.au/forums/topic/132503-z32-vs-q45/#findComment-2457727
    • No-one in Aus/NZ would pay that much, because they remember when a turbo Skyline/Silvia was a cheap but awesome alternative to the mediocre shit sold here locally at the time. I'm sure over in USA there are enough trust fund kids who will have their R34 GTR, whatever the cost
    • I am stuck with enthusiast and very unhappy, even though Lumley, Shannons and Famous are all options, they all require a lock up garage, and my situation (basically a walled off compound from the street) is insufficient because the car is under a carport. I'm confident to resolve the situation I need to build a roller door with fascia in-front of my roller gate which is a solid opaque metal rolling gate. In any other universe moving the roller door 2 meters in-front of the garage door would still constitute the same amount of security but oh no. My insurance rates suck to the point of when I joined a market research for Enthusiast they were all surprised that I paid about 2-3x what other people were paying with Enthusiast when I asked them why their rates were so high. If I lie about having a garage, I save like $10 a month with enthusiast. (It's about $2600 p.a for 5000km of driving for a very unsustainable agreed value). Lumley has terrible reviews but @Duncan made me consider calling them when renew time came up - but their horrible reviews plus Christmas time made me... forget.
    • Not far. If all you want to do is know that they will reciprocate and move oil around a tiny bit, then a metre or so is all you need. Half metre fore and aft is enough.
    • That's the spirit!
    • It's fine. Basically if it has seized (eg due to moisture/rust in the bores) it will either break free on the starter or it won't turn....then you'll know it is freed up If it turns and doesn't start (reasonably likely) you will need to troubleshoot but most likely issue is a seized injector from moisture; same if it starts but missfires. Anything else could have happened (eg mice nibbling electricals) but the only way to find out is to close your eyes and hit the key I'd also change the fuel filter again after a few minutes of running as it may catch a heap of crap on first start
